[pdal-commits] [PDAL/PDAL] 142897: Move Raster to private space.
Andrew Bell
noreply at github.com
Thu Jun 25 10:19:29 PDT 2020
Branch: refs/heads/gdal-utils-raster
Home: https://github.com/PDAL/PDAL
Commit: 142897db4acaec36f905f046621e81590b13c2e7
https://github.com/PDAL/PDAL/commit/142897db4acaec36f905f046621e81590b13c2e7
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2020-06-24 (Wed, 24 Jun 2020)
Changed paths:
M filters/ColorinterpFilter.cpp
M filters/ColorizationFilter.cpp
M filters/DEMFilter.cpp
M filters/HagDemFilter.cpp
M io/GDALReader.cpp
M io/GDALWriter.cpp
M pdal/EigenUtils.cpp
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
A pdal/private/gdal/BaseBand.cpp
A pdal/private/gdal/GDALError.hpp
A pdal/private/gdal/Raster.cpp
A pdal/private/gdal/Raster.hpp
M test/unit/io/GDALWriterTest.cpp
Log Message:
Commit: 05410305ec3934ea14823dd5b0be7ed6e4b00d26
https://github.com/PDAL/PDAL/commit/05410305ec3934ea14823dd5b0be7ed6e4b00d26
Changed paths:
A doc/stages/filters.litree.rst
A filters/LiTreeFilter.cpp
A filters/LiTreeFilter.hpp
M filters/SMRFilter.cpp
M io/TIndexReader.cpp
M kernels/TIndexKernel.cpp
M kernels/private/density/OGR.cpp
M kernels/private/density/OGR.hpp
A pdal/private/gdal/SpatialRef.cpp
A pdal/private/gdal/SpatialRef.hpp
M pdal/util/FileUtils.cpp
M pdal/util/FileUtils.hpp
M plugins/hdf/io/Hdf5Handler.cpp
M plugins/nitf/io/NitfWriter.cpp
M test/unit/CMakeLists.txt
Log Message:
Merge remote-tracking branch 'origin/master' into gdal-utils-raster
Commit: 3c4394e57dec930a177d78962025a1f6c215d6cd
https://github.com/PDAL/PDAL/commit/3c4394e57dec930a177d78962025a1f6c215d6cd
Date: 2020-06-25 (Thu, 25 Jun 2020)
Changed paths:
M filters/OverlayFilter.cpp
M io/Ilvis2MetadataReader.cpp
M io/OGRWriter.cpp
M pdal/Geometry.cpp
M pdal/Polygon.cpp
M pdal/Stage.cpp
A pdal/private/gdal/ErrorHandler.cpp
A pdal/private/gdal/ErrorHandler.hpp
A pdal/private/gdal/GDALError.cpp
M pdal/private/gdal/Raster.cpp
Log Message:
Split up GDALUtils and move to private.
Commit: 4830fba548656b3f23ceb21431fe43da2002b05c
https://github.com/PDAL/PDAL/commit/4830fba548656b3f23ceb21431fe43da2002b05c
Changed paths:
A doc/images/nz_formulas.png
A doc/images/nz_lds_screenshot.png
A doc/images/nz_lvd.png
A doc/images/nz_relationships.png
M doc/stages/writers.las.rst
A doc/tutorial/grid-shift.rst
A doc/tutorial/lvd_to_nzvd2016.py
A doc/tutorial/nz_reproject.json
M io/LasVLR.cpp
A test/data/las/vlr-43.bin
M test/unit/io/LasWriterTest.cpp
Log Message:
Compare: https://github.com/PDAL/PDAL/compare/142897db4aca%5E...4830fba54865
More information about the pdal-commits
