[pdal-commits] [PDAL/PDAL] 6a64e0: docker container uses	1.5-maintenance branch
    Howard Butler
    noreply at github.com
    Tue Sep  1 07:35:20 PDT 2020
  Branch: refs/heads/1.5-maintenance
  Home:   https://github.com/PDAL/PDAL
  Commit: 6a64e0b1033cbd8d5c1adda34133c8ee9a98839e
      https://github.com/PDAL/PDAL/commit/6a64e0b1033cbd8d5c1adda34133c8ee9a98839e
  Author: Howard Butler <howard at hobu.co>
  Date:   2017-04-06 (Thu, 06 Apr 2017)
  Changed paths:
    M scripts/docker/Dockerfile
  Log Message:
  Commit: 9eb947368bca5fc2e7222f6e6bacce363fe11ccf
      https://github.com/PDAL/PDAL/commit/9eb947368bca5fc2e7222f6e6bacce363fe11ccf
  Changed paths:
  Log Message:
  check out full branch for docker
  Commit: 4ed1a6c3b38cfc0b36a3e0cf28cc3f24c6bb853d
      https://github.com/PDAL/PDAL/commit/4ed1a6c3b38cfc0b36a3e0cf28cc3f24c6bb853d
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2017-04-17 (Mon, 17 Apr 2017)
  Changed paths:
    M doc/apps/translate.rst
    M doc/pipeline.rst
    M doc/stages/filters.outlier.rst
    M doc/stages/filters.pmf.rst
    M doc/workshop/exercises/analysis/denoising/denoise.json
    M doc/workshop/exercises/analysis/denoising/denoising.rst
    M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
    M doc/workshop/exercises/analysis/ground/ground.rst
    M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
  Log Message:
  Resolve some dangling references to deprecated extract and classify options
extract and classify have been used in several filters, namely outlier and PMF.
With the release of PDAL v1.5, we removed these options, opting to always
classify points, and to force users to ignore or extract them as they see fit
in their pipelines.
The outlier filter's extract option can be replicated by adding a range filter
stage as shown following the outlier filter:
      "type":"filters.range",
      "limits":"Classification![7:7]"
The PMF filter's extract option can be replicated by adding the following range
filter:
      "limits":"Classification[2:2]"
The intention here was to remove any ambiguity as to how individual filters
implement "extract", and to instead be explicit in the pipeline specification
as to how points are extracted.
  Commit: 341ece4cdd11f455b6152cc0e6be98e4984899b1
      https://github.com/PDAL/PDAL/commit/341ece4cdd11f455b6152cc0e6be98e4984899b1
  Author: Éric Lemoine <eric.lemoine at oslandia.com>
  Date:   2017-04-20 (Thu, 20 Apr 2017)
  Changed paths:
    M doc/development/testing.rst
  Log Message:
  Add note to docs about pgpointcloud tests
  Commit: 72f8e270a1f16857e8ea29886b0204957e94068f
      https://github.com/PDAL/PDAL/commit/72f8e270a1f16857e8ea29886b0204957e94068f
  Changed paths:
    M doc/pipeline.rst
  Log Message:
  Merge branch '1.5-maintenance' of github.com:PDAL/PDAL into 1.5-maintenance
  Commit: fb0dff5f7f98d34d9080176c0622adad40ad6ddb
      https://github.com/PDAL/PDAL/commit/fb0dff5f7f98d34d9080176c0622adad40ad6ddb
  Author: Éric Lemoine <eric.lemoine at gmail.com>
  Date:   2017-04-21 (Fri, 21 Apr 2017)
  Changed paths:
  Log Message:
  Fix formatting issues in testing.rst (#1574)
  Commit: c5ba883e4bd8c048bc46b807d9f2a22a83e6dd98
      https://github.com/PDAL/PDAL/commit/c5ba883e4bd8c048bc46b807d9f2a22a83e6dd98
  Changed paths:
    M filters/ClusterFilter.cpp
  Log Message:
  we need to count clusters from 1 instead of 0, because all other points will have 0 for their ClusterID (default value)
  Commit: 542cb17b16b7a714d5af025f173f601b56d39400
      https://github.com/PDAL/PDAL/commit/542cb17b16b7a714d5af025f173f601b56d39400
  Date:   2017-04-24 (Mon, 24 Apr 2017)
  Changed paths:
  Log Message:
  don't purge python-numpy in diet section
  Commit: ee9445b99501aef8152275ad01118b42346aebca
      https://github.com/PDAL/PDAL/commit/ee9445b99501aef8152275ad01118b42346aebca
