[pgrouting-dev] New website for review
Daniel Kastl
daniel at georepublic.de
Sun Nov 14 12:41:22 EST 2010
Hi Steve,
Thank you for the comments!
2010/11/15 Stephen Woodbridge <woodbri at swoodbridge.com>
> Daniel,
> Wow! two big thumbs up! Thank you for all this effort and the results are
> very fine.
> One problem on the Download -> Code Respository section:
> woodbri at mappy:~/work/pgrouting-git$ git clone git at github.com:
> pgRouting/pgrouting.git
> Initialized empty Git repository in /u/work/pgrouting-git/pgrouting/.git/
> The authenticity of host 'github.com (207.97.227.239)' can't be
> established.
> RSA key fingerprint is 16:27:ac:a5:76:28:2d:36:63:1b:56:4d:eb:df:a6:48.
> Are you sure you want to continue connecting (yes/no)? yes
> Warning: Permanently added 'github.com,207.97.227.239' (RSA) to the list
> of known hosts.
> Permission denied (publickey).
> fatal: The remote end hung up unexpectedly
Oh maybe this problem happened, because I have never tried to clone a
repository recently, that I didn't create myself ;-)
It seems that there are several ways to access a repository:
- SSH read and write: git at github.com:pgRouting/pgrouting.git
- Git read only: git://github.com/pgRouting/pgrouting.git
I everywhere wrote the command with read and write access and didn't think
about it. That might be the problem.
> A couple of small suggestions for the Development page.
> 1. I think it would be a good idea to have a "How To Contribute" page the
> has a short paragraph covering things that we think are important. Ideas
> like:
> o where to add documentation
> o How to use RFCs
> o coding standards if any (might just say to not reformat existing pages
> and to you style similar to existing).
> o test cases
> o examples
> o whatever you guys think would be appropriate and desirable for
> contributors to provide.
Good ideas ... some points I don't know well about either, but maybe we can
steal from other projects a bit.
> 2. I think it would be helpful to add a link to 1-2 GitHub Tutorials out on
> the web.
Yes, true. That's not so difficult.
> 3. Does sphinx have the ability to automatically create a site map page? If
> so I think it might be useful to generate that and link it in somewhere. If
> not I'm not sure if it is worth the effort to generate and update manually.
I don't really know.
When you create a new project with the wizard, it also creates this block on
the index.html page in root:
Indices and tables
* :ref:`genindex`
* :ref:`modindex`
* :ref:`search`
I don't know one of them could be useful. Only search worked from beginning,
so I disabled the other two.
Sitemap is only mentioned in the documentation at toctree:
http://sphinx.pocoo.org/markup/toctree.html?highlight=sitemap
Daniel
> Great job on this.
> -Steve
> On 11/14/2010 8:13 AM, Daniel Kastl wrote:
>> Hi list,
>> It has started many months ago, but I'm glad to say there is some
>> visible output now.
>> I created a new pgRouting website, built with Sphinx, and I copied the
>> relevant content from current TRAC wiki.
>> If you have a time, please take a look at the current version and tell
>> me, if something is missing.
>> Let me know if you have ideas what could be done better:
>> http://update.pgrouting.org/
>> (on the first page the "news" block and the "callout" to add some
>> banners like the one for FOSS4G 2011 for example are still missing)
>> If everything looks OK, I would propose to change to the new website in
>> about a week or so.
>> Next steps would be then:
>> * Copy relevant tickets from TRAC to GitHub (-> Anton)
>> * Cache the discussion forum as HTML and upload it to
>> http://download.osgeo.org/pgrouting/forum/
>> * Prepare redirect from current http://pgrouting.postlbs.org to
>> http://www.pgrouting.org (also try to redirect missing links as
>> good as possible) (-> Orkney)
>> * Change DNS record of pgrouting.org <http://pgrouting.org> (Daniel)
>> * Make the change final and announce it.
>> If someone wants to help with the website, fix typos or add/edit
>> content, I'm happy to add you as a committer to the repository on Github.
>> There is a cron job running on the server that checks the Git repository
>> every hour and updates the website if there are changes.
>> Aside the website, a few other things have changed, mostly related to
>> GitHub hosting:
>> * All pgRouting related repositories will be in
>> https://github.com/pgRouting
>> o pgrouting (library): https://github.com/pgRouting/pgrouting
>> o website: https://github.com/pgRouting/website
>> o workshop (FOSS4G 2010): https://github.com/pgRouting/workshop
>> o osm2pgrouting: https://github.com/pgRouting/osm2pgrouting
>> o pgrouting-contrib:
>> https://github.com/pgRouting/pgrouting-contrib (place to
>> collect wrapper functions, examples, etc.)
>> Especially to "pgrouting-contrib" and "website" I want to add anyone as
>> committer, who would like to contribute, without restrictions.
>> For all other repositories I hope that Git will make it easier to
>> propose changes and patches by creating your own fork and sending "pull
>> requests" to apply changes to the pgRouting repository.
>> It has been a long way.
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>> Web: http://georepublic.de
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20101115/b9c3ef35/attachment.html
More information about the pgrouting-dev
