[pdal-commits] [PDAL/PDAL] fdee1a: Docker tweak for CONDA_PREFIX install (#3401)
Andrew Bell
noreply at github.com
Wed Apr 14 07:55:19 PDT 2021
Branch: refs/heads/lazperf
Home: https://github.com/PDAL/PDAL
Commit: fdee1a5fc3ebfdfd931a56c031832a6fc153ec90
https://github.com/PDAL/PDAL/commit/fdee1a5fc3ebfdfd931a56c031832a6fc153ec90
Author: Howard Butler <howard at hobu.co>
Date: 2021-04-02 (Fri, 02 Apr 2021)
Changed paths:
M scripts/docker/ubuntu/Dockerfile
Log Message:
* Fix up docker configuration issues #3375
* updates
* install PDAL into CONDA_PREFIX
Commit: ea0ff391723d9920ab768f7e461fab709909e1e9
https://github.com/PDAL/PDAL/commit/ea0ff391723d9920ab768f7e461fab709909e1e9
Date: 2021-04-03 (Sat, 03 Apr 2021)
Changed paths:
M doc/tutorial/iowa.json
Log Message:
fix iowa tutorial
Commit: db3e98b7f2443a2be746bd1041ecbc30b7244595
https://github.com/PDAL/PDAL/commit/db3e98b7f2443a2be746bd1041ecbc30b7244595
Changed paths:
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Commit: 6140ea3a6d0d9b20bbcd64c22ff893dce0091a2e
https://github.com/PDAL/PDAL/commit/6140ea3a6d0d9b20bbcd64c22ff893dce0091a2e
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2021-04-05 (Mon, 05 Apr 2021)
Changed paths:
M vendor/arbiter/arbiter.cpp
Log Message:
Set Accept-Encoding header.
Commit: a00819d42cfd1ecd7ab85c6d77ec277fa278aac9
https://github.com/PDAL/PDAL/commit/a00819d42cfd1ecd7ab85c6d77ec277fa278aac9
Date: 2021-04-07 (Wed, 07 Apr 2021)
Changed paths:
M scripts/ci/linux/setup.sh
M scripts/ci/osx/setup.sh
M scripts/ci/win/setup.sh
Log Message:
Get CI healthy(er)
Commit: 07a94dfbef1e5f94d73a9b6a9ac9955c00c9c2cc
https://github.com/PDAL/PDAL/commit/07a94dfbef1e5f94d73a9b6a9ac9955c00c9c2cc
Date: 2021-04-09 (Fri, 09 Apr 2021)
Changed paths:
M pdal/compression/DeflateCompression.cpp
A pdal/compression/GzipCompression.hpp
M plugins/i3s/CMakeLists.txt
M plugins/i3s/io/SlpkReader.cpp
M plugins/i3s/io/SlpkReader.hpp
M vendor/arbiter/arbiter.hpp
Log Message:
Remove unused gzip from arbiter (#3412)
* Remove gzip decoding from arbiter.
Add gzip decompression.
Fix SLPK to use PDAL decompression rather than arbiter decompression.
* Missed file.
Commit: 608d3d34c917d1812d3f4e0e87c026a143d6e2d2
https://github.com/PDAL/PDAL/commit/608d3d34c917d1812d3f4e0e87c026a143d6e2d2
Changed paths:
M io/private/ept/EptInfo.cpp
M io/private/ept/TileContents.hpp
Log Message:
Fix names of dimensions received from ept.json. (#3404)
Commit: 2f1bfc35f3874529cfc594e1c1b18a2f8358985c
https://github.com/PDAL/PDAL/commit/2f1bfc35f3874529cfc594e1c1b18a2f8358985c
Changed paths:
M io/LasWriter.cpp
A test/data/text/largescan.txt
M test/unit/io/LasWriterTest.cpp
Log Message:
Don't set scan_angle when writing point formats 6 or greater. (#3405)
Commit: bfff41439c30dd27130927f30df3041490f44c80
https://github.com/PDAL/PDAL/commit/bfff41439c30dd27130927f30df3041490f44c80
Changed paths:
M io/LasHeader.cpp
M io/LasHeader.hpp
Log Message:
Allow 1.4 LAS to use geotiff for PDRF 0-5 (#3406)
* Don't use file version for determining geotiff/wkt.
