[pgrouting-dev] redundant core sql functions
Mario Basa
mario.basa at gmail.com
Mon Jul 2 00:02:21 PDT 2012
Hello,
The core wrapper functions have
dijkstra_sp_delta_directed
astar_sp_delta_directed
with "length" hard coded as cost for some reason.
While astar_sp_delta_cc has a cost column parameter, but all it does
is call astar_sp_delta_cc_directed with
reverse_cost=false,directed=false.
There is also no dijkstra_sp_delta_cc with a cost column parameter, so
a user has to rename the column containing the cost value to "length"
to use this clipping function. Etc....
Personally I am getting confused with all these functions and would
like to just trim it down to dijkstra_sp_delta and astar_sp_delta with
a cost column parameter along with reverse_cost and directed
parameters.
Opinions?
Mario.
More information about the pgrouting-dev
