[pgrouting-dev] can not find the definition of the function
Daniel Kastl
daniel at georepublic.de
Thu Jun 14 04:37:27 PDT 2012
Have you looked at the "CMakeLists.txt", which you can find in pretty much
every directory?
Daniel
On Thu, Jun 14, 2012 at 1:21 PM, Jinfu Leng <logicnut at gmail.com> wrote:
> Hello Jay,
> Thanks very much.
> You need to create a .sql file and write function definition.
> I did not know how to create the .sql file. I added the definition of the
> function:
> CREATE OR REPLACE FUNCTION shortest_path_mild_two_q(sql text, source_id
> integer,
> target_id integer, directed boolean, has_reverse_cost boolean)
> RETURNS SETOF path_result
> AS '$libdir/librouting'
> LANGUAGE 'C' IMMUTABLE STRICT;
> to the file "rounting_core.sql".
> Modify cmakelists accordingly.
> Which cmakelists.txt file are you referring to? I updated the
> cmakelists.txt file in the folder "core/src".
> It is not working right now.
> Jinfu
> On Thu, Jun 14, 2012 at 11:32 AM, Jay Mahadeokar <jai.mahadeokar at gmail.com
> > wrote:
>> Hi Jinfu,
>> It seems that your function is not created in postgres database. You need
>> to create a .sql file and write function definition. Modify cmakelists
>> accordingly.
>> If you have already done that, and didn't work, try adding it by giving
>> the command at sql prompt. Check out the documentation in apsp page in
>> pgrouting wiki for exact commands.
>> On 14 Jun 2012 07:52, "Jinfu Leng" <logicnut at gmail.com> wrote:
>>> Hey,
>>> I am writing the code for the new algorithm. I added the name of the
>>> file to the file "CMakeLists.txt", and then the file can be compiled. In
>>> pgAdmin3, I can call the function shortest_path(), but when I tried to call
>>> my function shortest_path_mild_two_q(), I got the error message "no matched
>>> function".
>>> My question is, besides "CMakeLists.txt", what else should I do to let
>>> the system know there is a function named shortest_path_mild_two_q().
>>> Thanks,
>>> Jinfu
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120614/9eb527f1/attachment.html>
More information about the pgrouting-dev
