[pdal-commits] [PDAL/PDAL] 1a802a: filters.colorization keep points outside raster wh...
Daniel Brookes
noreply at github.com
Tue Mar 16 12:53:18 PDT 2021
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 1a802af92a194e99cf551b56579ce21c07f02af8
https://github.com/PDAL/PDAL/commit/1a802af92a194e99cf551b56579ce21c07f02af8
Author: Daniel Brookes <26078684+dbrookes96 at users.noreply.github.com>
Date: 2021-03-16 (Tue, 16 Mar 2021)
Changed paths:
M filters/ColorizationFilter.cpp
M test/unit/filters/ColorizationFilterTest.cpp
Log Message:
filters.colorization keep points outside raster when streaming (#3391) (#3393)
always return true from ColorizationFilter::processOne regardless of if
the raster read for the x, y position of the point did not succeed. the
output band(s) of points outside the raster are ignored.
the normal mode output and stream mode output should now be equal for
filters.colorization.
added a quick unit test to check this scenario.
Co-authored-by: Daniel Brookes <dbrookes at micromine.com.au>
More information about the pdal-commits
