[pdal-commits] [PDAL/PDAL] f50a63: STANDALONE prefix for building RDB plugin
Andrew Bell
noreply at github.com
Wed Dec 23 12:38:54 PST 2020
Branch: refs/heads/issue-3321
Home: https://github.com/PDAL/PDAL
Commit: f50a63d6f2d522475a4ccf1baf9a1d60a99311a8
https://github.com/PDAL/PDAL/commit/f50a63d6f2d522475a4ccf1baf9a1d60a99311a8
Author: Howard Butler <howard at hobu.co>
Date: 2020-11-05 (Thu, 05 Nov 2020)
Changed paths:
M plugins/rdb/CMakeLists.txt
Log Message:
Commit: 26b3374c3e7fa09ce21b90ac3a2bed8803479c15
https://github.com/PDAL/PDAL/commit/26b3374c3e7fa09ce21b90ac3a2bed8803479c15
Date: 2020-11-11 (Wed, 11 Nov 2020)
Changed paths:
M test/unit/io/FauxReaderTest.cpp
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Commit: e1b4e80ed152af41b9639e0854e6a1c80f6c8c6b
https://github.com/PDAL/PDAL/commit/e1b4e80ed152af41b9639e0854e6a1c80f6c8c6b
Date: 2020-11-30 (Mon, 30 Nov 2020)
Changed paths:
M .github/workflows/alpine.yml
M .github/workflows/conda.yml
M .github/workflows/docker.yml
M .github/workflows/docs.yml
M .github/workflows/linux.yml
M .github/workflows/osx.yml
M .github/workflows/win.yml
M cmake/options.cmake
A doc/apps/chamfer.rst
M doc/development/compilation/windows.rst
M doc/references.rst
M doc/stages/filters.litree.rst
M doc/stages/filters.lof.rst
A doc/stages/filters.teaser.rst
M doc/stages/writers.ogr.rst
M filters/ApproximateCoplanarFilter.cpp
M filters/ApproximateCoplanarFilter.hpp
M filters/CovarianceFeaturesFilter.cpp
M filters/EigenvaluesFilter.cpp
M filters/EigenvaluesFilter.hpp
M filters/EstimateRankFilter.cpp
M filters/EstimateRankFilter.hpp
M filters/FaceRasterFilter.cpp
M filters/LOFFilter.cpp
M filters/LOFFilter.hpp
M filters/LiTreeFilter.cpp
M filters/LiTreeFilter.hpp
M filters/MiniballFilter.cpp
M filters/MiniballFilter.hpp
M filters/OptimalNeighborhoodFilter.cpp
M filters/OptimalNeighborhoodFilter.hpp
M filters/PlaneFitFilter.cpp
M filters/PlaneFitFilter.hpp
M filters/RadialDensityFilter.cpp
M filters/RadialDensityFilter.hpp
M filters/ReciprocityFilter.cpp
M filters/ReciprocityFilter.hpp
M filters/RelaxationDartThrowing.cpp
M filters/SampleFilter.cpp
M filters/private/expr/Lexer.cpp
M io/GDALWriter.cpp
M io/GltfWriter.cpp
M io/Ilvis2MetadataReader.cpp
M io/LasVLR.cpp
M io/ObjReader.cpp
M io/ObjReader.hpp
M io/private/ept/EptInfo.cpp
M io/private/ept/Key.hpp
A kernels/ChamferKernel.cpp
A kernels/ChamferKernel.hpp
M pdal/Dimension.json
M pdal/Geometry.cpp
M pdal/PDALUtils.cpp
M pdal/PDALUtils.hpp
M pdal/PointView.hpp
M pdal/Polygon.cpp
M pdal/private/Raster.hpp
M pdal/private/gdal/BaseBand.cpp
M pdal/private/gdal/GDALUtils.cpp
M pdal/private/gdal/Raster.cpp
M pdal/util/Bounds.hpp
M pdal/util/CMakeLists.txt
M pdal/util/FileUtils.hpp
M pdal/util/ThreadPool.cpp
M pdal/util/ThreadPool.hpp
M plugins/CMakeLists.txt
M plugins/pgpointcloud/test/PgpointcloudTest.cpp
A plugins/teaser/CMakeLists.txt
A plugins/teaser/filters/TeaserFilter.cpp
A plugins/teaser/filters/TeaserFilter.hpp
A plugins/teaser/filters/registration.h
A plugins/teaser/test/TeaserFilterTest.cpp
M plugins/tiledb/CMakeLists.txt
M plugins/tiledb/io/TileDBReader.cpp
M plugins/tiledb/test/TileDBWriterTest.cpp