  Date:   2017-04-25 (Tue, 25 Apr 2017)
  Changed paths:
  Log Message:
  more python numpy docker fixes
  Commit: 9ce6bbe6ce02f26a32e2957cd79b1cda9804f052
      https://github.com/PDAL/PDAL/commit/9ce6bbe6ce02f26a32e2957cd79b1cda9804f052
  Date:   2017-05-10 (Wed, 10 May 2017)
  Changed paths:
    M doc/stages/filters.programmable.rst
  Log Message:
  doc typpo
  Commit: 66f0a9be0dd012a275b25ac2bee7629be9895311
      https://github.com/PDAL/PDAL/commit/66f0a9be0dd012a275b25ac2bee7629be9895311
  Date:   2017-05-12 (Fri, 12 May 2017)
  Changed paths:
    M doc/tutorial/index.rst
    A doc/tutorial/python-filtering.rst
    M doc/workshop/includes/substitutions.rst
  Log Message:
  Python filtering tutorial
  Commit: 80f2f5136cd4c28e2d6985140368343bb21fe0f9
      https://github.com/PDAL/PDAL/commit/80f2f5136cd4c28e2d6985140368343bb21fe0f9
  Changed paths:
    M scripts/ci/script.sh
  Log Message:
  switch off java for now
  Commit: 9cfad839b32ba74afcc83badcba036deb4751b03
      https://github.com/PDAL/PDAL/commit/9cfad839b32ba74afcc83badcba036deb4751b03
  Date:   2017-05-19 (Fri, 19 May 2017)
  Changed paths:
    M doc/workshop/exercises/info/metadata-command.txt
    M doc/workshop/exercises/info/metadata.rst
    M doc/workshop/exercises/info/single-point-command.txt
    M doc/workshop/exercises/info/single-point.rst
    M doc/workshop/exercises/translation/compression-command-verify.txt
    M doc/workshop/exercises/translation/compression.rst
    M doc/workshop/exercises/translation/reprojection-command-1.txt
    M doc/workshop/images/compression-verify.png
    M doc/workshop/images/info-interesting-metadata.png
    M doc/workshop/images/info-interesting-single-point.png
    A doc/workshop/images/osgeo4w-advanced-selection.png
    A doc/workshop/images/osgeo4w-pdal-selection.png
    A doc/workshop/osgeo4w.rst
    M doc/workshop/qgis.rst
    M doc/workshop/software.rst
  Log Message:
  start refactoring workshop for windows
  Commit: f635a6f5fa6b28d7acb56ef6697f3e0c869b0614
      https://github.com/PDAL/PDAL/commit/f635a6f5fa6b28d7acb56ef6697f3e0c869b0614
  Changed paths:
    M doc/stages/filters.smrf.rst
    M doc/tutorial/las.rst
    M doc/workshop/exercises/analysis/boundary/boundary-command-boundary.txt
    M doc/workshop/exercises/analysis/boundary/boundary-command-tindex.txt
    M doc/workshop/exercises/analysis/boundary/boundary.rst
    M doc/workshop/exercises/analysis/clipping/clipping-run-command.txt
    M doc/workshop/exercises/analysis/clipping/clipping.json
    M doc/workshop/exercises/analysis/clipping/clipping.rst
    M doc/workshop/exercises/analysis/colorization/colorization-run-command.txt
    M doc/workshop/exercises/analysis/colorization/colorization.rst
    M doc/workshop/exercises/analysis/colorization/colorize.json
    M doc/workshop/exercises/analysis/denoising/denoising-run-command.txt
    M doc/workshop/exercises/analysis/density/density-command.txt
    M doc/workshop/exercises/analysis/density/density.rst
    A doc/workshop/exercises/analysis/dtm/dtm-hillshade-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm-run-command.txt
    M doc/workshop/exercises/analysis/dtm/dtm.rst
    M doc/workshop/exercises/analysis/dtm/gdal.json
    M doc/workshop/exercises/analysis/ground/ground-run-no-filter.txt
    M doc/workshop/exercises/analysis/thinning/thinning-run-dartsample.txt
    M doc/workshop/exercises/analysis/thinning/thinning.rst
    M doc/workshop/exercises/georeferencing/georeferencing-command.txt
    M doc/workshop/exercises/georeferencing/index.rst
    A doc/workshop/exercises/info/metadata-command-jq.txt
    M doc/workshop/exercises/info/near-command-1.txt
    M doc/workshop/exercises/info/near-command-2.txt
    M doc/workshop/exercises/info/near.rst
