[pgrouting-dev] First version of bi-directional dijkstra
Daniel Kastl daniel at georepublic.de
Sun Jun 10 01:59:10 PDT 2012
Hi Razequl,
As long as you try and test Git with your personal fork in your GitHub
account, you can't do anything wrong.
Also, as long as you don't do a "git push ..." everything is only on your
local repository and not on the GitHub repository.
What does "git remote -v" return? Does it return something like
origin git at github.com:zibon/pgrouting.git (fetch)
origin git at github.com:zibon/pgrouting.git (push)
Usual steps are:
   1. git status
   (tellys you which files have been modified and files that have not been
   added yet)
   2. git add .
   (add all files that have not been added yet ... or just specify the
   files/directories you want to add)
   3. git commit -m "message" .
   (commit all files that have not been added yet ... or just specify the
   files/directories you want to commit)
   4. git pull <repository> <branch>
   (this will either tell you all is up-to-date, or merge was successful or
   tell you there was a merge conflict, that you need to resolve)
   5. git push <repository> <branch>
   Push the changes to the repository)
The default repository is named "origin", the default branch "master".
Can you once try all the 5 steps above and see if it solves your problem?
Daniel
On Sun, Jun 10, 2012 at 4:18 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi Razequl,
> I will look at it tomorrow night late if I have a chance. Jay if you can
> make some time to review and comment that would be great also.
> I only have limited access at the moment and my favor gitref.org site was
> broken last I checked. So off the top of my head I think the commands are
> something like:
> git add <list of files>
> git commit
> git push origin master
> I think you can also do something like
> git -A commit
> which will commit all changed files, but you still probably new the git
> add for any new files you want to add to your directory.
> So read the docs and see if the above works.
> Thanks and congratulations for getting this far.
> -Steve
> On 6/9/2012 3:46 AM, Razequl Islam wrote:
>> Hi Steve,
>> 1.I implemented the first version bi directional shortest path using
>> dijkstra and attached the source code in this mail. Please have a look
>> and let me know your feedback.
>> 2. i tried to merge my source code to
>> https://github.com/zibon/**pgrouting <https://github.com/zibon/pgrouting>.
>> but failed.
>> I have checked out the fork the local folder and created my source
>> directory bdsp under the extra folder. Then
>> i tried the following command:
>> After a few time it said that 'Everything up-to-date', but found no bdsp
>> folder in https://github.com/zibon/**pgrouting/tree/master/extra<https://github.com/zibon/pgrouting/tree/master/extra>
>> 3.I just copied my source code folder to my local repo directory. Is it
>> necessary to commit every single file of my folder. If so then what is
>> the procedure?
>> regards
>> razequl
>> ______________________________**_________________
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120610/5e0459f9/attachment.html>
More information about the pgrouting-dev mailing list
