[pdal-commits] [PDAL/PDAL] dc856a: Lazperf (#3459)
    Andrew Bell
    noreply at github.com
    Wed May 19 05:52:57 PDT 2021
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: dc856a0a79d4f4888cb76d7b2786d8ffc52ca2e6
      https://github.com/PDAL/PDAL/commit/dc856a0a79d4f4888cb76d7b2786d8ffc52ca2e6
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2021-05-19 (Wed, 19 May 2021)
  Changed paths:
    M CMakeLists.txt
    M cmake/lazperf.cmake
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    R pdal/compression/LazPerfCompression.cpp
    R pdal/compression/LazPerfCompression.hpp
    M pdal/compression/LazPerfVlrCompression.cpp
    M pdal/compression/LazPerfVlrCompression.hpp
    M test/unit/io/LasReaderTest.cpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Lazperf (#3459)
* Checkpoint.
* Add start option to LAS reader.
* Add PDAL_LAS_START macro.
* Lazperf in progress.
* More fixes for new lazperf.
* Use proper test for point format.
* Better name for 1.4 point format test.
* Updates for new LAZPERF
* Remove config stuff.
* Fix name.
* Add start test.
* Fix arg name.
* Start support for LAZPERF.
* Offset count by start index.
* Working start for lazperf.
* Fix missed bits.
* Fixups for LAZperf version 2.
* Missed header.
* Don't copy filter?
* No unique_ptr for LasPerfVlrCompressor
* Don't run lazperf tests without lazperf.
* Fix comment.
* Minor updates.
* Assertion to exception
More information about the pdal-commits