* Allow geotiff in 1.4 files with dataformat 0-5 if the WKT bit is set.
Close #3242
Commit: ea0dc4b09391faf85b2b64b054ef9b4691d07c2c
https://github.com/PDAL/PDAL/commit/ea0dc4b09391faf85b2b64b054ef9b4691d07c2c
Changed paths:
M io/LasWriter.cpp
Log Message:
If there are no extended VLRs, set the offset to 0 (#3407)
* Don't try to test ext VLR position for zipped file.
Close #3348
* Set the VLR offsets to 0 if there are no offsets.
* VLR Offset is really header size.
Commit: f447247ad56d1c4da9e1701b29186c87049e3993
https://github.com/PDAL/PDAL/commit/f447247ad56d1c4da9e1701b29186c87049e3993
Changed paths:
A doc/stages/filters.zsmooth.rst
A filters/ZsmoothFilter.cpp
A filters/ZsmoothFilter.hpp
Log Message:
Add zsmooth filter (#3408)
* Add Zsmooth filter.
* Fix bad comment.
* Improve doc.
Commit: 8a82a01fd739d1fd5a22923d4ff2c5212df96182
https://github.com/PDAL/PDAL/commit/8a82a01fd739d1fd5a22923d4ff2c5212df96182
Date: 2021-04-11 (Sun, 11 Apr 2021)
Changed paths:
M CMakeLists.txt
M cmake/draco.cmake
M plugins/draco/CMakeLists.txt
M scripts/ci/linux/cmake.sh
M scripts/ci/osx/cmake.sh
M scripts/ci/win/cmake.sh
M scripts/conda/osx.sh
Log Message:
use pkgconfig to support draco 1.4.0+ (only) (#3413)
* use pkgconfig to support draco 1.4.0+ (only)
* Draco is opt-in, not opt-out
* osx build config
* use draco cmake config
* remove WITH_DRACO
* BUILD_PLUGIN_DRACO needed to build Draco support
* search lib64/pkgconfig for draco
* link to DRACO_LIBRARIES
* pkgconfig for win
* pkgconfig for win
* draco test linkage
Commit: 6cc3e958f3dfe37012df3d0789800f74e2fddaa4
https://github.com/PDAL/PDAL/commit/6cc3e958f3dfe37012df3d0789800f74e2fddaa4
Date: 2021-04-12 (Mon, 12 Apr 2021)
Changed paths:
M doc/stages/filters.cluster.rst
Log Message:
Add general filter options to cluster doc.
Commit: dd588c94e0af58671f3dcbfed8047a9d74f6bb7d
https://github.com/PDAL/PDAL/commit/dd588c94e0af58671f3dcbfed8047a9d74f6bb7d
Changed paths:
M pdal/util/Utils.cpp
M test/unit/UtilsTest.cpp
Log Message:
Minor base64 decode cleanup. (#3414)
Commit: 77b8f4bb2dd78a9b958d1353838209cf11bf98fe
https://github.com/PDAL/PDAL/commit/77b8f4bb2dd78a9b958d1353838209cf11bf98fe
Changed paths:
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasWriter.cpp
Log Message:
Better error messages for case where point format is not allowed. (#3417)
Commit: df23c23cb75d5cfb8b210f22b7c5ddb0fe4accbd
https://github.com/PDAL/PDAL/commit/df23c23cb75d5cfb8b210f22b7c5ddb0fe4accbd
Changed paths:
M pdal/Options.hpp
M test/unit/OptionsTest.cpp
Log Message:
Transit doubles through Option with 15 places of precision. (#3415)
Commit: b70566b947adeb0d25196708dc7aba56652932a9
https://github.com/PDAL/PDAL/commit/b70566b947adeb0d25196708dc7aba56652932a9
Changed paths:
M io/LasReader.cpp
M io/LasUtils.cpp
M io/LasUtils.hpp
M test/unit/io/LasReaderTest.cpp
Log Message:
Make sure the extra dimension spec doesn't exceed the point size. (#3418)
Commit: c33f0c446f82694ee9ec9b551d840bf3729e078c
https://github.com/PDAL/PDAL/commit/c33f0c446f82694ee9ec9b551d840bf3729e078c
Changed paths:
M filters/GpsTimeConvert.cpp
M filters/GpsTimeConvert.hpp
Log Message:
Don't take a double when we can't use it.
