[pgrouting-dev] redundant core sql functions
Mario Basa mario.basa at gmail.com
Mon Jul 2 00:28:37 PDT 2012
Daniel,
I agree. Right now it really is quite confusing which function to use,
and the description of each function is not also very helpful.
I am curious though why is it that there is no sp function that
accepts source_x,source_y and target_x,target_y parameters similar to
that of driving_distance. This I think, will be very useful.
Mario.
On Mon, Jul 2, 2012 at 4:11 PM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Mario,
> In my opinion I would drop functions like the one you mentioned and reduce
> the number of wrappers as much as possible.
> I think a good and useful wrapper function is one, that selects a BBOX
> containing start and end point and returns records with geometries.
> Then everyone can modify it as needed. I don't think we should simplify
> those basic wrappers and make assumptions like naming the cost column
> "length" or so.
> What do you think?
> Daniel
> On Mon, Jul 2, 2012 at 9:02 AM, Mario Basa <mario.basa at gmail.com> wrote:
>> Hello,
>> The core wrapper functions have
>> dijkstra_sp_delta_directed
>> astar_sp_delta_directed
>> with "length" hard coded as cost for some reason.
>> While astar_sp_delta_cc has a cost column parameter, but all it does
>> is call astar_sp_delta_cc_directed  with
>> reverse_cost=false,directed=false.
>> There is also no dijkstra_sp_delta_cc with a cost column parameter, so
>> a user has to rename the column containing the cost value to "length"
>> to use this clipping function. Etc....
>> Personally I am getting confused with all these functions and would
>> like to just trim it down to dijkstra_sp_delta and astar_sp_delta with
>> a cost column parameter along with reverse_cost and directed
>> parameters.
>> Opinions?
>> Mario.
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
More information about the pgrouting-dev mailing list
