[pgrouting-dev] Returning the correct edge id from
boost_dijkstra_* functions
Daniel Kastl
daniel at georepublic.de
Fri Jul 1 00:46:02 EDT 2011
Hi Steve,
Thank you! But I also rely on Anton's skills here.
Not to get lost in the mailing list archive, I copied the code and links to
this Wiki page:
https://github.com/pgRouting/pgrouting/wiki/Revision-of-return-results
It's part of the 2.0 plan. If you have more ideas or request, feel free to
add them there:
https://github.com/pgRouting/pgrouting/wiki/2.0-Development-Plan
Daniel
2011/7/1 Stephen Woodbridge <woodbri at swoodbridge.com>
> Anton, Daniel,
> I have been fighting with the dijkstra results because we do not return
> things like the parent id of a path and we definitely do not return the
> correct edge ids.
> So with some help from the boost users list and banging my head against the
> C++ wall, being only a C programmer :), I have some code that works for me.
> http://pastebin.com/qa1caiXs
> In dijkstra.h I also have defined the following structs:
> typedef struct edge
> int id;
> int source;
> int target;
> float8 cost;
> float8 rcost;
> } edge_t;
> typedef struct path_element
> int vertex_id;
> int parent_id;
> int edge_id;
> float8 cost;
> } path_element_t;
> You should be able to copy the appropriate parts of this file and update
> the driving distance code and the low level dijkstra code to return more
> correct and useful results. I'm using this code outside of the postgresql
> server, but it should not require any significant changes. Since I'm not
> developing code in the database, I will leave that as an exercise for you
> guys to work out and test.
> Thanks,
> -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110701/2dcbe051/attachment.html
More information about the pgrouting-dev