Commit: 39bdc2f4cc4733ccae4219785a17737c73c8d335
https://github.com/PDAL/PDAL/commit/39bdc2f4cc4733ccae4219785a17737c73c8d335
Changed paths:
M filters/StatsFilter.cpp
Log Message:
Eliminate precision-loss warnings.
Commit: 3fef250d69fa2f7811e8e220e07373067ddce7fd
https://github.com/PDAL/PDAL/commit/3fef250d69fa2f7811e8e220e07373067ddce7fd
Changed paths:
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasReader.cpp
M io/LasUtils.cpp
M io/LasUtils.hpp
M io/LasWriter.cpp
M pdal/Options.hpp
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: 36de7dd07ea06fafa1be47d9779f60b90d778b44
https://github.com/PDAL/PDAL/commit/36de7dd07ea06fafa1be47d9779f60b90d778b44
Changed paths:
M filters/ZsmoothFilter.cpp
Log Message:
Eliminate warning on Windows.
Commit: ae289d744738f0e05a616c3db789df325bb97bc3
https://github.com/PDAL/PDAL/commit/ae289d744738f0e05a616c3db789df325bb97bc3
Changed paths:
M io/BpfWriter.cpp
M io/SbetReader.cpp
M pdal/util/FileUtils.cpp
Log Message:
Handle fileSize() failures where appropriate. (#3421)
Commit: 3ddb88292269d31602ac44032f2e0859c5d838da
https://github.com/PDAL/PDAL/commit/3ddb88292269d31602ac44032f2e0859c5d838da
Changed paths:
M io/LasWriter.cpp
Log Message:
Update LAS driver description. (#3420)
Close #3403
Commit: 3ded270b5aaeff4a0d30bd399728c8df844073b3
https://github.com/PDAL/PDAL/commit/3ded270b5aaeff4a0d30bd399728c8df844073b3
Changed paths:
M kernels/PipelineKernel.cpp
M pdal/PipelineManager.cpp
M pdal/PipelineManager.hpp
A test/data/pipeline/filter-only.json.in
M test/data/pipeline/issue2937.json.in
M test/unit/apps/pcpipelineTestJSON.cpp
Log Message:
Detect filter-only pipeline. (#3419)
* Make sure when we run a pipeline without a reader.
* Add missed test file.
* Add input file to satisfy new pipeline requirement.
Commit: 99bdf0efa4978c0eed5c1e4ab6616ad64d59013a
https://github.com/PDAL/PDAL/commit/99bdf0efa4978c0eed5c1e4ab6616ad64d59013a
Changed paths:
M doc/stages/writer_opts.rst
M doc/stages/writers.draco.rst
M doc/stages/writers.raster.rst
M pdal/Filter.cpp
M pdal/Filter.hpp
M pdal/Reader.cpp
M pdal/Reader.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
M pdal/Streamable.cpp
M pdal/Writer.cpp
M pdal/Writer.hpp
M pdal/private/StageRunner.cpp
M test/unit/WhereTest.cpp
Log Message:
Add where support to writers (#3416)
* Extend where syntax to writers.
* Doc update.
* Change "filter" to "writer".
* Fix logic.
Commit: 0b3e02fdb2df7737afaf5b0e3ab6c33fa092d37e
https://github.com/PDAL/PDAL/commit/0b3e02fdb2df7737afaf5b0e3ab6c33fa092d37e
Date: 2021-04-14 (Wed, 14 Apr 2021)
Changed paths:
M CMakeLists.txt
M cmake/draco.cmake
M io/BpfWriter.cpp
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasReader.cpp
M io/LasUtils.cpp
M io/LasUtils.hpp
M io/LasWriter.cpp
M io/SbetReader.cpp
M pdal/Filter.cpp
M pdal/Filter.hpp
M pdal/Options.hpp
M pdal/Reader.cpp
M pdal/Reader.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
M pdal/Writer.cpp
M pdal/Writer.hpp
Log Message:
Merge remote-tracking branch 'origin' into lazperf
Compare: https://github.com/PDAL/PDAL/compare/0bf884ff2131...0b3e02fdb2df
More information about the pdal-commits