    M doc/workshop/exercises/translation/compression-command.txt
    M doc/workshop/exercises/translation/reprojection-command-2.txt
    M doc/workshop/exercises/translation/reprojection.rst
    M doc/workshop/images/boundary-text-output.png
    M doc/workshop/images/boundary-tindex-run.png
    M doc/workshop/images/clipping-run-command.png
    M doc/workshop/images/colorize-run-command.png
    M doc/workshop/images/denoise-run-command.png
    M doc/workshop/images/dtm-add-raster-layer.png
    M doc/workshop/images/dtm-add-raster-mean.png
    M doc/workshop/images/dtm-qgis-added.png
    M doc/workshop/images/dtm-qgis-classify.png
    M doc/workshop/images/dtm-qgis-colorize-dtm.png
    M doc/workshop/images/dtm-qgis-hillshade-done.png
    M doc/workshop/images/dtm-qgis-select-hillshade.png
    M doc/workshop/images/dtm-run-command.png
    M doc/workshop/images/georeferencing-run-command.png
    M doc/workshop/images/ground-classified-included-side.png
    M doc/workshop/images/ground-classified-included.png
    M doc/workshop/images/ground-filtered.png
    M doc/workshop/images/ground-ground-only-view.png
    M doc/workshop/images/ground-run-command.png
    A doc/workshop/images/info-interesting-metadata-jq.png
    M doc/workshop/images/info-near-bbox.png
    M doc/workshop/images/info-near-point.png
    A doc/workshop/images/reprojection-first-point.png
    M doc/workshop/images/reprojection-proper-scale.png
    M doc/workshop/images/reprojection-run-command.png
    M doc/workshop/images/reprojection-run-with-scale.png
    M doc/workshop/images/reprojection-wrong-scale.png
    M doc/workshop/images/thinning-command-run.png
  Log Message:
  refactor workshop for OSGeo4W
  Commit: 1844c16979ce0e369fcc4d891a2f728c235df00c
      https://github.com/PDAL/PDAL/commit/1844c16979ce0e369fcc4d891a2f728c235df00c
  Changed paths:
  Log Message:
  doc bug
  Commit: e127d079615042f1e97748f8c7034e17b8bf728d
      https://github.com/PDAL/PDAL/commit/e127d079615042f1e97748f8c7034e17b8bf728d
  Changed paths:
    M CMakeLists.txt
  Log Message:
  allow PDAL_PLUGIN_INSTALL_PATH override at configure time
  Commit: fb3179dba314a3a9525b6bd6784b3fe388eb8592
      https://github.com/PDAL/PDAL/commit/fb3179dba314a3a9525b6bd6784b3fe388eb8592
  Changed paths:
    M doc/download.rst
  Log Message:
  point to osgeo4w for windows download
  Commit: 66c848a960c39e6a4105329a49d53d9b9428ab61
      https://github.com/PDAL/PDAL/commit/66c848a960c39e6a4105329a49d53d9b9428ab61
  Changed paths:
    M plugins/hexbin/kernel/OGR.cpp
  Log Message:
  OGR layer owns feature, don't destroy
  Commit: 82c5aa7513d4ee4738bb831ae0e03ff707d226ca
      https://github.com/PDAL/PDAL/commit/82c5aa7513d4ee4738bb831ae0e03ff707d226ca
  Date:   2017-05-21 (Sun, 21 May 2017)
  Changed paths:
    M doc/workshop/images/density-command-run.png
  Log Message:
  workshop image
  Commit: a6a2b7c6b21d9b4c0b48136cee5ce7b26fb24618
      https://github.com/PDAL/PDAL/commit/a6a2b7c6b21d9b4c0b48136cee5ce7b26fb24618
  Date:   2017-05-31 (Wed, 31 May 2017)
  Changed paths:
    M doc/workshop/exercises/index.rst
    A doc/workshop/exercises/python/histogram-command.txt
    A doc/workshop/exercises/python/histogram.json
    A doc/workshop/exercises/python/histogram.py
    A doc/workshop/exercises/python/histogram.rst
    A doc/workshop/images/python-histogram-command.png
    A doc/workshop/images/python-histogram.png
    M doc/workshop/index.rst
  Log Message:
  add histogram plotting workshop exercise
  Commit: cb82e645b87a865bdd07458471722c76b404a6b7
      https://github.com/PDAL/PDAL/commit/cb82e645b87a865bdd07458471722c76b404a6b7
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-06-06 (Tue, 06 Jun 2017)
  Changed paths:
    M io/LasWriter.cpp
  Log Message:
  Initialize global encoding.
