[pgrouting-dev] Fwd: Multiple Turn Restrictions?
Stephen Woodbridge woodbri at swoodbridge.com
Sat Apr 30 23:34:00 EDT 2011
I'm reposting this old thread for Jay's benefit. Unfortunately the the
old links to postlbs.org no longer work and I do not see the content on
the new sight.
-Steve
On 8/19/2008 10:40 AM, Stephen Woodbridge wrote:
> http://pgrouting.postlbs.org/ticket/124
>> Hi Anton,
>> Thank you for your responses and enlightenment. I have updated two wiki
>> pages to include some of this additional explanation. When you have a
>> chance could you check and make sure I stated thinks correctly and
>> completely.
>> Added some info on Graphs, Directed, Undirected, and reverse costs.
>> http://pgrouting.postlbs.org/wiki/TopologyCreation
>> Added info on multiple turn restrictions:
>> http://pgrouting.postlbs.org/wiki/ShootingStar
>> It seems, like it would be better to add some additional parsing and
>> syntax to the rule column to support multiple restriction, rather than
>> adding multiple rows. For example, rule could be:
>> rule 1           rule 2          rule N
>> <edge>[,<edge>][;<edge>[,<edge>]]*
>> this would allow any of the following rows
>> 4
>> 14,4
>> 4;12
>> 14,4;12
>> etc
>> Anyway, it is a thought for an improvement. I can open a ticket if you like.
>> Best regards,
>>     -Steve
>> Anton Patrushev wrote:
>>> You just need to add one more row for that edge.
>>> Like this:
>>>   gid | source | target | cost | x1 | y1 | x2 | y2 | to_cost | rule
>>>   11 |      3 |     10 |    2 |  4 |  3 |  4 |  5 |    1000 | 4
>>>   11 |      3 |     10 |    2 |  4 |  3 |  4 |  5 |    1000 | 12
>>> And then you always need to order your data by gid when you load it to
>>> a shortest path function..
>>> Anton.
>>> On Mon, Aug 18, 2008 at 11:06 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com>  wrote:
>>>> Anton,
>>>> Ok, that makes sense, but I still do not see how to specify multiple
>>>> restrictions for a single edge. For example in the graph below how to I
>>>> specify the cost of going from either edge EB(4) or CB(12) to edge DB(11) is
>>>> 1000. Both of these turns should be disallowed.
>>>> -Steve
>>>> PS: Sorry looks like the list is still broken regardless of what email I
>>>> send it to.
>>>>> Steve,
>>>>> Here is the table for your case:
>>>>>   Edge  |  Source | Target | Cost | to_cost | rule
>>>>>   AB    |  A      | B      | 1    | 1000    | EB
>>>>>   BC    |  B      | C      | 1    | 1000    | DB
>>>>>   EB    |  E      | B      | 2    | 1000    | BC
>>>>> and nothing more.
>>>>>>   12 |      3 |     10 |    2 |  4 |  3 |  4 |  5 |    1000 | 14, 4
>>>>> This means completely different things.
>>>>> For example, you have a graph like this:
>>>>>          C
>>>>> A-------B--------E--------F
>>>>>          D         |
>>>>>                     G
>>>>> where edge ids are:
>>>>> AB: 10
>>>>> BC: 12
>>>>> BD: 11
>>>>> BE: 4
>>>>> EF: 2
>>>>> EG: 14
>>>>> So, the restriction we have describes a way 14->4->12 (G->E->B->C)
>>>>> which is restricted (has cost 1000).
>>>>> Anton.
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.postlbs.org
>>>>> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the pgrouting-dev mailing list
