[pgrouting-dev] APSP Implementation
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Dec 1 23:06:51 EST 2010
On 12/1/2010 10:50 PM, Anton Patrushev wrote:
> Hi list,
> Daniel is right - we mostly need a distance matrix, so I think there
> should be at least an option to return distance matrix only and omit
> extra work on extracting paths. Or should it be different function?
> It would be nice if extracted paths could be in form of phRouting
> 'path' type with additional 'from' and 'to' columns.
Agreed.
You can do a lot in the wrapper functions like joining to other tables
or otherwise post processing the results that come back. The key to this
is to have the necessary references to the other data.
I think Daniel made an excellent point earlier that I would like to
hilite which is that we can build the graph once the process it multiple
times in the code before we return the results.
So the process flow might look like this for a SOME PAIRS shortest path
build graph from bounding box
if num pairs is < some limit then
loop thought pairs and solve shortest path
else
use APSP algorithm
return results as:
from,to,distance[,array{from,node,node,...,to}]
or something like that.
A lot of good ideas.
-Steve
More information about the pgrouting-dev