M test/unit/CMakeLists.txt
A test/unit/apps/ChamferTest.cpp
M test/unit/filters/NormalFilterTest.cpp
M test/unit/io/EptReaderTest.cpp
M test/unit/io/LasWriterTest.cpp
Log Message:
Commit: 4c7e4c401849ac71b2dcd7e64f0755f6f0f755f5
https://github.com/PDAL/PDAL/commit/4c7e4c401849ac71b2dcd7e64f0755f6f0f755f5
Date: 2020-12-07 (Mon, 07 Dec 2020)
Changed paths:
M pdal/Scaling.cpp
M scripts/ci/linux/setup.sh
Log Message:
Commit: 74876b02283beea30ecc9a4d205d0faa89177961
https://github.com/PDAL/PDAL/commit/74876b02283beea30ecc9a4d205d0faa89177961
Date: 2020-12-16 (Wed, 16 Dec 2020)
Changed paths:
M io/GeotiffSupport.cpp
M io/GeotiffSupport.hpp
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasReader.cpp
Log Message:
Support capturing GTifPrint output for LAS header metadata for diagnostic support (#3301)
* STANDALONE prefix for building RDB plugin
* Implement #3299 to support GTifPrint info in LAS header metadata
* no-op if we can't cast the thing we were given to a printer
* address PR comments
Commit: f14474529abe1f4a3c470ab0a65576a7e07a84f3
https://github.com/PDAL/PDAL/commit/f14474529abe1f4a3c470ab0a65576a7e07a84f3
Date: 2020-12-17 (Thu, 17 Dec 2020)
Changed paths:
M doc/apps/pipeline.rst
M doc/apps/translate.rst
M doc/stages/readers.ept.rst
M io/EptReader.cpp
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasReader.cpp
M kernels/PipelineKernel.cpp
M kernels/PipelineKernel.hpp
M kernels/TranslateKernel.cpp
M kernels/TranslateKernel.hpp
M pdal/PointLayout.cpp
M pdal/PointLayout.hpp
M scripts/ci/conda/compile.sh
M scripts/ci/conda/setup.sh
M scripts/docker/ubuntu/Dockerfile
M test/unit/PointTableTest.cpp
M test/unit/filters/IcpFilterTest.cpp
M vendor/eigen/Eigen/Core
M vendor/eigen/Eigen/Eigenvalues
M vendor/eigen/Eigen/Geometry
A vendor/eigen/Eigen/KLUSupport
M vendor/eigen/Eigen/LU
M vendor/eigen/Eigen/OrderingMethods
M vendor/eigen/Eigen/PaStiXSupport
M vendor/eigen/Eigen/QR
M vendor/eigen/Eigen/Sparse
M vendor/eigen/Eigen/SparseCholesky
M vendor/eigen/Eigen/SparseLU
M vendor/eigen/Eigen/SparseQR
M vendor/eigen/Eigen/src/Cholesky/LDLT.h
M vendor/eigen/Eigen/src/Cholesky/LLT.h
M vendor/eigen/Eigen/src/CholmodSupport/CholmodSupport.h
A vendor/eigen/Eigen/src/Core/ArithmeticSequence.h
M vendor/eigen/Eigen/src/Core/Array.h
M vendor/eigen/Eigen/src/Core/ArrayBase.h
M vendor/eigen/Eigen/src/Core/ArrayWrapper.h
M vendor/eigen/Eigen/src/Core/Assign.h
M vendor/eigen/Eigen/src/Core/AssignEvaluator.h
M vendor/eigen/Eigen/src/Core/Assign_MKL.h
M vendor/eigen/Eigen/src/Core/Block.h
M vendor/eigen/Eigen/src/Core/BooleanRedux.h
M vendor/eigen/Eigen/src/Core/CommaInitializer.h
M vendor/eigen/Eigen/src/Core/CoreEvaluators.h
M vendor/eigen/Eigen/src/Core/CoreIterators.h
M vendor/eigen/Eigen/src/Core/CwiseBinaryOp.h
M vendor/eigen/Eigen/src/Core/CwiseNullaryOp.h
M vendor/eigen/Eigen/src/Core/CwiseUnaryView.h
M vendor/eigen/Eigen/src/Core/DenseBase.h
M vendor/eigen/Eigen/src/Core/DenseCoeffsBase.h
M vendor/eigen/Eigen/src/Core/DenseStorage.h
M vendor/eigen/Eigen/src/Core/Diagonal.h
M vendor/eigen/Eigen/src/Core/DiagonalMatrix.h
M vendor/eigen/Eigen/src/Core/DiagonalProduct.h
