[pgrouting-dev] Time dependent data and input format
Daniel Kastl daniel at georepublic.de
Thu Jul 28 11:02:55 EDT 2011
If possible I would like to use the same for testing as PostGIS:
http://trac.osgeo.org/postgis/wiki/DevWikiCUnit
http://trac.osgeo.org/postgis/wiki/DevWikiMain#PatchSubmissionGuidelines
Except there are good arguments to do it a different way.
Daniel
On Thu, Jul 28, 2011 at 6:53 PM, Kishore Kumar <justjkk at gmail.com> wrote:
> Hi,
> Updated the wiki page and added this:
> https://github.com/pgRouting/pgrouting/wiki/Automated-Testing-(Unit-Tests)#wiki-SQL_Testing
> Looking for improvements in the workflow.
> Regards,
> J Kishore kumar.
> On Thu, Jul 28, 2011 at 2:52 PM, Jay Mahadeokar
> <jai.mahadeokar at gmail.com> wrote:
> > On Thu, Jul 28, 2011 at 2:47 PM, Kishore Kumar <justjkk at gmail.com>
> wrote:
> >> Hi,
> >> The testing framework currently doesn't have a proper documentation
> >> except the somewhat readable python code. I am also not sure what
> >> level of documentation should suffice. Is the python testing framework
> >> going to stay or should we move to c?
> > I am not sure about others, but I have not worked with python before. So,
> I
> > would love to go with C if given a choice!
> >> Thanks & Regards,
> >> J Kishore kumar.
> >> On Tue, Jul 26, 2011 at 4:40 AM, Daniel Kastl <daniel at georepublic.de>
> >> wrote:
> >> >> Daniel, Anton, is there anything specific that I need to do with
> >> >> regards
> >> >> to the project, so that it can be bundled with the pgRouting 2.0?
> >> >> Currently
> >> >> I am using a modified CMake file[2], and not compiling the test
> >> >> framework.
> >> >> Till now, I have not worked with this testing framework designed by
> >> >> Kishore
> >> >> (right?) so should I read any docs that will get me introduced with
> it?
> >> > Sorry, the test framework I don't have a clear opinion yet. I think
> it's
> >> > Kishore's proposed testing but anyone is free to make suggestions how
> to
> >> > improve it.
> >> _______________________________________________
> >> pgrouting-dev mailing list
> >> pgrouting-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> > Regards,
> > -Jay Mahadeokar
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110729/8f0e7d2f/attachment.html
More information about the pgrouting-dev mailing list