  Commit: 7810115e69d6155a15191dc8efb5516f4ebafb2f
      https://github.com/PDAL/PDAL/commit/7810115e69d6155a15191dc8efb5516f4ebafb2f
  Date:   2017-06-19 (Mon, 19 Jun 2017)
  Changed paths:
    M doc/stages/readers.faux.rst
  Log Message:
  Fix #1607
  Commit: f5f5c3226d6ef999278355c431d3b7187579fab5
      https://github.com/PDAL/PDAL/commit/f5f5c3226d6ef999278355c431d3b7187579fab5
  Date:   2017-06-20 (Tue, 20 Jun 2017)
  Changed paths:
    M kernels/GroundKernel.cpp
    M kernels/GroundKernel.hpp
  Log Message:
  Adapt ground kernel to pmf filter changes
* Classify option is no longer needed, PMF always classifies points
* Extract option is retained, but is now implemented by adding a range filter
  Commit: 580239cdd2b7b7c7a7e94f11884a1475cb73f04c
      https://github.com/PDAL/PDAL/commit/580239cdd2b7b7c7a7e94f11884a1475cb73f04c
  Date:   2017-06-27 (Tue, 27 Jun 2017)
  Changed paths:
    M pdal/EigenUtils.cpp
  Log Message:
  Should be computing sample covariance
  Commit: 6cb85102cfb19ca941ec8b04fa89a88c084e5278
      https://github.com/PDAL/PDAL/commit/6cb85102cfb19ca941ec8b04fa89a88c084e5278
  Date:   2017-07-21 (Fri, 21 Jul 2017)
  Changed paths:
    M doc/workshop/agenda.rst
    A doc/workshop/capstone.rst
    A doc/workshop/conf.py
    M doc/workshop/exercises/analysis/clipping/attributes.vrt
    M doc/workshop/exercises/python/histogram.rst
    A doc/workshop/exercises/translation/greyhound-command.txt
    A doc/workshop/exercises/translation/greyhound-info-command.txt
    A doc/workshop/exercises/translation/greyhound.json
    A doc/workshop/exercises/translation/greyhound.rst
    M doc/workshop/images/agenda-usb-drive.jpg
    A doc/workshop/images/greyhound-command.png
    A doc/workshop/images/greyhound-view.png
    A doc/workshop/notes.rst
    M doc/workshop/slides/source/basic_info.rst
    M doc/workshop/slides/source/boundary.rst
    M doc/workshop/slides/source/clipping.rst
    M doc/workshop/slides/source/colorization.rst
    M doc/workshop/slides/source/conf.py
    M doc/workshop/slides/source/denoising.rst
    M doc/workshop/slides/source/density.rst
    M doc/workshop/slides/source/dtm.rst
    M doc/workshop/slides/source/ground.rst
    A doc/workshop/slides/source/img/osgeo4w-shell.png
    M doc/workshop/slides/source/introduction.rst
    M doc/workshop/slides/source/lidar_intro.rst
    M doc/workshop/slides/source/pdal_intro.rst
    M doc/workshop/slides/source/software.rst
    M doc/workshop/slides/source/thinning.rst
    M doc/workshop/slides/source/translation.rst
  Log Message:
  workshop updates in preparation for July 25th, 2017 presentation
  Commit: efdd2402c9e345ab549a3850300c4e737a7264db
      https://github.com/PDAL/PDAL/commit/efdd2402c9e345ab549a3850300c4e737a7264db
  Date:   2017-08-11 (Fri, 11 Aug 2017)
  Changed paths:
    M doc/stages/readers.las.rst
    M doc/stages/readers.oci.rst
    M doc/stages/readers.pgpointcloud.rst
    M pdal/Stage.cpp
  Log Message:
  Update doc for spatialreference option.
