[pdal-commits] [PDAL/PDAL] 124061: Fix filename handling for tiledb. (#2853)
Andrew Bell
noreply at github.com
Wed Jan 8 09:11:20 PST 2020
Branch: refs/heads/issue-2778
Home: https://github.com/PDAL/PDAL
Commit: 124061dde7fc8d80dae9a5d2fff94e80e138457c
https://github.com/PDAL/PDAL/commit/124061dde7fc8d80dae9a5d2fff94e80e138457c
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2019-12-19 (Thu, 19 Dec 2019)
Changed paths:
M plugins/tiledb/io/TileDBReader.cpp
M plugins/tiledb/io/TileDBReader.hpp
M plugins/tiledb/io/TileDBWriter.cpp
Log Message:
* Fix filename handling for tiledb.
Handle tiledb exceptions.
* Update writer to match reader behavior.
Commit: 7396fb209f8a784f048b83415b661a0a5fcf204e
https://github.com/PDAL/PDAL/commit/7396fb209f8a784f048b83415b661a0a5fcf204e
Author: Pravin Shinde <pshinde825 at gmail.com>
Changed paths:
M filters/private/delaunator.hpp
M plugins/e57/CMakeLists.txt
M plugins/e57/io/E57Reader.cpp
M plugins/e57/io/E57Reader.hpp
M plugins/e57/io/E57Writer.cpp
M plugins/e57/io/E57Writer.hpp
M plugins/e57/io/Scan.cpp
M plugins/e57/io/Scan.hpp
M plugins/e57/io/Utils.cpp
M plugins/e57/io/Utils.hpp
M plugins/e57/io/Uuid.cpp
M plugins/e57/io/Uuid.hpp
M plugins/e57/test/E57ReaderTest.cpp
M plugins/e57/test/E57UtilsTest.cpp
M plugins/e57/test/E57UuidTest.cpp
M plugins/e57/test/E57WriterTest.cpp
M plugins/e57/test/ScanTest.cpp
A test/data/e57/A_B_different_dims.e57
Log Message:
Adding enhancements in E57 plugins (#2847)
* Refactored E57 Reader.
* Added remote file reading support in E57
* fixed indents
* Resolved namespaces, chunksize and spelling mistakes.
* Combined switch cases, resolved e57 namespace in ScanTest.cpp
* Use Array instead of Map for rescale factors.
* Added rescaling optimizations.
* Minor adjustments
* Fixed windows build failure.
* Changed WIN32 to WINDOWS
* fixing CI
* Added more enhancements and features in E57 plugins
* Added test data
* Fixed linux build failure
* Addressing comments
* Changed chunk size to 10000.
* Correction in info text
Commit: 743d44cf439ad7fd4f837de84261a5e3177264c0
https://github.com/PDAL/PDAL/commit/743d44cf439ad7fd4f837de84261a5e3177264c0
Date: 2019-12-20 (Fri, 20 Dec 2019)
Changed paths:
M filters/ClusterFilter.cpp
M filters/ClusterFilter.hpp
M pdal/Dimension.json
Log Message:
Make ClusterID a built-in dimension. (#2854)
Commit: ec934b2bb70c90d630d743cfe8f7017e804cb2cf
https://github.com/PDAL/PDAL/commit/ec934b2bb70c90d630d743cfe8f7017e804cb2cf
Changed paths:
A test/data/filters/elm1.txt
M test/unit/CMakeLists.txt
A test/unit/filters/ELMFilterTest.cpp
Log Message:
Add simple test for ELM filter. (#2855)
Commit: 3b09a694d3372d4c9a1daffb80131daac592fd8f
https://github.com/PDAL/PDAL/commit/3b09a694d3372d4c9a1daffb80131daac592fd8f
Date: 2020-01-02 (Thu, 02 Jan 2020)
Changed paths:
M cmake/gtest.cmake
Log Message:
Remove what seem to be unnecessary property settings. (#2859)
Commit: 1c3b53c0961327d87d78e568032faf0034149b1d
https://github.com/PDAL/PDAL/commit/1c3b53c0961327d87d78e568032faf0034149b1d
Author: Howard Butler <howard at hobu.co>
Changed paths:
M filters/TransformationFilter.cpp
A test/data/filters/transform-newlines.txt
A test/data/filters/transform-oneline.txt
M test/unit/filters/TransformationFilterTest.cpp
Log Message:
support providing 'matrix' option to filters.transformation via filenames (#2856)
Commit: adf3d5bf0b5c0ab64506008044b39e1b55ff0883
https://github.com/PDAL/PDAL/commit/adf3d5bf0b5c0ab64506008044b39e1b55ff0883
Date: 2020-01-06 (Mon, 06 Jan 2020)
Changed paths:
M doc/stages/writers.las.rst
M io/LasWriter.cpp
Log Message:
Add "filesource_id" as an argument for the LAS writer. (#2863)
Commit: bc7726ca03a8151b7d0d3acb1f1e434c18c9d866
https://github.com/PDAL/PDAL/commit/bc7726ca03a8151b7d0d3acb1f1e434c18c9d866
Date: 2020-01-07 (Tue, 07 Jan 2020)
Changed paths:
M filters/SkewnessBalancingFilter.cpp
Log Message:
Change the processing a bit to simplify and eliminate array OOB problem.
Commit: f7105378448f1dc9513ffa20120eec0d8bbeec5a
https://github.com/PDAL/PDAL/commit/f7105378448f1dc9513ffa20120eec0d8bbeec5a
Changed paths:
M cmake/gtest.cmake
M io/LasWriter.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2778
Commit: 31c03321aff7909b2be6974d410452d17f99ca14
https://github.com/PDAL/PDAL/commit/31c03321aff7909b2be6974d410452d17f99ca14
Changed paths:
Log Message:
Fix compiler warning.
Commit: 8fe562b2c24b2e083fbc7e0baaf56fec37ef48ac
https://github.com/PDAL/PDAL/commit/8fe562b2c24b2e083fbc7e0baaf56fec37ef48ac
Changed paths:
Log Message:
Commit: 763d26c67d91ffeafc8dc4f0a8faae6e6f9ef1fa
https://github.com/PDAL/PDAL/commit/763d26c67d91ffeafc8dc4f0a8faae6e6f9ef1fa
Changed paths:
M filters/SkewnessBalancingFilter.hpp
Log Message:
Compilation fixes.
Commit: 93cd5f7cbc4a957c0083a37533419f9310cdb2ea
https://github.com/PDAL/PDAL/commit/93cd5f7cbc4a957c0083a37533419f9310cdb2ea
Date: 2020-01-08 (Wed, 08 Jan 2020)
Changed paths:
Log Message:
Rework to make more clear (hopefully) and eliminate potential OOB situations.
Compare: https://github.com/PDAL/PDAL/compare/31f56d882a75...93cd5f7cbc4a
More information about the pdal-commits
