[pgrouting-dev] Writing unittests for SQL functions
Kishore Kumar
justjkk at gmail.com
Wed Apr 20 13:44:19 EDT 2011
Inline response follows:
On Apr 20, 2011 6:24 AM, "Daniel Kastl" <daniel at georepublic.de> wrote:
> I had actually made a ticket for unit tests some time ago:
Thanks to let me know that I'm heading in the right direction.
> Have you looked at how PostGIS is doing it? There is some chance that
pgRouting and PostGIS will merge (someday), so then it would be good to have
something that fits already.
Well, it didn't occur to me previously. I am hoping that looking at
PostGIS's tests will solve most problems. I got busy with college stuff
recently and hope to go through it in a couple of days.
> One important point is in my opinion to have some suitable network graph
for testing.
> Something that can cover all test cases and can eventually give some
visual.
Ah, I added that simple test data and the simple test case more as a hello
world of unittests and hence will replace with some large, real data soon.
Thanks & regards,
J Kishore Kumar.
> 2011/4/20 Kishore Kumar <justjkk at gmail.com>
>> Hi,
>> I was exploring on ways to improve the pgrouting codebase and make it
suited for easier development. It struck me that writing unittests for all
the pgrouting functions will help with both documentation as well as reduce
the overhead of manual testing. Initially I tried using google's c++ testing
framework[1] to test the c and c++ functions but encountered problems
because the c functions were using postgresql library and decoupling psql
interactions from the core algorithm seemed too much of a rewrite for
testing.
>> Hence, I resolved to implementing black box testing of individual SQL
functions. Since this can be done independent of the language constraints, I
explored opportunities with using python. I found python's unittest
framework to be both light and flexible for the purpose. The initial
attempts can be found in my python_unittests branch[2].
>> The problem I'm facing is to run the tests between 'make' and 'make
install' stages. Currently, the tests are run against the installed version
of pgrouting found at $libdir so that testing can be done only after
installing.
>> Will be glad to hear any problems with the current choice of tools or if
the testing approach needs to be changed.
>> Regards,
>> J Kishore Kumar.
>> [1] - http://code.google.com/p/googletest/
>> [2] - https://github.com/justjkk/pgrouting/commits/python_unittests
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110420/00bd8426/attachment.html
More information about the pgrouting-dev
