[pgrouting-dev] GSoC branches and unit tests
Daniel Kastl daniel at georepublic.de
Mon May 23 11:19:25 EDT 2011
Hi Kishore and Jay,
I created one branch for each project:
   - gsoc-multimodal
   - gsco-tdsp
Both branches contain Kishore's unit tests.
And I also just fixed an error with linking to CGAL, that was new with
Ubuntu 11.04.
You can either work directly in the pgRouting repository branches or, as you
did in the past, have a fork in your own GitHub account.
That's up to you and what you think is more convenient.
Daniel
2011/5/23 Jay Mahadeokar <jai.mahadeokar at gmail.com>
> On Mon, May 23, 2011 at 8:23 AM, Daniel Kastl <daniel at georepublic.de>wrote:
>> Kishore started adding unit tests as described here:
>> https://github.com/pgRouting/pgrouting/wiki/Automated-Testing-%28Unit-Tests%29
>> Three libraries are used: CUnit, CTest and Python "unittest".
>> As explained in the document, each library seems to have its advantages.
>> I'm probably most concerned about adding Python as another language.
>> No problem? Recommendations? Any thoughts?
>> And I merged the changes into a branch called "unittests":
>> https://github.com/pgRouting/pgrouting/network
>> Maybe someone is interested to test it and/or give some comments.
>> I would take the "unittests" branch as base for creating the GSoC project
>> branches. (@Jay: is that OK for you?)
> Sure.
>> Thanks a lot to Kishore and Jay, who are doing a great GSoC!
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Regards,
> -Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110524/8c0d141d/attachment.html
More information about the pgrouting-dev mailing list
