[pgrouting-dev] Dijkstra's solution - How to get tree?
Stephen Woodbridge
woodbri at swoodbridge.com
Tue May 4 22:49:51 EDT 2010
If I run a Dijkstra's solution:
Can I run it for some max distance?
How can I get the resulting tree?
I have a problem where I need to pick a start point and solve the graph
for some max distance from the start node. I think this is similar to
what is done for drive time analysis.
Any hints would be welcome and I'm not shy about hack some code if I
know where to start looking.
Thanks,
-Steve
More information about the pgrouting-dev
