[pgrouting-dev] postgis2 and driving distance
Mario Basa
mario.basa at gmail.com
Thu Jun 21 01:38:41 PDT 2012
cool. thanks Steve.
Mario.
On Wed, Jun 20, 2012 at 11:15 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> You should be able write a simple wrapper for st_startpoint like:
> create or replace function pgr_startpoint(line geometry)
> returns geometry as
> $body$
> declare
> pnt geometry;
> begin
> if geometrytype(line) = 'LINESTRING' then
> pnt := st_startpoint(line);
> elsif geometrytype(line) = 'MULTILINESTRING' then
> pnt := st_startpoint(st_geometryn(line,1));
> else
> return null;
> end if;
> return pnt;
> end;
> $body$
> language plpgsql stable;
> I think we need to support MULTILINESTRING because the shapefile loader
> creates then by default. I understand that "real" MULTILINESTRING objects
> may not make sense but we can also just state the ALL MULTILINESTRING
> objects will be treated as those it is a valid contiguous path from start
> point to end point and that it is the users responsibility for model the
> graph correctly if they have a different interpertation of what a
> MULTILINESTRING means in their models.
> -Steve
> On 6/20/2012 2:37 AM, Daniel Kastl wrote:
>> Hi Mario,
>> Thank you for this information!
>> Which files exactly do you mean with "wrapper sql files"?
>> So this means the line geometry MUST be LINESTRING from now? Or is there
>> an alternative function to ST_startpoint?
>> Maybe it's better that import tools like osm2po create a correct
>> geometry type as MULTILINESTRING doesn't make sense really for a routing
>> network anyway.
>> In the past it just didn't matter if you had LINESTRING or
>> MULTILINESTRING, right?
>> I will create a ticket for this.
>> Daniel
>> On Wed, Jun 20, 2012 at 5:40 AM, Mario Basa <mario.basa at gmail.com
>> <mailto:mario.basa at gmail.com>> wrote:
>> Daniel,
>> You might want to limit st_startpoint usage in your devel-2.0
>> wrapper sql files. According to documentation:
>> Changed: 2.0.0 no longer works with single geometry
>> multilinestrings. In older versions of PostGIS -- a single line
>> multilinestring would work happily with this function and return the
>> start point. In 2.0.0 it just returns NULL like any other
>> multilinestring. The older behavior was an undocumented feature, but
>> people who assumed they had their data stored as LINESTRING may
>> experience these returning NULL in 2.0 now.
>> I used osm2po to create the Japan networks and am getting nulls when
>> I use st_startpoint.
>> Mario.
>> On Tue, Jun 19, 2012 at 6:10 PM, Daniel Kastl <daniel at georepublic.de
>> <mailto:daniel at georepublic.de>> wrote:
>> Hi Mario,
>> I think it's a good idea to drop CGAL if possible ... and you
>> proofed that it is possible.
>> I guess that PostGIS 2.0 will soon become a standard, so if we
>> now want to make a bigger cleanup and new release of pgRouting
>> it's OK to require PostGIS 2.0 in my opinion. There haven't been
>> many questions about driving distance on the lists, so I assume
>> there are not so many users of this function either.
>> If you move it into "core" (which is a good idea), please don't
>> commit it into "master" branch for now.
>> I would propose to either make a different branch for that, that
>> we can merge later, or use "devel-2_0" branch, which already
>> contains code cleanup:
>> https://github.com/pgrouting/pgrouting/tree/devel-2_0
>> Daniel
>> On Tue, Jun 19, 2012 at 11:11 AM, Mario Basa
>> <mario.basa at gmail.com <mailto:mario.basa at gmail.com>> wrote:
>> Hi,
>> It really is possible now to take away CGAL from pgRouting
>> since st_concavehull of PostGIS 2 can create the same alpha
>> shape. I have already managed to compile diriving-dist
>> without CGAL installed by modifying the cmake files and
>> drivedist.c.
>> I used this:
>> select st_concavehull(st_collect(
>> st_geomfromewkt('srid=4326;POINT('||x1||'
>> '||y1||')')),0.7) from jp_2po_4pgr,
>> driving_distance('SELECT
>> id,source,target,cost,reverse_cost from jp_2po_4pgr
>> where
>> st_contains(ST_GeomFromEWKT(''SRID=4326;POLYGON((139 35,139
>> 36,140 36,140 35,139 35))''),
>> the_geom) = true',156598,0.07,false,false) where id =
>> edge_id;
>> to create the drive time polygon in the attached screen
>> dump. The performance isn't so bad even with a 0.7 target
>> percent parameter for the concave hull.
>> I am planning to clean up routing_dd.sql and
>> routing_dd_wrapper.sql and start using the newer st_*
>> postgis functions.
>> Will there be any objections if I move routing_dd into core
>> instead of extra since it will now only use BOOST to compile.
>> Mario.
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> <mailto:pgrouting-dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> <mailto:daniel.kastl at georepublic.de>
>> Web: http://georepublic.de <http://georepublic.de/>
>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
More information about the pgrouting-dev