M vendor/eigen/Eigen/src/Core/Dot.h
M vendor/eigen/Eigen/src/Core/EigenBase.h
M vendor/eigen/Eigen/src/Core/Fuzzy.h
M vendor/eigen/Eigen/src/Core/GeneralProduct.h
M vendor/eigen/Eigen/src/Core/GenericPacketMath.h
M vendor/eigen/Eigen/src/Core/GlobalFunctions.h
M vendor/eigen/Eigen/src/Core/IO.h
A vendor/eigen/Eigen/src/Core/IndexedView.h
M vendor/eigen/Eigen/src/Core/Inverse.h
M vendor/eigen/Eigen/src/Core/Map.h
M vendor/eigen/Eigen/src/Core/MapBase.h
M vendor/eigen/Eigen/src/Core/MathFunctions.h
M vendor/eigen/Eigen/src/Core/MathFunctionsImpl.h
M vendor/eigen/Eigen/src/Core/Matrix.h
M vendor/eigen/Eigen/src/Core/MatrixBase.h
M vendor/eigen/Eigen/src/Core/NestByValue.h
M vendor/eigen/Eigen/src/Core/NoAlias.h
M vendor/eigen/Eigen/src/Core/NumTraits.h
A vendor/eigen/Eigen/src/Core/PartialReduxEvaluator.h
M vendor/eigen/Eigen/src/Core/PermutationMatrix.h
M vendor/eigen/Eigen/src/Core/PlainObjectBase.h
M vendor/eigen/Eigen/src/Core/Product.h
M vendor/eigen/Eigen/src/Core/ProductEvaluators.h
M vendor/eigen/Eigen/src/Core/Random.h
M vendor/eigen/Eigen/src/Core/Redux.h
M vendor/eigen/Eigen/src/Core/Ref.h
M vendor/eigen/Eigen/src/Core/Replicate.h
A vendor/eigen/Eigen/src/Core/Reshaped.h
M vendor/eigen/Eigen/src/Core/ReturnByValue.h
M vendor/eigen/Eigen/src/Core/Reverse.h
M vendor/eigen/Eigen/src/Core/Select.h
M vendor/eigen/Eigen/src/Core/SelfAdjointView.h
M vendor/eigen/Eigen/src/Core/Solve.h
M vendor/eigen/Eigen/src/Core/SolveTriangular.h
M vendor/eigen/Eigen/src/Core/SolverBase.h
M vendor/eigen/Eigen/src/Core/StableNorm.h
A vendor/eigen/Eigen/src/Core/StlIterators.h
M vendor/eigen/Eigen/src/Core/Swap.h
M vendor/eigen/Eigen/src/Core/Transpose.h
M vendor/eigen/Eigen/src/Core/Transpositions.h
M vendor/eigen/Eigen/src/Core/TriangularMatrix.h
M vendor/eigen/Eigen/src/Core/VectorBlock.h
M vendor/eigen/Eigen/src/Core/VectorwiseOp.h
M vendor/eigen/Eigen/src/Core/Visitor.h
M vendor/eigen/Eigen/src/Core/arch/AVX/Complex.h
M vendor/eigen/Eigen/src/Core/arch/AVX/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/AVX/PacketMath.h
M vendor/eigen/Eigen/src/Core/arch/AVX/TypeCasting.h
A vendor/eigen/Eigen/src/Core/arch/AVX512/Complex.h
M vendor/eigen/Eigen/src/Core/arch/AVX512/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/AVX512/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/AVX512/TypeCasting.h
M vendor/eigen/Eigen/src/Core/arch/AltiVec/Complex.h
M vendor/eigen/Eigen/src/Core/arch/AltiVec/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/AltiVec/MatrixProduct.h
A vendor/eigen/Eigen/src/Core/arch/AltiVec/MatrixProductCommon.h
A vendor/eigen/Eigen/src/Core/arch/AltiVec/MatrixProductMMA.h
M vendor/eigen/Eigen/src/Core/arch/AltiVec/PacketMath.h
M vendor/eigen/Eigen/src/Core/arch/CUDA/Complex.h
A vendor/eigen/Eigen/src/Core/arch/Default/BFloat16.h
A vendor/eigen/Eigen/src/Core/arch/Default/GenericPacketMathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/Default/GenericPacketMathFunctionsFwd.h
A vendor/eigen/Eigen/src/Core/arch/Default/Half.h
M vendor/eigen/Eigen/src/Core/arch/Default/Settings.h
A vendor/eigen/Eigen/src/Core/arch/Default/TypeCasting.h
