[pdal-commits] [PDAL/PDAL] 431de7: EPT reader filtering with both polygon and bounds ...
Andrew Bell noreply at github.com
Tue Aug 31 10:52:48 PDT 2021
  Branch: refs/heads/issue-3523
  Home:   https://github.com/PDAL/PDAL
  Commit: 431de7a785eb8911adb36b2dfb11fa05416dc5fe
      https://github.com/PDAL/PDAL/commit/431de7a785eb8911adb36b2dfb11fa05416dc5fe
  Author: Connor Manning <connor at hobu.co>
  Date:   2021-08-31 (Tue, 31 Aug 2021)
  Changed paths:
    M doc/stages/readers.ept.rst
    M io/EptReader.cpp
    M test/unit/io/EptReaderTest.cpp
  Log Message:
  EPT reader filtering with both polygon and bounds (#3506)
* Fix EPT reader polygon/bounds interaction to require both to pass, matching 2.2 behavior.
* Fix spatial filter checks when filters are not present.
* Add EPT reader test for polygon/bounds combination query.
* Add doc note for readers.ept polygon/bounds combination behavior.
  Commit: e94722a55a4638aa39dc57046ab1122fe9942843
      https://github.com/PDAL/PDAL/commit/e94722a55a4638aa39dc57046ab1122fe9942843
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M io/EptReader.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-3523
Compare: https://github.com/PDAL/PDAL/compare/7114a9fa890b...e94722a55a46
More information about the pdal-commits mailing list
