[pdal-commits] [PDAL/PDAL] ebd6c8: Small typo (#3466)
Andrew Bell
noreply at github.com
Mon Jun 28 07:03:58 PDT 2021
Branch: refs/heads/issue-3469
Home: https://github.com/PDAL/PDAL
Commit: ebd6c84733e473c42cb4bf82c83c9e63b900a6c2
https://github.com/PDAL/PDAL/commit/ebd6c84733e473c42cb4bf82c83c9e63b900a6c2
Author: Philipp Glira <pipppoo at gmail.com>
Date: 2021-06-11 (Fri, 11 Jun 2021)
Changed paths:
M doc/stages/filters.sample.rst
Log Message:
Small typo (#3466)
Commit: 72fad99ad3f4e019648174d74899c13ccb23f434
https://github.com/PDAL/PDAL/commit/72fad99ad3f4e019648174d74899c13ccb23f434
Author: Preston Hartzell <preston.hartzell at gmail.com>
Date: 2021-06-15 (Tue, 15 Jun 2021)
Changed paths:
M filters/IterativeClosestPoint.cpp
Log Message:
Check distance threshold in ICP filter final MSE computation (#3475)
* Check distance threshold in final MSE computation
Fixes issue 3471
* Eliminate `continue` blocks in maximum point to point distance checks
* Wrap numeric_limits
Commit: 8e25bb6a750d5c806fd226f7c78859cb66fdc611
https://github.com/PDAL/PDAL/commit/8e25bb6a750d5c806fd226f7c78859cb66fdc611
Author: chambbj <brad.chambers at gmail.com>
Date: 2021-06-22 (Tue, 22 Jun 2021)
Changed paths:
M doc/stages/filters.optimalneighborhood.rst
Log Message:
Update filters.optimalneighborhood.rst (#3481)
Per https://github.com/PDAL/PDAL/blob/72fad99ad3f4e019648174d74899c13ccb23f434/filters/OptimalNeighborhoodFilter.cpp#L64, the default `max_k` should be 14.
Commit: e71e3550a82a2f04cb764cf1343c1fd521c97c0a
https://github.com/PDAL/PDAL/commit/e71e3550a82a2f04cb764cf1343c1fd521c97c0a
Author: Charles Karney <charles at karney.com>
Date: 2021-06-24 (Thu, 24 Jun 2021)
Changed paths:
M doc/stages/filters.transformation.rst
M filters/TransformationFilter.cpp
Log Message:
Generalize filters.transformation to all homographies. (#3467)
Include the normalizing step in filters.transformation to allow general
homographies and update the documentation. All the examples in the
documentation are unaffected (since the last row of the matrix is
[0,0,0,1]). Homographies allow (painfully!), perspective images of a
point cloud to be created by following the transformation filter by
writers.gdal. This setup is not ideal, because the effective camera
matrix isn't stored with the the output image.
Commit: a72a0d97127536aeda99fbac84b5a841df7dbd65
https://github.com/PDAL/PDAL/commit/a72a0d97127536aeda99fbac84b5a841df7dbd65
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2021-06-25 (Fri, 25 Jun 2021)
Changed paths:
M pdal/Metadata.cpp
Log Message:
Catch bounds exceptions. (#3485)
Commit: 3d08e56a9b419888df350de7990c8f491b2448d3
https://github.com/PDAL/PDAL/commit/3d08e56a9b419888df350de7990c8f491b2448d3
Changed paths:
M pdal/util/Uuid.hpp
M test/unit/UuidTest.cpp
Log Message:
Initialize UUID to null. (#3486)
Close #3483
Commit: dd2e3d5051b7eb43afaee6c1cf63b1fa913c6f19
https://github.com/PDAL/PDAL/commit/dd2e3d5051b7eb43afaee6c1cf63b1fa913c6f19
Date: 2021-06-28 (Mon, 28 Jun 2021)
Changed paths:
M pdal/Metadata.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-3469
Compare: https://github.com/PDAL/PDAL/compare/d11e0e20ba2d...dd2e3d5051b7
More information about the pdal-commits
