[pdal-commits] [PDAL/PDAL] dbdc10: Don't try to build HeightAboveGround if there is n...
Andrew Bell
noreply at github.com
Wed Mar 3 05:59:40 PST 2021
Branch: refs/heads/issue-3313
Home: https://github.com/PDAL/PDAL
Commit: dbdc10628fd3aa345698559f8b82e8a34f59477f
https://github.com/PDAL/PDAL/commit/dbdc10628fd3aa345698559f8b82e8a34f59477f
Author: Vasily Chekalkin <bacek at bacek.com>
Date: 2021-01-22 (Fri, 22 Jan 2021)
Changed paths:
M filters/HagNnFilter.cpp
Log Message:
Don't try to build HeightAboveGround if there is no ground points. (#3343)
Without this it triggers assert/segfault in PointView::getFieldAs when
HAG filters trying to fetch non-existing points.
Co-authored-by: Vasily Chekalkin <bacek at powerlinespro.com>
Commit: 60670b8aed64061233015cf41d5639d1e9f57400
https://github.com/PDAL/PDAL/commit/60670b8aed64061233015cf41d5639d1e9f57400
Author: Howard Butler <howard at hobu.co>
Date: 2021-01-26 (Tue, 26 Jan 2021)
Changed paths:
M CMakeLists.txt
Log Message:
bump master version information so it will resolve when we use it elsewhere
Commit: b7aaa45640a5097123023a7dad4019eaba77f97b
https://github.com/PDAL/PDAL/commit/b7aaa45640a5097123023a7dad4019eaba77f97b
Author: Norman Barker <norman at tiledb.io>
Date: 2021-01-27 (Wed, 27 Jan 2021)
Changed paths:
M plugins/tiledb/io/TileDBWriter.cpp
M plugins/tiledb/test/TileDBWriterTest.cpp
Log Message:
TileDB SFC (#3345)
* TileDB: Support hilbert ordering
* remove unnecessary array check
Commit: 9b438bcaab3a04b4aaa4ec623e30c3efe81898fc
https://github.com/PDAL/PDAL/commit/9b438bcaab3a04b4aaa4ec623e30c3efe81898fc
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2021-02-09 (Tue, 09 Feb 2021)
Changed paths:
M io/LasReader.cpp
M io/LasReader.hpp
M test/unit/apps/pc2pcTest.cpp
M test/unit/io/LasReaderTest.cpp
Log Message:
Remove LASzip from public headers (#3347)
* Move some private stuff from the LasReader header file to a struct in the cpp file.
* Fix guarded LAZperf code.
* Use args for guardec compression.
* Fix compression name.
Commit: 951a9e465a8c0a2f41876286c9b5d584c4311fce
https://github.com/PDAL/PDAL/commit/951a9e465a8c0a2f41876286c9b5d584c4311fce
Author: Preston Hartzell <preston.hartzell at gmail.com>
Changed paths:
A doc/stages/filters.gpstimeconvert.rst
A filters/GpsTimeConvert.cpp
A filters/GpsTimeConvert.hpp
M test/unit/CMakeLists.txt
A test/unit/filters/GpsTimeConvertTest.cpp
Log Message:
Add a filter that converts GPS time between the three standards (#3342)
* Replace bool functions with lambdas
First commit since adapting code for eventual pull request.
* Remove time vector, simplify code
- Pass view to functions rather than extracting and passing a vector of
times.
- Use 'filter' function rather than 'run'.
- Simplify functions that wrap and unwrap GPS Week Seconds.
- Move input validation to 'initialize' function.
- Additional miscellaneous refactoring.
* Remove test pipeline and text input/output files.
* Add documentation file, update conversion names
- Added filters.gpstimeconvert.rst to the doc/stages directory.
- Updated conversion names for consistency.
* Finish documentation, Update style, Edit test
- Final commit before pull request
* Fix typos in doc file, add newlines at file ends
Commit: a6884661dd180aeacfb6ec7014faac2cd341a1a9
https://github.com/PDAL/PDAL/commit/a6884661dd180aeacfb6ec7014faac2cd341a1a9
Author: chambbj <brad.chambers at gmail.com>
Date: 2021-02-10 (Wed, 10 Feb 2021)
Changed paths:
M doc/stages/filters.sample.rst
M filters/SampleFilter.cpp
M filters/SampleFilter.hpp
Log Message:
Make SampleFilter streamable (#3275)
Commit: 9be0a60d532738a9b618585df54cc1fb7e087f0c
https://github.com/PDAL/PDAL/commit/9be0a60d532738a9b618585df54cc1fb7e087f0c
Date: 2021-02-17 (Wed, 17 Feb 2021)
Changed paths:
M dimbuilder/DimBuilder.cpp
Log Message:
Throw errors when appropriate. (#3356)
Close #3353
Commit: ede0e8c958981fe5308397b8683b73804eb501a2
https://github.com/PDAL/PDAL/commit/ede0e8c958981fe5308397b8683b73804eb501a2
Changed paths:
M apps/pdal.cpp
Log Message:
Return an error code if no command is provided. (#3355)
Close #3354
Commit: e5768caabb5d95159dbe1cb81702ea119725d232
https://github.com/PDAL/PDAL/commit/e5768caabb5d95159dbe1cb81702ea119725d232
Changed paths:
M doc/stages/filters.reprojection.rst
M filters/ReprojectionFilter.cpp
M filters/ReprojectionFilter.hpp
Log Message:
Add an option to throw an exception if reprojection fails. (#3340)
Close #3316
Commit: 755b248ad47bea34ec180866b89182a2d5dd251d
https://github.com/PDAL/PDAL/commit/755b248ad47bea34ec180866b89182a2d5dd251d
Date: 2021-02-19 (Fri, 19 Feb 2021)
Changed paths:
M io/LasHeader.cpp
M io/LasReader.cpp
M kernels/InfoKernel.cpp
M pdal/PDALUtils.cpp
M pdal/PDALUtils.hpp
M pdal/util/FileUtils.cpp
M vendor/arbiter/arbiter.cpp
Log Message:
Get size for remote files (#3363)
* Fix file size exception.
