[pgrouting-dev] postgresql problems
Jinfu Leng
logicnut at gmail.com
Thu May 24 23:13:47 EDT 2012
Hey,
I got a new problem now,
When I was trying to create the database template with the .sh, I got the
error message:
"/usr/share/postlbs/routing_core.sql: No such file or directory"
I found that "postlbs" folder did not exist in my disk. According to
some archived emails, this is because "pgrouting" was not installed
successfully. But I think I have correctly compiled and installed it.
In addition, I found the ".sql" files located in my "usr/share/pgrouting"
folder. So for creating the database template, I can change the path in the
".sh" file and use these ".sql", but I am not sure if this will ruin the
later steps.
Thanks,
Jinfu
On Thu, May 24, 2012 at 10:24 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 5/24/2012 10:11 AM, Jinfu Leng wrote:
>> Hey all,
>> I am trying to use postgresql to build the network database, but got a
>> problem when I ran "createdb -U postgres -T template_routing routing".
>> Error message:
>> "createdb: could not connect to database postgres: FATAL: password
>> authentication failed for user "postgres""
>> I already used "passwd" to change the password of "postgres" and used
>> "trust" to replace "md5" in pg_hba file.
> 1. you have to restart postgresql after changing the pg_hba file.
> 2. you might try adding -h localhost to you command.
> -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120525/438c855d/attachment.html
More information about the pgrouting-dev
