[pgrouting-dev] Issue with compiling 64-bit under mingw64
Paragon Corporation
lr at pcorp.us
Sun Apr 7 09:12:11 PDT 2013
Steve,
This might be a false alarm.
I was using my local copy instead of the updated one you had
makepgroutingw64.sh, but with your version it compiles.
I noticed my local had
cmake -G "MSYS Makefiles" -DWITH_DD=ON -DWITH_TSP=ON ..
And in your modified you had taken out the
-DWITH_TSP=ON
So after changing to:
cmake -G "MSYS Makefiles" -DWITH_DD=ON ..
it seemed to compile. However the librouting_tsp.dll is no longer being
generated as it was for the 32-bit.
I'm guessing this is part of your cleanup since it looks like you removed it
from the 32-bit as well (though my 32-bit with the -DWITH_TSP=ON still seems
to work and generates the additional dll.)
Thanks,
Regina
-----Original Message-----
[mailto:pgrouting-dev-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Sunday, April 07, 2013 8:40 AM
To: pgrouting-dev at lists.osgeo.org
Subject: Re: [pgrouting-dev] Issue with compiling 64-bit under mingw64
OK, so this problem is related to the fact that 64 bit is not including
INCLUDEDIR-SERVER = c:/ming32/projects/pgx32/pg92w32/include/POSTGR~1/server
because this is where 'ERROR' is defined in:
/c/ming32/projects/pgx32/pg92w32/include/postgresql/server/utils/elog.h
I'm not sure why 32 is different from 64. I'll look more at this
tonight/tomorrow. A simple fix might be wo make sure the CFLAGS includes the
equivalent of "-I ${INCLUDEDIR-SERVER}"
-Steve
On 4/6/2013 11:54 PM, Stephen Woodbridge wrote:
> On 4/6/2013 10:44 PM, Paragon Corporation wrote:
>> Steve,
>> We were able to compile pgRouting under mingw64-w64 chain before git
>> pulling, but last pull and recompile gave us this error
>> c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c: In function
>> 'findEulerianPath
>> c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:183:14: error: 'ERROR'
>> undeclared (first use in this function)
>> c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:183:14: note: each
>> undeclared identifier is reported only once for each function it
>> appears in
>> 'find_tsp_solution':
>> c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:446:18: error: 'FATAL'
>> undecla
>> make[2]: *** [src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.obj]
>> Error 1
>> make[1]: *** [src/tsp/src/CMakeFiles/routing_tsp.dir/all] Error 2
>> make: *** [all] Error 2
>> So not sure what we are missing here. Strangely enough (unless we
>> did something different), the same code base compiles fine Under
>> mingw64-w32 chain.
> I'll sort this out on Monday when I'm and have access to my 64bit
> setup. I'm thinking that maybe -I... might be different or maybe a
> missing header file. Should be easy to resolve.
> Thanks,
> -Steve
> pgrouting-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
