[pgrouting-dev] Issue with compiling 64-bit under mingw64
Stephen Woodbridge woodbri at swoodbridge.com
Sun Apr 7 17:19:42 PDT 2013
Ok, I just got back and I have the same problem on 64bit now that I have
a system to check it on.
-DWITH_TSP=ON  should not be included any more. I may have forgotten to
take it out of makepgroutingw64.sh
After looking at the compile error on 64 bit for 6 hours, I'm either
totally missing something obvious or this is looking like GNU compiler bug.
If you run the tools/makepgroutingw64.sh and then after it bombs:
cd build
make VERBOSE=1
and this will should you something like:
Scanning dependencies of target routing_tsp
[ 66%] Building C object src/tsp/src/CMakeFiles/routing_tsp.dir/tsp.c.obj
[ 73%] Building C object src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.obj
c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c: In function
'findEulerianPath':
c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:183:14: error: 'ERROR'
undeclared (first use in this function)
c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:183:14: note: each
undeclared identifier is reported only once for each function it appears in
'find_tsp_solution':
c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:446:18: error: 'FATAL'
make[2]: *** [src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.obj] Error 1
make[1]: *** [src/tsp/src/CMakeFiles/routing_tsp.dir/all] Error 2
make: *** [all] Error 2
woodbri at imaptools /c/ming64/projects/pgrouting
$ cd build
woodbri at imaptools /c/ming64/projects/pgrouting/build
$ make VERBOSE=1
/C/ming64/msys/bin/cmake.exe -H/C/ming64/projects/pgrouting
-B/C/ming64/projects/pgrouting/build --check-build-system
CMakeFiles/Makefile.cmake 0
/C/ming64/msys/bin/cmake.exe -E cmake_progress_start
/C/ming64/projects/pgrouting/build/CMakeFiles
/C/ming64/projects/pgrouting/build/CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[1]: Entering directory `/c/ming64/projects/pgrouting/build'
make -f src/shooting_star/src/CMakeFiles/shooting_star.dir/build.make
src/shooting_star/src/CMakeFiles/shooting_star.dir/depend
make[2]: Entering directory `/c/ming64/projects/pgrouting/build'
/C/ming64/msys/bin/cmake.exe -E cmake_depends "MSYS Makefiles"
/C/ming64/projects/pgrouting/src/shooting_star/src
/C/ming64/projects/pgrouting/build/src/shooting_star/src
/C/ming64/projects/pgrouting/build/src/shooting_star/src/CMakeFiles/shooting_star.dir/DependInfo.cmake
--color=
make[2]: Leaving directory `/c/ming64/projects/pgrouting/build'
make[2]: Nothing to be done for
`src/shooting_star/src/CMakeFiles/shooting_star.dir/build'.
/C/ming64/msys/bin/cmake.exe -E cmake_progress_report
/C/ming64/projects/pgrouting/build/CMakeFiles  11 12
[ 13%] Built target shooting_star
make -f src/trsp/src/CMakeFiles/trsp.dir/build.make
src/trsp/src/CMakeFiles/trsp.dir/depend
/C/ming64/projects/pgrouting /C/ming64/projects/pgrouting/src/trsp/src
/C/ming64/projects/pgrouting/build/src/trsp/src
/C/ming64/projects/pgrouting/build/src/trsp/src/CMakeFiles/trsp.dir/DependInfo.cmake
--color=
make[2]: Nothing to be done for `src/trsp/src/CMakeFiles/trsp.dir/build'.
/C/ming64/projects/pgrouting/build/CMakeFiles  13 14 15
[ 33%] Built target trsp
make -f src/astar/src/CMakeFiles/astar.dir/build.make
src/astar/src/CMakeFiles/astar.dir/depend
/C/ming64/projects/pgrouting /C/ming64/projects/pgrouting/src/astar/src
/C/ming64/projects/pgrouting/build/src/astar/src
/C/ming64/projects/pgrouting/build/src/astar/src/CMakeFiles/astar.dir/DependInfo.cmake
--color=
make[2]: Nothing to be done for `src/astar/src/CMakeFiles/astar.dir/build'.
/C/ming64/projects/pgrouting/build/CMakeFiles  1 2
[ 46%] Built target astar
make -f src/dijkstra/src/CMakeFiles/dijkstra.dir/build.make
src/dijkstra/src/CMakeFiles/dijkstra.dir/depend
/C/ming64/projects/pgrouting/src/dijkstra/src
/C/ming64/projects/pgrouting/build/src/dijkstra/src
/C/ming64/projects/pgrouting/build/src/dijkstra/src/CMakeFiles/dijkstra.dir/DependInfo.cmake
--color=
`src/dijkstra/src/CMakeFiles/dijkstra.dir/build'.
