[pdal-commits] [PDAL/PDAL] 16a7d3: support getting and setting dataset-level GDAL met...
Howard Butler
noreply at github.com
Mon Jun 28 07:11:34 PDT 2021
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 16a7d3434b7a2793d71dc85a51b9e683e2ac5e4c
https://github.com/PDAL/PDAL/commit/16a7d3434b7a2793d71dc85a51b9e683e2ac5e4c
Author: Howard Butler <howard at hobu.co>
Date: 2021-06-28 (Mon, 28 Jun 2021)
Changed paths:
M doc/stages/writers.gdal.rst
M io/GDALReader.cpp
M io/GDALReader.hpp
M io/GDALWriter.cpp
M io/GDALWriter.hpp
M pdal/private/gdal/Raster.cpp
M pdal/private/gdal/Raster.hpp
M test/unit/io/GDALReaderTest.cpp
M test/unit/io/GDALWriterTest.cpp
Log Message:
support getting and setting dataset-level GDAL metadata in writers.gdal and readers.gdal (#3479)
* support getting and setting dataset-level GDAL metadata in writers.gdal and readers.gdal
* no cleanup
* check split sizes
* support adding PDAL metadata and pipeline as GDAL XML PAM metadata for writers.gdal
* writers.gdal docs
* document the defaults
* respond to comments
* use MetadataNode
More information about the pdal-commits