  Commit: e233c279f4ec43759379ab60a6a88a5688828206
      https://github.com/PDAL/PDAL/commit/e233c279f4ec43759379ab60a6a88a5688828206
  Changed paths:
  Log Message:
  Fix option names in doc.
  Commit: b7f17a425a97245f05307f752b37986620fee41e
      https://github.com/PDAL/PDAL/commit/b7f17a425a97245f05307f752b37986620fee41e
  Changed paths:
    M doc/stages/readers.text.rst
  Log Message:
  Doc for separator option in readers.text.
Close #1630
  Commit: bfa370c466b0c52520d6777154c222d53f74b41b
      https://github.com/PDAL/PDAL/commit/bfa370c466b0c52520d6777154c222d53f74b41b
  Changed paths:
    M doc/stages/filters.crop.rst
    M filters/CropFilter.cpp
  Log Message:
  Add documentation for a_srs and a warning if it's not used when necessary.
  Commit: 1be4c12173cd06a78073f563e52766b135aa39fe
      https://github.com/PDAL/PDAL/commit/1be4c12173cd06a78073f563e52766b135aa39fe
  Date:   2017-08-24 (Thu, 24 Aug 2017)
  Changed paths:
    M doc/faq.rst
  Log Message:
  Add an FAQ about missing plugins.
  Commit: b561d3ec527486347189d219b6e0f16bb15918a7
      https://github.com/PDAL/PDAL/commit/b561d3ec527486347189d219b6e0f16bb15918a7
  Changed paths:
    M doc/faq.rst
  Log Message:
  Fix a typo.
  Commit: 843751bb30a8221ffd5af9ce179e7ccd46d3f620
      https://github.com/PDAL/PDAL/commit/843751bb30a8221ffd5af9ce179e7ccd46d3f620
  Date:   2017-08-25 (Fri, 25 Aug 2017)
  Changed paths:
    M io/LasWriter.cpp
  Log Message:
  don't attempt to write a pdal_metadata VLR if > LasVLR::MAX_DATA_SIZE and minor_version < 4
  Commit: 3dcb91711b93174e5428ebbd833a6d575870f99c
      https://github.com/PDAL/PDAL/commit/3dcb91711b93174e5428ebbd833a6d575870f99c
  Date:   2017-08-28 (Mon, 28 Aug 2017)
  Changed paths:
    M io/LasReader.cpp
    M test/unit/io/LasReaderTest.cpp
  Log Message:
  Put encoded LAS VLR in its own node.
Close #1648
  Commit: 739ea6f99d5811dbf242bd1d2455b499640b10a9
      https://github.com/PDAL/PDAL/commit/739ea6f99d5811dbf242bd1d2455b499640b10a9
  Changed paths:
    M doc/faq.rst
    M io/LasWriter.cpp
  Log Message:
  Merge remote-tracking branch 'origin/1.5-maintenance' into 1.5-maintenance
  Commit: 424c251270ac3cedc19d9276a6e09cce375d32ea
      https://github.com/PDAL/PDAL/commit/424c251270ac3cedc19d9276a6e09cce375d32ea
  Date:   2017-08-29 (Tue, 29 Aug 2017)
  Changed paths:
    M io/LasWriter.cpp
  Log Message:
  LasVLR::MAX_DATA_SIZE is never used, use USHRT_MAX for VLR size test
Compare: https://github.com/PDAL/PDAL/compare/6a64e0b1033c%5E...424c251270ac
More information about the pdal-commits
