[pdal-commits] [PDAL/PDAL] 962709: Update vendored GoogleTest to 1.10.0 (#2946)
Howard Butler
noreply at github.com
Mon Mar 2 06:52:17 PST 2020
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 962709071d66b2c7eda9ecacdae264810564e58d
https://github.com/PDAL/PDAL/commit/962709071d66b2c7eda9ecacdae264810564e58d
Author: Howard Butler <howard at hobu.co>
Date: 2020-03-02 (Mon, 02 Mar 2020)
Changed paths:
M cmake/gtest.cmake
M vendor/gtest/CMakeLists.txt
M vendor/gtest/README.md
M vendor/gtest/cmake/gtest.pc.in
M vendor/gtest/cmake/gtest_main.pc.in
M vendor/gtest/cmake/internal_utils.cmake
M vendor/gtest/docs/Pkgconfig.md
M vendor/gtest/docs/advanced.md
M vendor/gtest/docs/faq.md
M vendor/gtest/docs/primer.md
M vendor/gtest/docs/samples.md
M vendor/gtest/include/gtest/gtest-death-test.h
A vendor/gtest/include/gtest/gtest-matchers.h
M vendor/gtest/include/gtest/gtest-message.h
M vendor/gtest/include/gtest/gtest-param-test.h
M vendor/gtest/include/gtest/gtest-printers.h
M vendor/gtest/include/gtest/gtest-spi.h
M vendor/gtest/include/gtest/gtest-test-part.h
M vendor/gtest/include/gtest/gtest-typed-test.h
M vendor/gtest/include/gtest/gtest.h
M vendor/gtest/include/gtest/gtest_pred_impl.h
M vendor/gtest/include/gtest/internal/gtest-death-test-internal.h
M vendor/gtest/include/gtest/internal/gtest-filepath.h
M vendor/gtest/include/gtest/internal/gtest-internal.h
M vendor/gtest/include/gtest/internal/gtest-param-util.h
M vendor/gtest/include/gtest/internal/gtest-port-arch.h
M vendor/gtest/include/gtest/internal/gtest-port.h
M vendor/gtest/include/gtest/internal/gtest-string.h
M vendor/gtest/include/gtest/internal/gtest-type-util.h
M vendor/gtest/include/gtest/internal/gtest-type-util.h.pump
M vendor/gtest/samples/prime_tables.h
M vendor/gtest/samples/sample1.cc
M vendor/gtest/samples/sample1.h
M vendor/gtest/samples/sample10_unittest.cc
M vendor/gtest/samples/sample2.cc
M vendor/gtest/samples/sample2.h
M vendor/gtest/samples/sample2_unittest.cc
M vendor/gtest/samples/sample3-inl.h
M vendor/gtest/samples/sample3_unittest.cc
M vendor/gtest/samples/sample5_unittest.cc
M vendor/gtest/samples/sample6_unittest.cc
M vendor/gtest/samples/sample7_unittest.cc
M vendor/gtest/samples/sample8_unittest.cc
M vendor/gtest/samples/sample9_unittest.cc
M vendor/gtest/src/gtest-all.cc
M vendor/gtest/src/gtest-death-test.cc
M vendor/gtest/src/gtest-filepath.cc
M vendor/gtest/src/gtest-internal-inl.h
A vendor/gtest/src/gtest-matchers.cc
M vendor/gtest/src/gtest-port.cc
M vendor/gtest/src/gtest-printers.cc
M vendor/gtest/src/gtest-test-part.cc
M vendor/gtest/src/gtest-typed-test.cc
M vendor/gtest/src/gtest.cc
M vendor/gtest/src/gtest_main.cc
M vendor/gtest/test/BUILD.bazel
M vendor/gtest/test/googletest-catch-exceptions-test.py
M vendor/gtest/test/googletest-catch-exceptions-test_.cc
M vendor/gtest/test/googletest-death-test-test.cc
M vendor/gtest/test/googletest-death-test_ex_test.cc
M vendor/gtest/test/googletest-env-var-test.py
M vendor/gtest/test/googletest-filepath-test.cc
M vendor/gtest/test/googletest-filter-unittest.py
M vendor/gtest/test/googletest-filter-unittest_.cc
M vendor/gtest/test/googletest-json-outfiles-test.py
M vendor/gtest/test/googletest-json-output-unittest.py
M vendor/gtest/test/googletest-list-tests-unittest_.cc
M vendor/gtest/test/googletest-listener-test.cc
M vendor/gtest/test/googletest-message-test.cc
M vendor/gtest/test/googletest-options-test.cc
M vendor/gtest/test/googletest-output-test-golden-lin.txt
M vendor/gtest/test/googletest-output-test.py
M vendor/gtest/test/googletest-output-test_.cc
M vendor/gtest/test/googletest-param-test-invalid-name1-test_.cc
M vendor/gtest/test/googletest-param-test-invalid-name2-test_.cc
M vendor/gtest/test/googletest-param-test-test.cc
M vendor/gtest/test/googletest-param-test-test.h
M vendor/gtest/test/googletest-param-test2-test.cc
M vendor/gtest/test/googletest-port-test.cc
M vendor/gtest/test/googletest-printers-test.cc
M vendor/gtest/test/googletest-shuffle-test_.cc
M vendor/gtest/test/googletest-test-part-test.cc
M vendor/gtest/test/googletest-test2_test.cc
M vendor/gtest/test/googletest-throw-on-failure-test.py
M vendor/gtest/test/googletest-throw-on-failure-test_.cc
M vendor/gtest/test/googletest-uninitialized-test.py
M vendor/gtest/test/gtest-typed-test2_test.cc
M vendor/gtest/test/gtest-typed-test_test.cc
M vendor/gtest/test/gtest-typed-test_test.h
M vendor/gtest/test/gtest-unittest-api_test.cc
M vendor/gtest/test/gtest_all_test.cc
M vendor/gtest/test/gtest_assert_by_exception_test.cc
M vendor/gtest/test/gtest_environment_test.cc
M vendor/gtest/test/gtest_pred_impl_unittest.cc
M vendor/gtest/test/gtest_premature_exit_test.cc
M vendor/gtest/test/gtest_repeat_test.cc
A vendor/gtest/test/gtest_skip_environment_check_output_test.py
A vendor/gtest/test/gtest_skip_in_environment_setup_test.cc
A vendor/gtest/test/gtest_skip_test.cc
M vendor/gtest/test/gtest_stress_test.cc
M vendor/gtest/test/gtest_test_utils.py
M vendor/gtest/test/gtest_throw_on_failure_ex_test.cc
M vendor/gtest/test/gtest_unittest.cc
M vendor/gtest/test/gtest_xml_outfile1_test_.cc
M vendor/gtest/test/gtest_xml_outfile2_test_.cc
M vendor/gtest/test/gtest_xml_outfiles_test.py
M vendor/gtest/test/gtest_xml_output_unittest.py
M vendor/gtest/test/gtest_xml_output_unittest_.cc
M vendor/gtest/test/gtest_xml_test_utils.py
Log Message:
* update to gtest 1.10.0
* update gtest cmake
More information about the pdal-commits