A vendor/eigen/Eigen/src/Core/arch/GPU/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/GPU/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/GPU/TypeCasting.h
A vendor/eigen/Eigen/src/Core/arch/HIP/hcc/math_constants.h
A vendor/eigen/Eigen/src/Core/arch/MSA/Complex.h
A vendor/eigen/Eigen/src/Core/arch/MSA/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/MSA/PacketMath.h
M vendor/eigen/Eigen/src/Core/arch/NEON/Complex.h
M vendor/eigen/Eigen/src/Core/arch/NEON/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/NEON/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/NEON/TypeCasting.h
M vendor/eigen/Eigen/src/Core/arch/SSE/Complex.h
M vendor/eigen/Eigen/src/Core/arch/SSE/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/SSE/PacketMath.h
M vendor/eigen/Eigen/src/Core/arch/SSE/TypeCasting.h
A vendor/eigen/Eigen/src/Core/arch/SYCL/InteropHeaders.h
A vendor/eigen/Eigen/src/Core/arch/SYCL/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/SYCL/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/SYCL/SyclMemoryModel.h
A vendor/eigen/Eigen/src/Core/arch/SYCL/TypeCasting.h
M vendor/eigen/Eigen/src/Core/arch/ZVector/Complex.h
M vendor/eigen/Eigen/src/Core/arch/ZVector/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/ZVector/PacketMath.h
M vendor/eigen/Eigen/src/Core/functors/AssignmentFunctors.h
M vendor/eigen/Eigen/src/Core/functors/BinaryFunctors.h
M vendor/eigen/Eigen/src/Core/functors/NullaryFunctors.h
M vendor/eigen/Eigen/src/Core/functors/UnaryFunctors.h
M vendor/eigen/Eigen/src/Core/products/GeneralBlockPanelKernel.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular_BLAS.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector.h
M vendor/eigen/Eigen/src/Core/products/Parallelizer.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixVector.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointProduct.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointRank2Update.h
M vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix.h
M vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix.h
M vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/TriangularSolverVector.h
M vendor/eigen/Eigen/src/Core/util/BlasUtil.h
A vendor/eigen/Eigen/src/Core/util/ConfigureVectorization.h
M vendor/eigen/Eigen/src/Core/util/Constants.h
M vendor/eigen/Eigen/src/Core/util/DisableStupidWarnings.h
M vendor/eigen/Eigen/src/Core/util/ForwardDeclarations.h
A vendor/eigen/Eigen/src/Core/util/IndexedViewHelper.h
A vendor/eigen/Eigen/src/Core/util/IntegralConstant.h
M vendor/eigen/Eigen/src/Core/util/MKL_support.h
M vendor/eigen/Eigen/src/Core/util/Macros.h
M vendor/eigen/Eigen/src/Core/util/Memory.h
M vendor/eigen/Eigen/src/Core/util/Meta.h
M vendor/eigen/Eigen/src/Core/util/ReenableStupidWarnings.h
A vendor/eigen/Eigen/src/Core/util/ReshapedHelper.h
M vendor/eigen/Eigen/src/Core/util/StaticAssert.h
A vendor/eigen/Eigen/src/Core/util/SymbolicIndex.h
M vendor/eigen/Eigen/src/Core/util/XprHelper.h
M vendor/eigen/Eigen/src/Eigenvalues/ComplexEigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/ComplexSchur.h
