[pgrouting-dev] Support for Time Constraints
Anton Patrushev anton.patrushev at georepublic.de
Sun Jun 12 04:02:20 EDT 2011
Hi Jay,
No, there was no specific meaning, just king of cyphering - first
digit for road class and then two last digits for road type.
Anton.
On 6/12/11, Jay Mahadeokar <jai.mahadeokar at gmail.com> wrote:
>> Hi Jay,
>> I think that instead of just random times, I would take a different
>> approach to generate this data. If we think about "rush hour" around a
>> major
>> city, the highways (based on road class) flowing into the city in the
>> morning would get reduced average speeds you could apply curve like
>> average
>> speed*percent based on 6am (90%), 7am(75%), 8am(45%), 9am(50%), 10am(85%)
>> and do something similar in the evening rush. It might be too hard to
>> figure
>> on direction of flow in/out bound so apply the curve to all traffic. The
>> assumption is that the highways are congested which will force traffic
>> onto
>> side streets. You might want to also reduce the lower class speeds by say
>> a
>> constant 80% during rush hour.
>> If we can get OSM data then it should be easy to populate the table with
>> that data.
>> -Steve
> I am trying to write plpgsql query to generate time-dependent data
> corresponding to the ways table in pgrouting workshop. As suggested by Steve
> above, instead of generating random data, I will follow patterns (see above
> message) so that the data is nearer to the real worlds scenario.
> So, now I need to make distinction between highways, streets etc. I saw the
> attribute class_id in ways table. It has 14 distinct values:
>  class_id
> 102
> 122
> 106
> 111
> 108
> 100
> 109
> 112
> 101
> 110
> 401
> 119
> 117
>       114
> Any specific meaning attached to these values? I did not find any
> information on the pgRouting-workshop website [1].
> Thanks in advance.
> [1] http://workshop.pgrouting.org/chapters/topology.html
> Regards,
> -Jay Mahadeokar
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Anton Patrushev
CTO
eMail: anton.patrushev at georepublic.de
Web: http://georepublic.de
Tel: +49 (089) 420 959 519
Sip: 1959519 at sipgate.de
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
More information about the pgrouting-dev mailing list
