[pdal-commits] [PDAL/PDAL] b4d069: Eliminate some WKT round trips and use WKT2 (#3427)
Andrew Bell
noreply at github.com
Fri Apr 23 05:21:30 PDT 2021
Branch: refs/heads/issue-3282
Home: https://github.com/PDAL/PDAL
Commit: b4d069276080517811b856492c301fae491bca9b
https://github.com/PDAL/PDAL/commit/b4d069276080517811b856492c301fae491bca9b
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2021-04-22 (Thu, 22 Apr 2021)
Changed paths:
M cmake/gdal.cmake
M filters/CropFilter.cpp
M pdal/Geometry.cpp
M pdal/private/SrsTransform.cpp
M pdal/private/SrsTransform.hpp
M pdal/private/gdal/GDALUtils.cpp
Log Message:
* Eliminate some WKT round trips and use WKT2
* Change WKT format to WKT2
* Force GDAL to version 3+
Commit: aefb669e0e0a5f0e8f4156c322e47a786ea1c8b0
https://github.com/PDAL/PDAL/commit/aefb669e0e0a5f0e8f4156c322e47a786ea1c8b0
Author: Guilhem Villemin <guilhem.villemin at gmail.com>
Changed paths:
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
Log Message:
Fix arbiter azure driver (#3426)
* upstream arbiter
* restore unwanted change to google driver
Commit: af55ff49fb618e672b150f7771fd590414d234f1
https://github.com/PDAL/PDAL/commit/af55ff49fb618e672b150f7771fd590414d234f1
Changed paths:
M pdal/util/CMakeLists.txt
A pdal/util/Random.cpp
A pdal/util/Random.hpp
Log Message:
Make random number seeding easy (#3430)
* Random stuff.
* Easy random number seeding.
Commit: 52527d5282b74e700f356c9f0c395d43625691a7
https://github.com/PDAL/PDAL/commit/52527d5282b74e700f356c9f0c395d43625691a7
Changed paths:
M doc/stages/readers.mrsid.rst
M plugins/mrsid/io/MrsidReader.cpp
Log Message:
Deprecate the MrSid reader. (#3429)
Commit: a568db4751c17574b6f3d198d44b6a1896a690ab
https://github.com/PDAL/PDAL/commit/a568db4751c17574b6f3d198d44b6a1896a690ab
Date: 2021-04-23 (Fri, 23 Apr 2021)
Changed paths:
M pdal/util/Random.hpp
M test/unit/SpatialReferenceTest.cpp
M test/unit/Support.cpp
M test/unit/Support.hpp
M test/unit/apps/AppPluginTest.cpp
M test/unit/apps/AppTest.cpp
M test/unit/apps/pcpipelineTestJSON.cpp
Log Message:
Test support update (#3432)
* Test support update
* Don't use uniform_int_distribution<char-type>.
* Export functions.
Commit: c12dd4e5a43869ce4aebddda4dbbb8cd2b854465
https://github.com/PDAL/PDAL/commit/c12dd4e5a43869ce4aebddda4dbbb8cd2b854465
Changed paths:
M cmake/gdal.cmake
M pdal/Geometry.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-3282
Commit: df66a063341fca3a5c725c18d5d4d211375bb76d
https://github.com/PDAL/PDAL/commit/df66a063341fca3a5c725c18d5d4d211375bb76d
Changed paths:
M test/unit/UtilsTest.cpp
Log Message:
Add test for mapped files over 2G.
Compare: https://github.com/PDAL/PDAL/compare/417553baea50...df66a063341f
More information about the pdal-commits
