[pdal-commits] [PDAL/PDAL] ae289d: Handle fileSize() failures where appropriate. (#3421)
Andrew Bell noreply at github.com
Thu Apr 22 10:58:21 PDT 2021
  Branch: refs/heads/issue-3422
  Home:   https://github.com/PDAL/PDAL
  Commit: ae289d744738f0e05a616c3db789df325bb97bc3
      https://github.com/PDAL/PDAL/commit/ae289d744738f0e05a616c3db789df325bb97bc3
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2021-04-12 (Mon, 12 Apr 2021)
  Changed paths:
    M io/BpfWriter.cpp
    M io/SbetReader.cpp
    M pdal/util/FileUtils.cpp
    M plugins/i3s/io/SlpkReader.cpp
  Log Message:
  Commit: 3ddb88292269d31602ac44032f2e0859c5d838da
      https://github.com/PDAL/PDAL/commit/3ddb88292269d31602ac44032f2e0859c5d838da
  Changed paths:
    M io/LasWriter.cpp
  Log Message:
  Update LAS driver description. (#3420)
Close #3403
  Commit: 3ded270b5aaeff4a0d30bd399728c8df844073b3
      https://github.com/PDAL/PDAL/commit/3ded270b5aaeff4a0d30bd399728c8df844073b3
  Changed paths:
    M kernels/PipelineKernel.cpp
    M pdal/PipelineManager.cpp
    M pdal/PipelineManager.hpp
    A test/data/pipeline/filter-only.json.in
    M test/data/pipeline/issue2937.json.in
    M test/unit/apps/pcpipelineTestJSON.cpp
  Log Message:
  Detect filter-only pipeline. (#3419)
* Make sure when we run a pipeline without a reader.
* Add missed test file.
* Add input file to satisfy new pipeline requirement.
  Commit: 99bdf0efa4978c0eed5c1e4ab6616ad64d59013a
      https://github.com/PDAL/PDAL/commit/99bdf0efa4978c0eed5c1e4ab6616ad64d59013a
  Changed paths:
    M doc/stages/writer_opts.rst
    M doc/stages/writers.draco.rst
    M doc/stages/writers.raster.rst
    M pdal/Filter.cpp
    M pdal/Filter.hpp
    M pdal/Reader.cpp
    M pdal/Reader.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/Streamable.cpp
    M pdal/Writer.cpp
    M pdal/Writer.hpp
    M pdal/private/StageRunner.cpp
    M test/unit/WhereTest.cpp
  Log Message:
  Add where support to writers (#3416)
* Extend where syntax to writers.
* Doc update.
* Change "filter" to "writer".
* Fix logic.
  Commit: f802f396bbed4f2a29217f3ef5e1b9ae41fbc481
      https://github.com/PDAL/PDAL/commit/f802f396bbed4f2a29217f3ef5e1b9ae41fbc481
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2021-04-16 (Fri, 16 Apr 2021)
  Changed paths:
    M kernels/HausdorffKernel.cpp
    M pdal/PDALUtils.cpp
    M pdal/PDALUtils.hpp
    M test/unit/apps/HausdorffTest.cpp
  Log Message:
  Refactor Hausdorff kernel and add modified Hausdorff metric as one of the outputs (#3361)
* Refactor Hausdorff kernel and add modified Hausdorff metric as one of
the outputs
* Address PR comments, retain original computeHausdorff utility
  Commit: 297a7c07363143a001bb2fe0f9f26f430b9ace25
      https://github.com/PDAL/PDAL/commit/297a7c07363143a001bb2fe0f9f26f430b9ace25
  Date:   2021-04-20 (Tue, 20 Apr 2021)
  Changed paths:
    M doc/apps/chamfer.rst
    A doc/apps/eval.rst
    M doc/apps/hausdorff.rst
    A kernels/EvalKernel.cpp
    A kernels/EvalKernel.hpp
  Log Message:
  Add EvalKernel (#3346)
* Add EvalKernel
Adds pdal application/subcommand to print a classification report when
given two input point clouds, one with predicted labels, another with
truth.
Contains a minor edit in Chamfer and Hausdorff kernel documentation,
where positional arguments were described as non-positional.
* Address PR comments, provide ability to specify truth/prediction label
dimensions
* Addressing more PR comments about docs
  Commit: 4168534c25246b421fbf64f5a25424508fe0ea0d
      https://github.com/PDAL/PDAL/commit/4168534c25246b421fbf64f5a25424508fe0ea0d
  Date:   2021-04-22 (Thu, 22 Apr 2021)
  Changed paths:
    A doc/apps/eval.rst
    M io/BpfWriter.cpp
    M io/LasWriter.cpp
    M io/SbetReader.cpp
    M pdal/Filter.cpp
    M pdal/Filter.hpp
    M pdal/Reader.cpp
    M pdal/Reader.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/Writer.cpp
    M pdal/Writer.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-3422
  Commit: 94567b2fef8a760ffd29365d320c3e07546a9f2b
      https://github.com/PDAL/PDAL/commit/94567b2fef8a760ffd29365d320c3e07546a9f2b
  Changed paths:
    M pdal/util/Random.cpp
  Log Message:
  Easy random number seeding.
Compare: https://github.com/PDAL/PDAL/compare/2ef68be9b4cd...94567b2fef8a
More information about the pdal-commits mailing list
