[pdal-commits] [PDAL/PDAL] e8b42c: Write more glTF attributes, including color and no...
Emma Krantz
noreply at github.com
Thu May 7 05:33:34 PDT 2020
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: e8b42c460baf6950051878034bb26edb85eaf0c7
https://github.com/PDAL/PDAL/commit/e8b42c460baf6950051878034bb26edb85eaf0c7
Author: Emma Krantz <3796838+KeyboardSounds at users.noreply.github.com>
Date: 2020-05-07 (Thu, 07 May 2020)
Changed paths:
M io/GltfWriter.cpp
M io/GltfWriter.hpp
M test/unit/CMakeLists.txt
A test/unit/io/GltfWriterTest.cpp
Log Message:
Write more glTF attributes, including color and normals (#3043)
* Write point normals when using writer.gltf
When writing out gltf files, the normals for each point are now included in the vertex attributes. Also includes new tests for GltfWriter.
* Write point colours with writer.gltf
- GltfWriter now writes out point colors as COLOR_0 vertex attributes
- Cleanup of GltfWriter code.
- Improvement to GltfWriterTest tests.
* No longer default to writing out colors to gltf
Changed the default for gltf writer not write colors out to file - sometimes "empty" but extant colour dimensions can be present and mess things up. Also, fixed issue with how test data was set up.
* Make tests compile.
* Fixed test build error introduced by merge
* Move gltf writer configuration to ::prepared
u_short -> uint16_t
* revert whitespace changes
* add missing constructor
* create multiple gltf primitives instead of one
Co-authored-by: Andrew Bell <andrew.bell.ia at gmail.com>
More information about the pdal-commits
