[pdal-commits] [PDAL/PDAL] 6140ea: Set Accept-Encoding header.
Andrew Bell
noreply at github.com
Mon Apr 12 06:31:36 PDT 2021
Branch: refs/heads/issue-3233
Home: https://github.com/PDAL/PDAL
Commit: 6140ea3a6d0d9b20bbcd64c22ff893dce0091a2e
https://github.com/PDAL/PDAL/commit/6140ea3a6d0d9b20bbcd64c22ff893dce0091a2e
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2021-04-05 (Mon, 05 Apr 2021)
Changed paths:
M vendor/arbiter/arbiter.cpp
Log Message:
Commit: a00819d42cfd1ecd7ab85c6d77ec277fa278aac9
https://github.com/PDAL/PDAL/commit/a00819d42cfd1ecd7ab85c6d77ec277fa278aac9
Author: Howard Butler <howard at hobu.co>
Date: 2021-04-07 (Wed, 07 Apr 2021)
Changed paths:
M scripts/ci/linux/setup.sh
M scripts/ci/osx/setup.sh
M scripts/ci/win/setup.sh
Log Message:
Get CI healthy(er)
Commit: 07a94dfbef1e5f94d73a9b6a9ac9955c00c9c2cc
https://github.com/PDAL/PDAL/commit/07a94dfbef1e5f94d73a9b6a9ac9955c00c9c2cc
Date: 2021-04-09 (Fri, 09 Apr 2021)
Changed paths:
M pdal/compression/DeflateCompression.cpp
A pdal/compression/GzipCompression.hpp
M plugins/i3s/CMakeLists.txt
M plugins/i3s/io/SlpkReader.cpp
M plugins/i3s/io/SlpkReader.hpp
M vendor/arbiter/arbiter.hpp
Log Message:
Remove unused gzip from arbiter (#3412)
* Remove gzip decoding from arbiter.
Add gzip decompression.
Fix SLPK to use PDAL decompression rather than arbiter decompression.
* Missed file.
Commit: 608d3d34c917d1812d3f4e0e87c026a143d6e2d2
https://github.com/PDAL/PDAL/commit/608d3d34c917d1812d3f4e0e87c026a143d6e2d2
Changed paths:
M io/private/ept/EptInfo.cpp
M io/private/ept/TileContents.hpp
Log Message:
Fix names of dimensions received from ept.json. (#3404)
Commit: 2f1bfc35f3874529cfc594e1c1b18a2f8358985c
https://github.com/PDAL/PDAL/commit/2f1bfc35f3874529cfc594e1c1b18a2f8358985c
Changed paths:
M io/LasWriter.cpp
A test/data/text/largescan.txt
M test/unit/io/LasWriterTest.cpp
Log Message:
Don't set scan_angle when writing point formats 6 or greater. (#3405)
Commit: bfff41439c30dd27130927f30df3041490f44c80
https://github.com/PDAL/PDAL/commit/bfff41439c30dd27130927f30df3041490f44c80
Changed paths:
M io/LasHeader.cpp
M io/LasHeader.hpp
Log Message:
Allow 1.4 LAS to use geotiff for PDRF 0-5 (#3406)
* Don't use file version for determining geotiff/wkt.
* Allow geotiff in 1.4 files with dataformat 0-5 if the WKT bit is set.
Close #3242
Commit: ea0dc4b09391faf85b2b64b054ef9b4691d07c2c
https://github.com/PDAL/PDAL/commit/ea0dc4b09391faf85b2b64b054ef9b4691d07c2c
Changed paths:
M io/LasWriter.cpp
Log Message:
If there are no extended VLRs, set the offset to 0 (#3407)
* Don't try to test ext VLR position for zipped file.
Close #3348
* Set the VLR offsets to 0 if there are no offsets.
* VLR Offset is really header size.
Commit: f447247ad56d1c4da9e1701b29186c87049e3993
https://github.com/PDAL/PDAL/commit/f447247ad56d1c4da9e1701b29186c87049e3993
Changed paths:
A doc/stages/filters.zsmooth.rst
A filters/ZsmoothFilter.cpp
A filters/ZsmoothFilter.hpp
Log Message:
Add zsmooth filter (#3408)
* Add Zsmooth filter.
* Fix bad comment.
* Improve doc.
Commit: 8a82a01fd739d1fd5a22923d4ff2c5212df96182
https://github.com/PDAL/PDAL/commit/8a82a01fd739d1fd5a22923d4ff2c5212df96182
Date: 2021-04-11 (Sun, 11 Apr 2021)
Changed paths:
M CMakeLists.txt
M cmake/draco.cmake
M plugins/draco/CMakeLists.txt
M scripts/ci/linux/cmake.sh
M scripts/ci/osx/cmake.sh
M scripts/ci/win/cmake.sh
M scripts/conda/osx.sh
Log Message:
use pkgconfig to support draco 1.4.0+ (only) (#3413)
* use pkgconfig to support draco 1.4.0+ (only)
* Draco is opt-in, not opt-out
* osx build config
* use draco cmake config
* remove WITH_DRACO
* BUILD_PLUGIN_DRACO needed to build Draco support
* search lib64/pkgconfig for draco
* link to DRACO_LIBRARIES
* pkgconfig for win
* pkgconfig for win
* draco test linkage
Commit: 6cc3e958f3dfe37012df3d0789800f74e2fddaa4
https://github.com/PDAL/PDAL/commit/6cc3e958f3dfe37012df3d0789800f74e2fddaa4
Date: 2021-04-12 (Mon, 12 Apr 2021)
Changed paths:
M doc/stages/filters.cluster.rst
Log Message:
Add general filter options to cluster doc.
Commit: f9a97b898d1223a6ede7b28f882f3fa3d2e2fbc8
https://github.com/PDAL/PDAL/commit/f9a97b898d1223a6ede7b28f882f3fa3d2e2fbc8
Changed paths:
M CMakeLists.txt
M cmake/draco.cmake
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasWriter.cpp
Log Message:
Merge branch 'master' into issue-3233
Compare: https://github.com/PDAL/PDAL/compare/6ee70ba135de...f9a97b898d12
More information about the pdal-commits
