[pgrouting-dev] Which versions of cgal, gaul and boost should be used to compile pgrouting on Ubuntu 12-4
Stephen Woodbridge woodbri at swoodbridge.com
Thu Oct 25 08:34:34 PDT 2012
Hi Dave,
One of the down sides of git is that everyone can clone and branch the
repository and without some dedicated to managing a release it is hard
to keep up with all the changes. I know I have not had time to keep up
with it all. On my server which is old and dated I run boost 1.34,
gaul-devel-0.1849-0, and libcgal-dev 3.3.1-4.
Mario Basa had been working on pulling together a lot of the changes and
updates targeted toward a 2.0 release, but I believe he go side tracked
with other project work. Maybe Mario or Daniel can update us on that effort.
Best regards,
   -Steve
On 10/25/2012 9:29 AM, Dave Potts wrote:
> Hi
> I am trying to add intergrate some code to add support for the K
> shortest-path problem to pg route.
> There are lots of branches in git archive
> https://github.com/pgRouting/pgrouting.git which version is the most
> stable?
> I am aware that the default versin 1.05 does not appear to compile with
> the current support libraries due to changes in the library api.  I have
> no desire to repeat work thats already been done.
> regards
> Dave.
> Dave Potts wrote:
>> Hi,
>> I am trying to build from source and I am getting compiler errors.
>> Which  versions of boost, cgal and gaul should be used to build the
>> pgrouting software?
>> My build platform is 64 Ubuntu 12.4, gcc 4.6.3.
>> Dave.
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
