[pgrouting-dev] Licensing for Co-development between
OpenGraphRouter and pgRouting
Daniel Kastl
daniel at georepublic.de
Thu Jun 2 21:59:01 EDT 2011
2011/6/3 Anton Patrushev <anton.patrushev at georepublic.de>
> Anyway, what do you think may an advantage of using dual MIT/GPL
> license (except of OpenGraphRouter integration)?
> > Maybe worth to discuss this in a new thread, but having Jay and Kishore
> working on new algorithms, it might be time to think about a function
> "cleanup" and version pgRouting 2.0. Don't you agree?
> Yep, looks like some job for PSC :)
You're PSC ;-)
I think that thing was a nice try last year, but can't be really called a
success for whatever reason.
Anyway, other thread.
> Anton.
> >> Hi Daniel,
> >> Doesn't this statement
> >> * This program is free software; you can redistribute it and/or modify
> >> * it under the terms of the GNU General Public License as published by
> >> * the Free Software Foundation; either version 2 of the License, or
> >> * (at your option) any later version.
> >> assume later (i.e. v3) versions?
> > Well, this doesn't mean it's v3, no? It's the license text of version 2,
> I
> > think.
> >> I support getting rid of CGAL, but I don't think that PostGIS hulls
> >> fit all possible cases of Driving Distance use.
> > http://www.bostongis.com/postgis_concavehull.snippet
> > It even supports "wholes", so I think it's even better.
> > It doesn't need to be all new, but function names and wrappers could be
> > reorganized, pgRouting could be checked for compatibility with PostGIS
> 2.0
> > and Steve's idea to provide functions that return the "raw data" is also
> a
> > good idea.
> > Daniel
> >> Anton.
> >> >> Hi Steve,
> >> >> I believe pgRouting is under GPLv3 - I think we changed from v2 last
> >> >> year. For me GPL/MIT dual licensing looks a bit strange, I mean I
> >> >> can't imagine a case when one would prefer GPL.
> >> > No, it hasn't changed.
> >> >> MIT is GPL compatible and I see no problem with PostGIS which is also
> >> >> under
> >> >> GPL.
> >> >> By the way, we already have GPL/QPL compatibility issue :)
> >> > I would like to remove CGAL dependency and just return points for
> >> > driving
> >> > distance.
> >> > With PostGIS 2.0 there is also support for concave hull. Then CGAL
> isn't
> >> > necessary anymore to calculate the drive time polygon.
> >> > Daniel
> >> >> Anton.
> >> >> On 5/27/11, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> >> >> > Hi PSC,
> >> >> > I have been talking with Roni about doing more development for
> >> >> > OpenGraphRouter and to possible integrate that with pgRouting. The
> >> first
> >> >> > issue I see is that of licensing. OpenGraphRouter is using an MIT-X
> >> >> > style license (and wants to stay that way) and I believe pgRouting
> is
> >> >> > using a GPLv2 License.
> >> >> > So I think this means we can move OpenGraphRouter code into
> >> >> > pgRouting,
> >> >> > which would make that code dual licensed, ie code used in pgRouting
> >> >> > would become GPLv2, but the original in OpenGraphRouter would
> remain
> >> >> > MIT-X, but we could not move pgRouting code into OpenGraphRouter.
> >> >> > One of my goals as we move forward is that code we develop should
> be
> >> >> > have a reference implementation in a command line tool in
> >> >> > OpenGraphRouter and a reference implementation with in pgRouting.
> >> >> > Does anyone have any thoughts on this? Thoughts on the licensing
> >> issues?
> >> >> > Would there be any interest in supporting a similar dual licensing
> in
> >> >> > pgRouting? This might not be possible because Postgresql/PostGIS
> >> >> licensing.
> >> >> > Frank, Paul, can you comment please.
> >> >> > Thanks,
> >> >> > -Steve
> >> >> > _______________________________________________
> >> >> > pgrouting-dev mailing list
> >> >> > pgrouting-dev at lists.osgeo.org
> >> >> > http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> >> >> Georepublic UG (haftungsbeschränkt)
> >> >> Salzmannstraße 44,
> >> >> 81739 München, Germany
> >> >> Anton Patrushev
> >> >> CTO
> >> >> eMail: anton.patrushev at georepublic.de
> >> >> Web: http://georepublic.de
> >> >> Tel: +49 (089) 420 959 519
> >> >> Sip: 1959519 at sipgate.de
> >> >> Commercial register: Amtsgericht München, HRB 181428
> >> >> CEO: Daniel Kastl
> >> > Georepublic UG & Georepublic Japan
> >> > eMail: daniel.kastl at georepublic.de
> >> Salzmannstraße 44,
> >> Anton Patrushev
> >> CTO
> >> CEO: Daniel Kastl
> Salzmannstraße 44,
> Anton Patrushev
> CTO
> CEO: Daniel Kastl
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110603/676a6cb4/attachment-0001.html
More information about the pgrouting-dev
