[pgrouting-dev] Fwd: How to build a web application using pgRouting for solving traffic problem
Stephen Woodbridge woodbri at swoodbridge.com
Fri May 6 10:10:54 EDT 2011
On 5/6/2011 3:53 AM, Daniel Kastl wrote:
> Probably this is a good start: http://workshop.pgrouting.org/
> <http://workshop.pgrouting.org/>Daniel
Yup, start here and break your project down into a series of steps like:
1. load the data
2. prepare the data
3. get a simple test working with your data
4. look at the list archives for how to generate textual driving
directions this will require extra work
5. editing the data - all the data is in DB tables so it is accessible
to changes, but you will need to think through how you want to build a
application that allows editing of the data - review the prepare data steps
see more inline below ...
> 2011/5/6 Vũ Khắc Tín <tinvukhac at gmail.com <mailto:tinvukhac at gmail.com>>
>     Dear all,
>     I 'm  a newbie in GIS and pgRounting.I have a problem and can you
>     support for me?
>     I 'm developping a web application.My desire is buiding a web with
>     this functions:
Look at using OpenLayers for a Javascript API for mapping and to build
your application GUI in. This supports Google but also allows you to
build an application the is not locked into one vendor.
>     1.Find shortest path in any time( support for traffic problem),
>     "shortest" mean time,cost...
By traffic to you mean getting traffic feeds and dynamically adjusting
segment speeds? or are you just trying to say your want to solve general
vehicle routing problems?
>     2.Allow me change data.
>     This is similar google map,but I want to use my data(download from
>     OpenStreetMap),and use pgRoungting to route in that data,then use
>     Google Map API for display the result.
See my order of steps above. You will have to design and build an
application that interacts with the user making changes and generate
ajax requests to some server code that updates the database, then
refresh you screen to the changes from the database.
>     Can you help me? how to use pgRouting in OpenStreetMap data?
There are some tools the support loading OpenStreetMap data into pgRouting:
http://www.google.com/#q=osm2pgrouting
> How to
>     change data? How to return result similarly google?
>     Ex : When I find shortest path in Google Map,they draw path in map
>     and a set of drections:
>                    1.Turn left    A    100m
>                    2.Turn right  B     200m
>                    3.Go ahead   C    300m
>     Can pgRouting do that?
pgRouting does not do this out of the box, but it is possible to do it
and has been discussed in the list. search the list archives for
"driving directions". You can look at an example I built here:
http://tinyurl.com/3dz7zbk
Summary, You can do all of this but the project you have outline is very
big and you need to break it down into smaller pieces that you can focus
on one at a time. Some of the steps are not supported directly and those
you will have to write yourself. You will need skills in Javascript,
Openlayers, postgresql/postgis, pgrouting, and writing ajax handlers (I
use php for this).
Hope this helps,
   -Steve
>     Thank for read my email !I hope you support me early.
>     PS: Sorry if my English is bad!
>     Vũ Khắc Tín
>     K53,Department of Software Engineering ,
>     School of Information and Communication Technology,
>     http://soict.hut.edu.vn/
>     Hanoi University of Science and Technology,Vietnam,
>     http://www.hut.edu.vn <http://www.hut.edu.vn/>
>     Email: tinvukhac at gmail.com <mailto:tinvukhac at gmail.com>
>     Y!ID: Xitrum_rapper91
>     Skype: vu.khac.tin
>     Mobile: +84 168 990 4684
More information about the pgrouting-dev mailing list
