[pgrouting-dev] Introducing myself
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Apr 23 00:16:32 EDT 2012
Hi Razequl,
I can be slow when I'm distracted by other things - I did not connect
Razequl as being the same person as Khondoker that you proposal was
submitted under until now when I was reviewing your proposal again. So
please ignore my first bullet below and accept my apology.
I have developed some test cases for the TRSP algorithm and we might be
able to use them as tests for the bidirectional algorithm. I also have
extensive datasets covering large areas that we can potentially use for
performance testing.
Thank you for your introduction.
Best regards,
-Steve
On 4/22/2012 2:01 PM, Stephen Woodbridge wrote:
> Hi Razequl,
> I have a few of comments in no particular order:
> * We have a GSoC student that has proposed a project to do a
> Bi-directional routing algorithm and we should know by tomorrow if that
> was accepted or not. That said, while if it is accepted then having two
> is a little redundant unless one supports turn restrictions like TRSP
> and one does not.
> * Boost as the advantage that is a generic library that is well tested
> and most of the development is about how to use the library to do what
> you want. On the other hand it is more restrictive if you want to do
> something similar to Boost but not supported in the existing code. You
> might be able to reuse some of the TRSP code which would be good if you
> can do that.
> * Testing - I think you need to consider making some simple unit test
> examples that allow you to validate your code. This would be a
> collection of tests that you can apply to a relatively simple network
> that is easy to debug and trace the execution. Once this is done and
> working it is reasonable to throw a larger network like osm2pgrouting to
> look at performance tuning.
> * One of the keys to making quality releases is our ability to automate
> sanity testing of the code before we release it. While we do not have
> any automated testing yet, it is very high on my list of things that
> need to get done, so I will be pushing everyone to support this.
> As Jay said, if you have any specific questions that we can help with,
> please ask on the list.
> Best regards,
> -Steve
> On 4/22/2012 1:00 PM, Razequl Islam wrote:
>> Hi Jay,
>> Thanks for your reply and suggestion. I have already gone through the
>> source of basic dijkstra, A* and the new variant trsp (turn restricted
>> shortest path) as suggested by Steve. I found that dijkstra and A* has
>> been implemented using the boost library while trsp has its own
>> structure and implementation. It also uses STL for priority queue. I am
>> thinking of implementing like trsp using my own data structure.
>> I am still playing with these. I need some sample database, I am trying
>> to install osm2pgrouting but struggling.
>> Thanks for your help once again.
>> Razequl
>> On Sat, Apr 21, 2012 at 12:34 AM, Jay Mahadeokar
>> <jai.mahadeokar at gmail.com <mailto:jai.mahadeokar at gmail.com>> wrote:
>> Hi Razequl,
>> Welcome to pgRouting. Good implementation of Bi-directional
>> searching algorithm will be a very useful addition to pgRouting. I
>> would suggest you to:
>> - See the pgRouting source.
>> - Study typical pgRouting algorithm implementation link
>> shortest_path, play around with it, compile and debug etc. You will
>> need to use cmake and other tools for the same.
>> - Think about design the data structures and modules that will be
>> needed for Bi-directional algorithm implementation and discuss the
>> same in the list.
>> Steve and Daniel will surely provide useful insights and guidance
>> for you. :-)
>> Let us know if you have any queries.
>> Regards,
>> On Fri, Apr 20, 2012 at 10:12 PM, Razequl Islam
>> <ziboncsedu at gmail.com <mailto:ziboncsedu at gmail.com>> wrote:
>> Hi,
>> I am Razequl Islam, student of Dhaka university, Bangladesh. I
>> am new to the group. I am interested in implementing bi
>> directional searching algorithms in pgrouting, Your feedback and
>> suggestions are welcome.
>> Best Regards,
>> Razequl
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> -Jay Mahadeokar
>> Mtech, II Year,
>> IIT Kanpur,
>> India.
More information about the pgrouting-dev
