[pgrouting-dev] Do we need a new and better TSP?
Jay Mahadeokar jai.mahadeokar at gmail.com
Sat Sep 17 14:02:06 EDT 2011
On Sat, Sep 17, 2011 at 11:20 PM, Daniel Kastl <daniel at georepublic.de>wrote:
> Hi list,
> On Friday at FOSS4G in Denver I discussed with Steve about TSP, and I want
> to share a bit of what we came up with:
>    - According to Steve there is a way to solve TSP without GA (Genetic
>    Algorithm), and that way we could get rid off GAUL dependency and make it a
>    "core" function.
> I believe TSP is a NP Complete problem. So a polynomial time solution does
not exist. Steve, can you elaborate what heuristic might be used besides GA?
>    - Instead of calculation of a distance matrix within the TSP function,
>    the distance matrix could be passed as a "SELECT". Then the user could
>    decide the way distances should be calculated. And APSP would be a nice way
>    to calculate a distance matrix for example.
> +1 for use of APSP!
> Any other ideas how to improve the current implementation of TSP?
> Do you have some other use cases with specific requirements?
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110917/ab6c2534/attachment.html
More information about the pgrouting-dev mailing list
