[pdal-commits] [PDAL/PDAL] 3b09a6: Remove what seem to be unnecessary property settin...
    Howard Butler
    noreply at github.com
    Sun Jan  5 20:52:34 PST 2020
  Branch: refs/heads/readers.z5
  Home:   https://github.com/PDAL/PDAL
  Commit: 3b09a694d3372d4c9a1daffb80131daac592fd8f
      https://github.com/PDAL/PDAL/commit/3b09a694d3372d4c9a1daffb80131daac592fd8f
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-01-02 (Thu, 02 Jan 2020)
  Changed paths:
    M cmake/gtest.cmake
  Log Message:
  Remove what seem to be unnecessary property settings. (#2859)
  Commit: 1c3b53c0961327d87d78e568032faf0034149b1d
      https://github.com/PDAL/PDAL/commit/1c3b53c0961327d87d78e568032faf0034149b1d
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M filters/TransformationFilter.cpp
    A test/data/filters/transform-newlines.txt
    A test/data/filters/transform-oneline.txt
    M test/unit/filters/TransformationFilterTest.cpp
  Log Message:
  support providing 'matrix' option to filters.transformation via filenames (#2856)
  Commit: 885daf4caf28bc8a7df21958bcc6eb20c2cb66db
      https://github.com/PDAL/PDAL/commit/885daf4caf28bc8a7df21958bcc6eb20c2cb66db
  Date:   2020-01-04 (Sat, 04 Jan 2020)
  Changed paths:
    M cmake/gtest.cmake
  Log Message:
  Merge remote-tracking branch 'origin/master' into readers.z5
  Commit: 4322d78434fcf6cf5da702b62fde17652fa4e31b
      https://github.com/PDAL/PDAL/commit/4322d78434fcf6cf5da702b62fde17652fa4e31b
  Date:   2020-01-05 (Sun, 05 Jan 2020)
  Changed paths:
    M plugins/z5/CMakeLists.txt
    M plugins/z5/io/Z5Reader.cpp
    M plugins/z5/io/Z5Reader.hpp
    M plugins/z5/test/Z5ReaderTest.cpp
    A plugins/z5/test/data/make-test-data.py
    A test/data/z5/1.2-with-color-zstd.zarr/.zgroup
    A test/data/z5/1.2-with-color-zstd.zarr/las/.zgroup
    A test/data/z5/1.2-with-color-zstd.zarr/las/1.2-with-color/.zarray
    A test/data/z5/1.2-with-color-zstd.zarr/las/1.2-with-color/0
    A test/data/z5/bad.zarr/0
    A test/data/z5/bad.zarr/1
    A test/data/z5/bad.zarr/10
    A test/data/z5/bad.zarr/100
    A test/data/z5/bad.zarr/101
    A test/data/z5/bad.zarr/102
    A test/data/z5/bad.zarr/103
    A test/data/z5/bad.zarr/104
    A test/data/z5/bad.zarr/105
    A test/data/z5/bad.zarr/106
    A test/data/z5/bad.zarr/11
    A test/data/z5/bad.zarr/12
    A test/data/z5/bad.zarr/13
    A test/data/z5/bad.zarr/14
    A test/data/z5/bad.zarr/15
    A test/data/z5/bad.zarr/16
    A test/data/z5/bad.zarr/17
    A test/data/z5/bad.zarr/18
    A test/data/z5/bad.zarr/19
    A test/data/z5/bad.zarr/2
    A test/data/z5/bad.zarr/20
    A test/data/z5/bad.zarr/21
    A test/data/z5/bad.zarr/22
    A test/data/z5/bad.zarr/23
    A test/data/z5/bad.zarr/24
    A test/data/z5/bad.zarr/25
    A test/data/z5/bad.zarr/26
    A test/data/z5/bad.zarr/27
    A test/data/z5/bad.zarr/28
    A test/data/z5/bad.zarr/29
    A test/data/z5/bad.zarr/3
    A test/data/z5/bad.zarr/30
    A test/data/z5/bad.zarr/31
    A test/data/z5/bad.zarr/32
    A test/data/z5/bad.zarr/33
    A test/data/z5/bad.zarr/34
    A test/data/z5/bad.zarr/35
    A test/data/z5/bad.zarr/36
    A test/data/z5/bad.zarr/37
    A test/data/z5/bad.zarr/38
    A test/data/z5/bad.zarr/39
    A test/data/z5/bad.zarr/4
    A test/data/z5/bad.zarr/40
    A test/data/z5/bad.zarr/41
    A test/data/z5/bad.zarr/42
    A test/data/z5/bad.zarr/43
    A test/data/z5/bad.zarr/44
    A test/data/z5/bad.zarr/45
    A test/data/z5/bad.zarr/46
    A test/data/z5/bad.zarr/47
    A test/data/z5/bad.zarr/48
    A test/data/z5/bad.zarr/49
    A test/data/z5/bad.zarr/5
    A test/data/z5/bad.zarr/50
    A test/data/z5/bad.zarr/51
    A test/data/z5/bad.zarr/52
    A test/data/z5/bad.zarr/53
    A test/data/z5/bad.zarr/54
    A test/data/z5/bad.zarr/55
    A test/data/z5/bad.zarr/56
    A test/data/z5/bad.zarr/57
    A test/data/z5/bad.zarr/58
    A test/data/z5/bad.zarr/59
    A test/data/z5/bad.zarr/6
    A test/data/z5/bad.zarr/60
    A test/data/z5/bad.zarr/61
    A test/data/z5/bad.zarr/62
    A test/data/z5/bad.zarr/63
    A test/data/z5/bad.zarr/64
    A test/data/z5/bad.zarr/65
    A test/data/z5/bad.zarr/66
    A test/data/z5/bad.zarr/67
    A test/data/z5/bad.zarr/68
    A test/data/z5/bad.zarr/69
    A test/data/z5/bad.zarr/7
    A test/data/z5/bad.zarr/70
    A test/data/z5/bad.zarr/71
    A test/data/z5/bad.zarr/72
    A test/data/z5/bad.zarr/73
    A test/data/z5/bad.zarr/74
    A test/data/z5/bad.zarr/75
    A test/data/z5/bad.zarr/76
    A test/data/z5/bad.zarr/77
    A test/data/z5/bad.zarr/78
    A test/data/z5/bad.zarr/79
    A test/data/z5/bad.zarr/8
    A test/data/z5/bad.zarr/80
    A test/data/z5/bad.zarr/81
    A test/data/z5/bad.zarr/82
    A test/data/z5/bad.zarr/83
    A test/data/z5/bad.zarr/84
    A test/data/z5/bad.zarr/85
    A test/data/z5/bad.zarr/86
    A test/data/z5/bad.zarr/87
    A test/data/z5/bad.zarr/88
    A test/data/z5/bad.zarr/89
    A test/data/z5/bad.zarr/9
    A test/data/z5/bad.zarr/90
    A test/data/z5/bad.zarr/91
    A test/data/z5/bad.zarr/92
    A test/data/z5/bad.zarr/93
    A test/data/z5/bad.zarr/94
    A test/data/z5/bad.zarr/95
    A test/data/z5/bad.zarr/96
    A test/data/z5/bad.zarr/97
    A test/data/z5/bad.zarr/98
    A test/data/z5/bad.zarr/99
    A test/data/z5/make-test-data.py
  Log Message:
  access dataset and group, add some tests, initialize Zarr
Compare: https://github.com/PDAL/PDAL/compare/f96fbc76ae23...4322d78434fc
More information about the pdal-commits
