[pgrouting-dev] Questions
Daniel Kastl
daniel at georepublic.de
Sun Jun 3 04:51:06 PDT 2012
Hi Jinfu,
pgRouting uses Cmake (www.cmake.org) and it's a good idea to look into the
Cmake documentation. There are probably things that can be done even better
with the current Cmake install files.
pgRouting has two types of "algorithms": those part of "core" and those
part of "extra". To install algorithm part of "extra" a compile flag like
"--with-tsp" is used.
The reason to have "core" and "extra" was, that some algorithms required
other libraries such as GAUL or CGAL and it was sometimes a bit complicated
to get them installed. So we put them into "extra" that pgRouting could be
compiled more easily for those, who only needed shortest path functions.
On the long term it would be nice to get rid of dependencies like CGAL and
we could forget about "extra" and just compile all function.
So I would propose that every algorithm that has no new dependencies should
be compiled by default and doesn't get a compile flag.
Daniel
On Sun, Jun 3, 2012 at 3:42 AM, Jinfu Leng <logicnut at gmail.com> wrote:
> Hey,
> I wrote some codes for the new algorithm, but I do not know how to
> integrate it to pgRouting. I am not familiar with the Linux programming. I
> mean, which files should I edit, and then when I install pgRouting again,
> the new source code will be compiled and integrated.
> Thanks,
> Jinfu
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120603/f1c4c17a/attachment.html>
More information about the pgrouting-dev
