[pdal-commits] [PDAL/PDAL] 037337: Provide option to apply inverse transformation mat...
chambbj
noreply at github.com
Fri Jun 26 07:23:53 PDT 2020
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 0373375812be3918de0878cf5f7a59a367a39424
https://github.com/PDAL/PDAL/commit/0373375812be3918de0878cf5f7a59a367a39424
Author: chambbj <brad.chambers at gmail.com>
Date: 2020-06-26 (Fri, 26 Jun 2020)
Changed paths:
M doc/stages/filters.transformation.rst
M filters/TransformationFilter.cpp
M filters/TransformationFilter.hpp
M test/unit/filters/TransformationFilterTest.cpp
Log Message:
Provide option to apply inverse transformation matrix (#3151)
* Add option to apply the inverse of the provided transformation
* Add a test to invert rotation
* formatting
* Update docs for invert option
* Use Eigen Affine3d instead
* Invert is NOT the default behavior
* Add inverse translation test
* whitespace normalization
More information about the pdal-commits