M vendor/eigen/Eigen/src/Eigenvalues/EigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/GeneralizedSelfAdjointEigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/HessenbergDecomposition.h
M vendor/eigen/Eigen/src/Eigenvalues/MatrixBaseEigenvalues.h
M vendor/eigen/Eigen/src/Eigenvalues/RealQZ.h
M vendor/eigen/Eigen/src/Eigenvalues/RealSchur.h
M vendor/eigen/Eigen/src/Eigenvalues/SelfAdjointEigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/Tridiagonalization.h
M vendor/eigen/Eigen/src/Geometry/AlignedBox.h
M vendor/eigen/Eigen/src/Geometry/AngleAxis.h
M vendor/eigen/Eigen/src/Geometry/EulerAngles.h
M vendor/eigen/Eigen/src/Geometry/Hyperplane.h
M vendor/eigen/Eigen/src/Geometry/OrthoMethods.h
M vendor/eigen/Eigen/src/Geometry/ParametrizedLine.h
M vendor/eigen/Eigen/src/Geometry/Quaternion.h
M vendor/eigen/Eigen/src/Geometry/Rotation2D.h
M vendor/eigen/Eigen/src/Geometry/Scaling.h
M vendor/eigen/Eigen/src/Geometry/Transform.h
M vendor/eigen/Eigen/src/Geometry/Translation.h
M vendor/eigen/Eigen/src/Geometry/Umeyama.h
M vendor/eigen/Eigen/src/Geometry/arch/Geometry_SSE.h
M vendor/eigen/Eigen/src/Householder/BlockHouseholder.h
M vendor/eigen/Eigen/src/Householder/Householder.h
M vendor/eigen/Eigen/src/Householder/HouseholderSequence.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/BiCGSTAB.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/ConjugateGradient.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/IncompleteCholesky.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/IterativeSolverBase.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/LeastSquareConjugateGradient.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/SolveWithGuess.h
M vendor/eigen/Eigen/src/Jacobi/Jacobi.h
A vendor/eigen/Eigen/src/KLUSupport/KLUSupport.h
M vendor/eigen/Eigen/src/LU/Determinant.h
M vendor/eigen/Eigen/src/LU/FullPivLU.h
M vendor/eigen/Eigen/src/LU/InverseImpl.h
M vendor/eigen/Eigen/src/LU/PartialPivLU.h
A vendor/eigen/Eigen/src/LU/arch/InverseSize4.h
M vendor/eigen/Eigen/src/OrderingMethods/Amd.h
M vendor/eigen/Eigen/src/OrderingMethods/Eigen_Colamd.h
M vendor/eigen/Eigen/src/OrderingMethods/Ordering.h
M vendor/eigen/Eigen/src/PaStiXSupport/PaStiXSupport.h
M vendor/eigen/Eigen/src/PardisoSupport/PardisoSupport.h
M vendor/eigen/Eigen/src/QR/ColPivHouseholderQR.h
M vendor/eigen/Eigen/src/QR/CompleteOrthogonalDecomposition.h
M vendor/eigen/Eigen/src/QR/FullPivHouseholderQR.h
M vendor/eigen/Eigen/src/QR/HouseholderQR.h
M vendor/eigen/Eigen/src/SPQRSupport/SuiteSparseQRSupport.h
M vendor/eigen/Eigen/src/SVD/BDCSVD.h
M vendor/eigen/Eigen/src/SVD/JacobiSVD.h
M vendor/eigen/Eigen/src/SVD/SVDBase.h
M vendor/eigen/Eigen/src/SVD/UpperBidiagonalization.h
M vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky.h
A vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky_impl.h
M vendor/eigen/Eigen/src/SparseCore/AmbiVector.h
M vendor/eigen/Eigen/src/SparseCore/CompressedStorage.h
M vendor/eigen/Eigen/src/SparseCore/ConservativeSparseSparseProduct.h
M vendor/eigen/Eigen/src/SparseCore/SparseAssign.h
M vendor/eigen/Eigen/src/SparseCore/SparseBlock.h
M vendor/eigen/Eigen/src/SparseCore/SparseCompressedBase.h