* Header file.
Commit: 5c91d7e2dddcfa98f87491c1a993935f9dc0a447
https://github.com/PDAL/PDAL/commit/5c91d7e2dddcfa98f87491c1a993935f9dc0a447
Date: 2021-02-20 (Sat, 20 Feb 2021)
Changed paths:
M doc/stages/filters.assign.rst
Log Message:
Remove errant 's' from 'values'.
Commit: 7f99f4fb29b82e11d5b67482cb7ef0060779b401
https://github.com/PDAL/PDAL/commit/7f99f4fb29b82e11d5b67482cb7ef0060779b401
Changed paths:
M io/LasHeader.cpp
M io/LasReader.cpp
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: da289b5515c3a94f23d1f02ebffa6e25dc09cbb2
https://github.com/PDAL/PDAL/commit/da289b5515c3a94f23d1f02ebffa6e25dc09cbb2
Author: Kurt Schwehr <schwehr at google.com>
Date: 2021-02-24 (Wed, 24 Feb 2021)
Changed paths:
M io/HeaderVal.hpp
Log Message:
HeaderVal.hpp: Initialize m_defVal in constructor (#3367)
Commit: 65c5196e043b82f2223cb5d23a86d08b760e5037
https://github.com/PDAL/PDAL/commit/65c5196e043b82f2223cb5d23a86d08b760e5037
Changed paths:
M pdal/XMLSchema.cpp
Log Message:
XMLSchema.cpp: Fix memory leak in loadMetadata (#3368)
* XMLSchema.cpp: Fix memory leak in loadMetadata
* XMLSchema.cpp: Remove unused etype in loadMetadata
Commit: 59e2bad86071aa9a7bdcb86d627442c06e52f127
https://github.com/PDAL/PDAL/commit/59e2bad86071aa9a7bdcb86d627442c06e52f127
Changed paths:
M test/unit/SpatialReferenceTest.cpp
Log Message:
Remove worthless test.
Commit: 2315e9f0fd74fdbbe53f47119ec9d73b924e11d1
https://github.com/PDAL/PDAL/commit/2315e9f0fd74fdbbe53f47119ec9d73b924e11d1
Changed paths:
M io/HeaderVal.hpp
Log Message:
Commit: 357b2cd57f174c3ec64a342cb650013a6e7e5798
https://github.com/PDAL/PDAL/commit/357b2cd57f174c3ec64a342cb650013a6e7e5798
Date: 2021-02-25 (Thu, 25 Feb 2021)
Changed paths:
M test/unit/apps/TileTest.cpp
Log Message:
TileTest.cpp: Only check read values if they are actually read (#3369)
* TileTest.cpp: Only check read values if they are actually read
* TileTest.cpp: Do not count partial lines in checkFile
Commit: e76e330c151499b82c4abc92d595f54d01c43a97
https://github.com/PDAL/PDAL/commit/e76e330c151499b82c4abc92d595f54d01c43a97
Author: Aaron Yonas <aaronyonas at google.com>
Changed paths:
M test/unit/FileUtilsTest.cpp
M test/unit/PipelineManagerTest.cpp
M test/unit/filters/AdditionalMergeTest.cpp
M test/unit/filters/FaceRasterTest.cpp
Log Message:
Made unit tests write to Support:tempath() directory. (#3374)
Commit: c3f1ae5af1f370aa8659dc2653365846b209a841
https://github.com/PDAL/PDAL/commit/c3f1ae5af1f370aa8659dc2653365846b209a841
Changed paths:
M test/unit/XMLSchemaTest.cpp
Log Message:
In XMLSchemaTest, fixed null dereference on failure to open file. (#3371)
Commit: 2f2f684013a3887794b8a257a2bacefc0216af54
https://github.com/PDAL/PDAL/commit/2f2f684013a3887794b8a257a2bacefc0216af54
Changed paths:
R test/unit/PointContextTest.cpp
Log Message:
Deleted broken and unused file test/unit/PointContextTest.cpp (#3376)
Commit: d0d298f9493a0d4c89b45f199afc099e9abc0635
https://github.com/PDAL/PDAL/commit/d0d298f9493a0d4c89b45f199afc099e9abc0635
Author: Philipp Glira <pipppoo at gmail.com>
Date: 2021-03-01 (Mon, 01 Mar 2021)
Changed paths:
M doc/stages/readers.gdal.rst
Log Message:
Update readers.gdal.rst (#3381)
Changed output format to las in pipeline.
Commit: 9611754d325c0fd71f5d6e4d87f38e2355edcaf4
https://github.com/PDAL/PDAL/commit/9611754d325c0fd71f5d6e4d87f38e2355edcaf4
Date: 2021-03-02 (Tue, 02 Mar 2021)
Changed paths:
M io/GDALWriter.cpp
Log Message:
io/GDALWriter.cpp: Fixed undefined behavior bug. (#3383)
Commit: 6d66540020953240e1175fce737848307cd0a6f3
https://github.com/PDAL/PDAL/commit/6d66540020953240e1175fce737848307cd0a6f3
Date: 2021-03-03 (Wed, 03 Mar 2021)
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
M io/GDALWriter.cpp
M io/HeaderVal.hpp
M io/LasHeader.cpp
M io/LasReader.cpp
M io/LasReader.hpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-3313
Compare: https://github.com/PDAL/PDAL/compare/03cb83a3bd91...6d6654002095
More information about the pdal-commits
