[pgrouting-dev] Support for Time Constraints
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jul 7 23:29:41 EDT 2011
Hi Jay,
Sorry, I have not responded to your recent emails, I have been out of
the office most of this week. You are doing a great job with your
project. I will review it in more detail and comment as soon as I can.
Best regards,
   -Steve
On 7/7/2011 8:33 AM, Jay Mahadeokar wrote:
> Hi,
> I have documented the design details [1] and written an example tutorial
> [2] to try out the time_dependent_shortest_path algorithm. I guess this
> is enough to show the functionality, although, the data and examples
> along with the wrapper functions need to be worked on in next few weeks.
> Any feedback / corrections are welcome.
> [1] https://github.com/pgRouting/pgrouting/wiki/TDSP-Details
> [2] https://github.com/pgRouting/pgrouting/wiki/TDSP-Tutorial-and-Example
> On Tue, Jul 5, 2011 at 11:54 AM, Jay Mahadeokar
> <jai.mahadeokar at gmail.com <mailto:jai.mahadeokar at gmail.com>> wrote:
>     Hi,
>     An update -
>     I have coded the functions to retrieve data from time_dep_costs
>     table and it is presented to the core tdsp algorithm along with the
>     data from ways table. The query seems to be working nicely for now.
>     The query format is:
>     CREATE OR REPLACE FUNCTION time_dependent_shortest_path(
>              sql text,
>              source_id integer,
>              target_id integer,
>              directed boolean,
>              has_reverse_cost boolean,
>              time_dep_sql text,
>              query_start_time integer)
>              RETURNS SETOF path_result
>              AS '$libdir/librouting_tdsp'
>              LANGUAGE 'C' IMMUTABLE STRICT;
>     I have updated the github branch accordingly [1].
>     The script to generate time_dependent_costs data can be found at
>     [2]. I updated travel time of rows with class_id 106 and start_time
>     as 9 or 19 to a large value.  (Signifying that the roads are blocked
>     in those times) I also played around with the travel_time values a bit.
>     If you do following queries:
>     SELECT * FROM time_dependent_shortest_path('
>                      SELECT gid as id,
>                               source::integer,
>                               target::integer,
>                               length::double precision as cost
>                              FROM ways',
>                      81, 359, true, false,'SELECT edge_id, start_time
>     ,travel_time from time_dep_costs',14);
>                      SELECT gid as id,
>                               source::integer,
>                               target::integer,
>                              FROM ways',
>     ,travel_time from time_dep_costs',9);
>     The outputs are different. The path returned by second query where
>     query_start_time is 9 avoids the edge (81,82) since its cost is too
>     high, and instead takes a longer route of 39 hops.  On other hand,
>     path returned by 1st query where query_start_time is 14 returns
>     shortest path of 20 hops.
>     It would be great if anyone can check the code, run queries and give
>     feedback for improvements.
>     Now the next task should be to finalise framework to generate proper
>     test data and test the functionality rigorously.
>     Also, we need to write proper wrapper functions that will neatly map
>     the data from time_dep_costs table into data that can be presented
>     to core function. This means that the factors like cycles in time
>     (23 hrs to 00 hrs) need to be considered. Also it will be better if
>     the costs in table is in time units instead of distance units. I
>     will try and come up with a suitable model soon.
>     Any inputs in this regard are welcome.
>     [1] https://github.com/pgRouting/pgrouting/tree/gsoc-tdsp
>     [2]
>     https://github.com/pgRouting/pgrouting/blob/gsoc-tdsp/extra/tdsp/sql/data_generate_tdsp.sql
>     On Thu, Jun 23, 2011 at 2:56 AM, Daniel Kastl <daniel at georepublic.de
>     <mailto:daniel at georepublic.de>> wrote:
>         2011/6/23 Stephen Woodbridge <woodbri at swoodbridge.com
>         <mailto:woodbri at swoodbridge.com>>
>             Hi Daniel, Jay,
>             Ok, sorry for my *rant* about OSM attributes!
>             So it looks like osm2po does the importing and
>             classification via its black box java .jar file and you can
>             use the tables afterwards. Ok this could work, but I'm not
>             sure I like the idea of using someone's black box to import
>             the data. Long term it would be better to just use
>             osm2pgrouting and to understand the issues that I presented
>             and a write a stored procedure to do the classifications
>             that are needed.
>         Hi Steve,
>         This was just meant to be an easy and quick way for Jay, if he
>         doesn't want to spend much time with studying OSM attributes.
>         But of course I prefer some OS tool, too.
>         I have tried to convince Carsten (the author of osm2po) to make
>         his really nice conversion tool available as Open Source, but I
>         accept that he doesn't want to do so (yet ;-).
>         So I think it's good to see how osm2po organizes the tables.
>         Daniel
>             I have not been on the osm routing list, but I'm sure we can
>             get guidance from them to setup appropriate classifications.
>             Or if someone want to to try out osm2po we can review the
>             resultant tables and look at how they classified segments.
>             -Steve
>         Georepublic UG & Georepublic Japan
>         eMail: daniel.kastl at georepublic.de
>         <mailto:daniel.kastl at georepublic.de>
>         Web: http://georepublic.de <http://georepublic.de/>
>         _______________________________________________
>         pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>     Regards,
>     -Jay Mahadeokar
> Regards,
> -Jay Mahadeokar
More information about the pgrouting-dev mailing list
