[pgrouting-dev] Re: Implementation of core Time Dependent
Dijkstra function
Jay Mahadeokar
jai.mahadeokar at gmail.com
Fri May 13 02:03:04 EDT 2011
On Thu, May 12, 2011 at 8:08 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> *Few thoughts regarding implementation:*
>> Most important detail which needs to be finalised is the implementation
>> of dynamic weight map.
>> 1. Now, since the weight is function of time, the weight map is now like:
>> Key: (Edge , Time) - Since edge and time will form a unique key.
>> Value: weight
>> Is this interpretation reasonable?
> This seems reasonable. The only extension to this that would be valuable
> would to add a "class" to the key to allow filtering by traveler class. So
> something like Key: (Class, Edge, Time) where the default class is "Any".
> Hmmm, on second thought, it might be a better abstraction to use the Boost
> Filtered Graph to do this and keep your code simple because it is working in
> a tighter loop.
Can you please explain what exactly do you mean by traveler class? Is it
like - bus, 2-wheeler etc (they might have different costs at same time) .
I am assuming that user will query only those entries(Edge,Time) that are
useful. So, if he is querying for 2-wheeler, he should specify that in
query, so that only entries related to that class are passed to boost graph
and rest are filtered out already.
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110513/6e3a3cbd/attachment.html
More information about the pgrouting-dev
