[pgrouting-dev] GSoC Timeline
Jay Mahadeokar jai.mahadeokar at gmail.com
Mon Apr 23 22:33:34 EDT 2012
Hi Jinfu and Razequl,
Congrats again for getting the project accepted.
Daniel and Steve have already given most of the instructions in detail. I
would say most important steps are - learning to compile any existing
pgRouting algorithm and debugging it. Make sure you are able to print out
additional debug messages from your core function, since that will be most
helpful in the future. Let me know if you have problems with that.
Next I would suggest you plan out the design and exact prototype of your
implementation. Last year I had this:
https://github.com/pgRouting/pgrouting/wiki/TDSP-Details
This can be modified a bit when you implement but most of the ideas should
be conveyed with this.
Best of luck!
On Tue, Apr 24, 2012 at 7:48 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Jinfu, Razequl,
> First of all congratulations!
> And thank you, Steve, for this post.
> Just let me add a little additional information:
> OSGeo as mentoring organization wants to help students to pass milestones
> and deadlines.
> For that we often have OSGeo internal deadlines a few days ahead of GSoC
> deadlines. And OSGEo also requires weekly reports.
> All this can help you not to run out of time at the end of the GSoC
> program.
> What really helps is to being ahead of deadlines. Ask Jay! ;-)
>> http://download.osgeo.org/**pgrouting/forum/pgrouting.**postlbs.org/wiki/
>> **pgRoutingDocs.html<http://download.osgeo.org/pgrouting/forum/pgrouting.postlbs.org/wiki/pgRoutingDocs.html>
> Steve pointed you to the previous (cached) website Wiki.
> The newer (and slightly updated and revised one) should be here:
> http://www.pgrouting.org/documentation.html
> If you don't have a GitHub account yet, create one and let me know your
> account ID.
> You can then use also pgRouting's GitHub Wiki pages for planning and
> documenting your project. If you like you can use the issue tracker as well.
> Here is a link to last year's GSoC projects documented in the Wiki:
> https://github.com/pgRouting/pgrouting/wiki/Multi-modal-Public-Transit-Routing
> https://github.com/pgRouting/pgrouting/wiki/Time-dependent---Dynamic-Shortest-Path
> There is no required structure, so you can organize it as you like.
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120424/e74ac525/attachment.html
More information about the pgrouting-dev mailing list
