[pgrouting-dev] Re: [postgis-users] Constrained Delaunay
	Triangulation
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Sat Jun  4 10:54:39 EDT 2011
On 6/4/2011 9:51 AM, Sandro Santilli wrote:
> On Sat, Jun 4, 2011 at 11:49 AM, Brian Sanjeewa Rupasinghe
> <jinkabs at gmail.com>  wrote:
>> Can i implement constrained delaunay triangulation in PostGIS?
> Sanjeewa,  I belive it would make sense to port the algorithm from JTS
> (1.12) to GEOS first
> and then have PostGIS give access to the GEOS implementation throught its C-API.
Sorry cross-posting this to pgRouting.
I would like to through out a use case for delauny triangulation to
think about if you go forward with implementing this.
pgRouting today computes a drive time polygons. The way this is done is
to solve a graph problem that results in a set of nodes (x,y) and a cost
(z) at each node. If these nodes(ie 3D points) can be triangulated into
a triangulated surface, then the surface can be sliced by equi-interval
planes to create the edges of the polygons, that could then be passed to
ST_BuildArea() to create polygon contours.
Today we use CGAL to post process the 3D points into contours, but we
would like to remove that as a dependency because it has license
complication.
I'm sure there are a lot of other use cases out there, but this is just
one that I would like to add.
Thanks,
   -Steve
More information about the pgrouting-dev
