[pgrouting-dev] GSoC Timeline
Stephen Woodbridge woodbri at swoodbridge.com
Tue May 22 00:31:28 EDT 2012
Hi Razequl,
I will try to pull together a simple test case for TRSP, I have created
a couple I used for testing and debugging the code. Like wise for
documentation. I have posted to the list documentation on TRSP because
we have other people using it. I see about finding that and posting it
on the wiki if it is not already on the wiki. I think this is one of the
posts I am thinking of:
http://http-lists-osgeo-org-pipermail-pgrouting-dev.974090.n3.nabble.com/pgrouting-dev-TRSP-rule-vs-via-path-and-other-documentation-td3809866.html
http://http-lists-osgeo-org-pipermail-pgrouting-dev.974090.n3.nabble.com/pgrouting-dev-pgRouting-Development-Environment-td3713327.html
-Steve
On 5/19/2012 6:16 PM, Razequl Islam wrote:
> Hi Steve,
> Thanks for your suggestion. I've merged trsp branch with pgrouting
> master branch. But haven't run this functionality for the lacking of
> turn restricted network data. If possible please help me giving some
> turn restricted network data file thus i can apply this
> functionality(trsp) on these data.
> And the other thing, if there is any documentation for trsp, please give
> me the link.It will help.
> thanks
> Razequl
> On Thu, May 17, 2012 at 2:31 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Hi Razequl,
>     It is good to here that you have got your course work almost done
>     and it sounds like you are making excellent progress getting started
>     with pgrouting.
>     Regarding the trsp it is in a branch called trsp so you probably
>     need to do something like:
>     cd /path/to/pgrouting-git/
>     #git checkout master
>     #git pull
>     git checkout trsp
>     #git merge master
>     cmake -DWITH_TRSP=ON .
>     make
>     sudo make install
>     Let me know if you have questions.
>     Thanks,
>       -Steve
>     On 5/16/2012 4:10 PM, Razequl Islam wrote:
>         Hi Steve,
>         Sorry for being late to reply. I was busy for some academic purposes
>         which are almost end. Now i can give the full time for this project.
>         I am using ubuntu 12.04 LTS now. I hope it will not cause any
>         problem in
>         future as it is the very latest version of Ubuntu. I have already
>         installed the pre-requirement for pgrouting. and compiled
>         pgrouting core
>         as it says in the documentation. I found a great help from
>         Github for
>         completing this process. But stuck at adding functionality of
>         TRSP.  I
>         haven't found any TRSP section in ~/pgrouting/extra/ directory. How
>         could i add this functions. Please help.
>         I have already gone through the Workshop+Tutorial.
>         now i am working on making the design and prototype of the
>         implementation. I will up it to gitub wiki in between 1 or 2 days.
>         Thanks
>         Razequl
>         On Tue, Apr 24, 2012 at 7:37 AM, Stephen Woodbridge
>         <mailto:woodbri at swoodbridge. com
>         <mailto:woodbri at swoodbridge.com>>> wrote:
>             Jinfu, Razequl,
>             Since I was just updating my calendar with critical GSoC
>         dates from
>             here:
>         http://www.google-melange.com/ gsoc/document/show/gsoc_
>             program/google/gsoc2012/faqs# timeline
>         <http://www.google-melange. com/gsoc/document/show/gsoc_
>         <http://www.google-melange.com/gsoc/document/show/gsoc_program/google/gsoc2012/faqs#timeline>>
>             I thought I would pass this on to you in case you do not have it
>             handy. Please make sure you have these dates in your
>         calendar so you
>             can plan around them. Many of these are hard deadlines that
>         we need
>             to meet to keep your project in good standing with Google.
>             I'm sure you guys are busy with exams and curriculum
>         deadlines but
>             between now and May 21th is also your time to get a head
>         start on
>             your projects by reading pgRouting documentation, code,
>         setting up a
>             build and test environment, getting to know us better, asking
>             questions, etc. This is a good time to think about how you will
>             actually break down you project in detail and discuss that
>         with us.
>             We like to use the pgrouting-dev list for general discussions
>             because then you can get responses for Daniel, Jay and/or
>         myself and
>             other users and developers my have some valuable insights
>         also. Any
>             given question/answer is likely to provide insight to others as
>             well. Also, Daniel is in Japan, I am in the Boston, Mass USA
>         area,
>             and I think Jay is in India. Given the wide range of
>         timezones, we
>             are more likely to get you answers quicker by using the list.
>             How to get started:
>             0. Read these:
>         https://github.com/pgRouting/ pgrouting/wiki/Developer---
>             Getting-Started
>         <https://github.com/pgRouting/ pgrouting/wiki/Developer---
>         Getting-Started
>         <https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started>>
>         http://download.osgeo.org/ pgrouting/forum/pgrouting.
>         postlbs.org/wiki/ <http://postlbs.org/wiki/> pgRoutingDocs.html
>         <http://download.osgeo.org/ pgrouting/forum/pgrouting.
>         postlbs.org/wiki/ pgRoutingDocs.html
>         <http://download.osgeo.org/pgrouting/forum/pgrouting.postlbs.org/wiki/pgRoutingDocs.html>>
>             1. Let us know if you are using Linux or Windows? Linux is
>         easier
>             for us to support. So hopefully, you have access to a Linux
>         machine.
>             2. Check out the TRSP branch from github. - Need help? Ask :)
>             3. Build it. - Need help? Ask.
>             4. Install it. - Need help? Ask.
>             5. Try out the Workshops & Tutorials
>             6. I have some simple test cases for trsp, somewhere, I will
>         post a
>             link to download it.
>             7. Look at the flow of control from SQL, to plpgsql
>         function, to C
>             wrappers, to C++ code in the extra/trsp/* files. Ask
>         questions so
>             you understand this. You will need to mirror this flow for
>         your project.
>             8. start planning out your project in terms of how you will
>             integrate your code using the above trsp as a model.
>             Ok, this is a lot of stuff, but you have some time. My goal
>         here is
>             to lay out high level tasks in an order that will make your
>         project
>             flow smoothly. The key is communications. Please let us know
>         what
>             you are doing? We are here to help you and guide you to a
>         successful
>             conclusion.
>             Jay, Roni - since you have both been GSoC students and recently
>             worked on various projects in pgRouting, feel free to jump
>         in with
>             any thoughts hints, etc.
>             Best regards,
>               -Steve
>             ______________________________ _________________
>             pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>
>         <mailto:pgrouting-dev at lists. osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>>
>         http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>         <http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev> >
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
More information about the pgrouting-dev mailing list