M vendor/eigen/Eigen/src/SparseCore/SparseCwiseBinaryOp.h
M vendor/eigen/Eigen/src/SparseCore/SparseCwiseUnaryOp.h
M vendor/eigen/Eigen/src/SparseCore/SparseDenseProduct.h
M vendor/eigen/Eigen/src/SparseCore/SparseMatrix.h
M vendor/eigen/Eigen/src/SparseCore/SparseMatrixBase.h
M vendor/eigen/Eigen/src/SparseCore/SparseProduct.h
M vendor/eigen/Eigen/src/SparseCore/SparseRef.h
M vendor/eigen/Eigen/src/SparseCore/SparseSelfAdjointView.h
M vendor/eigen/Eigen/src/SparseCore/SparseUtil.h
M vendor/eigen/Eigen/src/SparseCore/SparseVector.h
M vendor/eigen/Eigen/src/SparseCore/SparseView.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_Memory.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_SupernodalMatrix.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_column_dfs.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_gemm_kernel.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_panel_bmod.h
M vendor/eigen/Eigen/src/SparseQR/SparseQR.h
M vendor/eigen/Eigen/src/StlSupport/StdDeque.h
M vendor/eigen/Eigen/src/StlSupport/StdList.h
M vendor/eigen/Eigen/src/StlSupport/StdVector.h
M vendor/eigen/Eigen/src/SuperLUSupport/SuperLUSupport.h
M vendor/eigen/Eigen/src/UmfPackSupport/UmfPackSupport.h
M vendor/eigen/Eigen/src/misc/lapacke.h
M vendor/eigen/Eigen/src/plugins/ArrayCwiseBinaryOps.h
M vendor/eigen/Eigen/src/plugins/ArrayCwiseUnaryOps.h
M vendor/eigen/Eigen/src/plugins/BlockMethods.h
M vendor/eigen/Eigen/src/plugins/CommonCwiseUnaryOps.h
A vendor/eigen/Eigen/src/plugins/IndexedViewMethods.h
M vendor/eigen/Eigen/src/plugins/MatrixCwiseUnaryOps.h
A vendor/eigen/Eigen/src/plugins/ReshapedMethods.h
Log Message:
Commit: 30a257ada8d12d1a74ee5eb25dd42a930d41d11a
https://github.com/PDAL/PDAL/commit/30a257ada8d12d1a74ee5eb25dd42a930d41d11a
Changed paths:
M doc/tutorial/iowa-entwine.rst
Log Message:
doc update
Commit: 30dcb7d335e7af4d99f6d9a88a08b2471ab81b0b
https://github.com/PDAL/PDAL/commit/30dcb7d335e7af4d99f6d9a88a08b2471ab81b0b
Changed paths:
M doc/index.rst
Log Message:
update front page NEWS
Commit: a25c0689a5c6cc8fdc8205b55d60383c3ecd1a53
https://github.com/PDAL/PDAL/commit/a25c0689a5c6cc8fdc8205b55d60383c3ecd1a53
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
Log Message:
Make Dockerfile consistent with base.
Commit: c4404a0709c67275daefea9a4a0f8a03d81b7c2b
https://github.com/PDAL/PDAL/commit/c4404a0709c67275daefea9a4a0f8a03d81b7c2b
Changed paths:
Log Message:
add latest tag to docker container builds
Commit: 047ef709c6582a061a619897f5ad5de3872900e6
https://github.com/PDAL/PDAL/commit/047ef709c6582a061a619897f5ad5de3872900e6
Date: 2020-12-18 (Fri, 18 Dec 2020)
Changed paths:
M doc/stages/readers.i3s.rst
M doc/stages/readers.slpk.rst
Log Message:
Update I3S doc (#3320)
Commit: 706257321dc311253888a1c30e79897aefdf0e4e
https://github.com/PDAL/PDAL/commit/706257321dc311253888a1c30e79897aefdf0e4e
Date: 2020-12-23 (Wed, 23 Dec 2020)
Changed paths:
M doc/index.rst
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasReader.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-3321
Compare: https://github.com/PDAL/PDAL/compare/01dff091397b...706257321dc3
More information about the pdal-commits