/C/ming64/projects/pgrouting/build/CMakeFiles  3 4
[ 60%] Built target dijkstra
make -f CMakeFiles/routing.dir/build.make CMakeFiles/routing.dir/depend
/C/ming64/projects/pgrouting/build /C/ming64/projects/pgrouting/build
/C/ming64/projects/pgrouting/build/CMakeFiles/routing.dir/DependInfo.cmake
--color=
make -f CMakeFiles/routing.dir/build.make CMakeFiles/routing.dir/build
make[2]: Nothing to be done for `CMakeFiles/routing.dir/build'.
[ 60%] Built target routing
make -f src/tsp/src/CMakeFiles/routing_tsp.dir/build.make
src/tsp/src/CMakeFiles/routing_tsp.dir/depend
/C/ming64/projects/pgrouting /C/ming64/projects/pgrouting/src/tsp/src
/C/ming64/projects/pgrouting/build/src/tsp/src
/C/ming64/projects/pgrouting/build/src/tsp/src/CMakeFiles/routing_tsp.dir/DependInfo.cmake
--color=
/C/ming64/projects/pgrouting/build/CMakeFiles 10
[ 66%] Building C object src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.obj
cd /C/ming64/projects/pgrouting/build/src/tsp/src &&
/c/ming64/mingw64/bin/gcc.exe  -Drouting_tsp_EXPORTS -O2 -g
-frounding-math @CMakeFiles/routing_tsp.dir/includes_C.rsp   -o
CMakeFiles/routing_tsp.dir/tsplib.c.obj   -c
/C/ming64/projects/pgrouting/src/tsp/src/tsplib.c
'findEulerianPath':
make[1]: Leaving directory `/c/ming64/projects/pgrouting/build'
So if I look at the commands that are getting executed you will notice
above on the gcc.exe there is:
This appears to be a way to include command line options from a file. So
I just copied the options from the file to the commandline in the next
command:
$ cd /C/ming64/projects/pgrouting/build/src/tsp/src
woodbri at imaptools /C/ming64/projects/pgrouting/build/src/tsp/src
$ /c/ming64/mingw64/bin/gcc.exe  -Drouting_tsp_EXPORTS -O2 -g
-frounding-math
-Ic:/ming64/projects/pgx64/pg92/include/postgresql/server
-IC:/ming64/projects/pgrouting/src/astar/src
-IC:/ming64/projects/pgrouting/src/dijkstra/src
-IC:/ming64/projects/pgrouting/src/shooting_star/src
-IC:/ming64/projects/pgrouting/src/tsp/src
-IC:/ming64/projects/pgrouting/src/driving_distance/src
-IC:/ming64/projects/pgrouting/src/trsp/src
-Ic:/ming64/msys/local/include/boost-1_46_1
-Ic:/ming64/projects/pgx64/pg92/include/postgresql/server/port/win32 -o
'findEulerianPath':
And tried to convert the "C:" to "/c" in this command:
-frounding-math
-I/c/ming64/projects/pgx64/pg92/include/postgresql/server
-I/c/ming64/projects/pgrouting/src/astar/src
-I/c/ming64/projects/pgrouting/src/dijkstra/src
-I/c/ming64/projects/pgrouting/src/shooting_star/src
-I/c/ming64/projects/pgrouting/src/tsp/src
-I/c/ming64/projects/pgrouting/src/driving_distance/src
-I/c/ming64/projects/pgrouting/src/trsp/src
-I/c/ming64/msys/local/include/boost-1_46_1
-I/c/ming64/projects/pgx64/pg92/include/postgresql/server/port/win32 -o
'findEulerianPath':
Lets check that the file exists, and it does. This file gets included
from postgres.h
$ /bin/find.exe /c/ming64/projects/pgx64/pg92/ -name postgres.h -print
/c/ming64/projects/pgx64/pg92/include/postgresql/server/postgres.h
$ /bin/find.exe /c/ming64/projects/pgx64/pg92/ -name elog.h -print
/c/ming64/projects/pgx64/pg92/include/postgresql/server/utils/elog.h
So I'm left with:
1. it works on 32 bit
2. the -Idirectory is included in the gcc
3. the include files exist in the correct places
4. gcc does not appear to be loading them, but I do not know why
Anyone run into this problem before?
Anyone have any ideas?
-Steve
More information about the pgrouting-dev mailing list
