[pgrouting-dev] Problems in Importing .osm to Database
Dave Potts dave.potts at pinan.co.uk
Tue May 29 23:34:49 PDT 2012
Hello,
>From the text of the error message, it appears your having a problem
connecting to your database, its not a pgroute package error but rather a
postgres error.
What happens if you try
psql -d routing -U postgres
This should connect directly to your database without using any of the
routing software.
Jinfu Leng wrote:
> Hello all,
> I created the database "routing" from the "template_routing", and
> downloaded the .osm file of London. But I got a problem when I was trying
> yo import this .osm file to the database.
> command:
> "osm2pgrouting -file "London.osm" -conf
> "/usr/share/osm2pgrouting/mapconfig.xml" -dbname routing -user postgres
> -clean"
> error message:
> "connection failed"
> Any ideas?
> Thanks a advance.
> Jinfu
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
