[pgrouting-dev] Issue with compiling 64-bit under mingw64
Paragon Corporation lr at pcorp.us
Mon Apr 8 13:04:17 PDT 2013
Okay I have the pgRouting binaries up for both 32-bit and 64-bit 9.2 from
your latest git commit
http://winnie.postgis.net/download/windows/pg92/buildbot/
 with brief description:
http://postgis.net/windows_downloads
I won't release again until you reach another stable point, but I'll start
preparing the autobuild jobs.
Thanks,
Regina
-----Original Message-----
[mailto:pgrouting-dev-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Monday, April 08, 2013 1:04 PM
To: pgrouting-dev at lists.osgeo.org
Subject: Re: [pgrouting-dev] Issue with compiling 64-bit under mingw64
Yikes, bit bucket overflow, didn't remember doing that.
Anyway, I have made changes and check them in, and it compiles and tests on
both ming32 and min64 with pg92 and debian squeeze linux and pg8.4
So pull these changes. I have a few other things to tackle the next few days
so this should remain stable until I tackle the next chunk.
-Steve
On 4/8/2013 12:22 PM, Paragon Corporation wrote:
> I suspect the reason it worked fine for the mingw64-w32 is because I
> don't think MINGW64 is defined for the mingw64-w32 chain so was
> skipping that section anyway.
> Remember this ticket you helped me with:
> http://trac.osgeo.org/postgis/ticket/1668
> I had started off using __MINGW64__ and had to change to
> __MINGW64_VERSION_MAJOR  because the MINGW64 is only defined for the
> 64-bit chain.
> http://trac.osgeo.org/postgis/changeset/11218
> Hope that helps,
> Regina
> From: pgrouting-dev-bounces at lists.osgeo.org
> Woodbridge
> Sent: Monday, April 08, 2013 9:18 AM
> On 4/8/2013 4:06 AM, Paragon Corporation wrote:
>> Yeh it passes all tests on 64-bit
>> So I guess just need to figure out what to do with the line part.
>> #ifdef __MINGW64__
>> #define ELOG_H
>> #include <winsock2.h>
>> #endif
> Ok, so I guess the obvious question for me is does it work on 32 bit
> without this. Maybe it is just old cruft that we don't need in either
> tree with the current tools.
> -Steve
>> [mailto:pgrouting-dev-bounces at lists.osgeo.org] On Behalf Of Paragon
>> Corporation
>> Sent: Monday, April 08, 2013 4:01 AM
>> To: 'pgRouting developers mailing list'
>> mingw64
>> Okay got it to compile
>> 1) I had a dirty tree so restarted from scratch and then I started to
>> get the error you got even without the -DWITH_TSP=ON
>> 2) For 64-bit I guess we can't have this line
>> #ifdef __MINGW64__
>> #define ELOG_H
>> #endif
>> I took that out and then it compiled okay -- so maybe you should only
>> check for  the 32-bit case there (I forget what the flag is)
>> I still need to run the regression, but its now generating the tsp
>> dll for 64-bit with
>> cmake -G "MSYS Makefiles" -DWITH_DD=ON ..
>> make && make install
>> Thanks,
>> Regina
>> Corporation
>> Sent: Monday, April 08, 2013 3:16 AM
>> mingw64
>> Okay just checked my ming32 and I was wrong,
>> It still builds the librouting_tsp.dll without the -DWITH_TSP=ON
>> If I take it out of my ming64, then no attempt at building the tsp
>> dll seems to be done, but it compiles the others.
>> I wonder if the issue is that a 32-bit lib is sneaking in somewhere.
>> That's the occupational hazard of using 32-bit tools to build a
>> 64-bit
> library.
>> When it comes across a 32-bit with a name it thinks it needs, things
>> get very confusing.
>> Thanks,
>> Regina
>> Corporation
>> Sent: Monday, April 08, 2013 2:53 AM
>> mingw64
>> Not off hand.  I can look again and rebuild.  When I pulled that was
>> the latest without jumping into 4.6 GCC.  With 4.6 GCC I had major
>> issues with dealing with C++ code (particularly Geos) with it
>> randomly crashing so avoided it like the plague.
>> I thought both my ming32 and ming64 are running the same prerelease
>> versions though
>> My ming64 compiles fine by taking out the
>> -DWITH_TSP=ON
>> But then it doesn't regress because the create extension seems to
>> load tsp functions.
>> I'll have to double-check my ming32, but as I recall if I take out
>> the -DWITH_TSP it also fails the tests because its missing the tsp dll.
>> Thanks,
>> Regina
>> Woodbridge
>> Sent: Sunday, April 07, 2013 8:51 PM
>> mingw64
>> Regina,
>> I just noticed that:
>> woodbri at imaptools /C/ming64/projects/pgrouting/build/src/tsp/src
>> $ gcc --version
>> gcc.exe (GCC) 4.5.4 20111030 (prerelease) [svn/rev.180676 -
>> mingw-w64/oz] Copyright (C) 2010 Free Software Foundation, Inc.
>> This is free software; see the source for copying conditions.  There
>> is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
>> PARTICULAR
> PURPOSE.
>> our version of the gcc is a prerelease, do you know if there is a new
>> version that might be better? I looked at the sourceforge but it has
>> a mess of versions and I think it better is we stay in sync with one
> another.
>> -Steve
>> On 4/7/2013 8:19 PM, Stephen Woodbridge wrote:
>>> Ok, I just got back and I have the same problem on 64bit now that I
>>> have a system to check it on.
>>> -DWITH_TSP=ON  should not be included any more. I may have forgotten
>>> to take it out of makepgroutingw64.sh
>>> After looking at the compile error on 64 bit for 6 hours, I'm either
>>> totally missing something obvious or this is looking like GNU
>>> compiler
>> bug.
>>> If you run the tools/makepgroutingw64.sh and then after it bombs:
>>> cd build
>>> make VERBOSE=1
>>> and this will should you something like:
>>> Scanning dependencies of target routing_tsp [ 66%] Building C object
>>> src/tsp/src/CMakeFiles/routing_tsp.dir/tsp.c.obj
>>> [ 73%] Building C object
>>> src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.obj
>>> c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c: In function
>>> 'findEulerianPath':
>>> c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:183:14: error: 'ERROR'
>>> undeclared (first use in this function)
>>> c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:183:14: note: each
>>> undeclared identifier is reported only once for each function it
>>> appears in
>>> 'find_tsp_solution':
>>> c:/ming64/projects/pgrouting/src/tsp/src/tsplib.c:446:18: error: 'FATAL'
>>> make[2]: *** [src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.obj]
>>> Error 1
>>> make[1]: *** [src/tsp/src/CMakeFiles/routing_tsp.dir/all] Error 2
>>> make: *** [all] Error 2
>>> woodbri at imaptools /c/ming64/projects/pgrouting $ cd build
>>> woodbri at imaptools /c/ming64/projects/pgrouting/build
>>> $ make VERBOSE=1
>>> /C/ming64/msys/bin/cmake.exe -H/C/ming64/projects/pgrouting
>>> -B/C/ming64/projects/pgrouting/build --check-build-system
>>> CMakeFiles/Makefile.cmake 0 /C/ming64/msys/bin/cmake.exe -E
>>> cmake_progress_start /C/ming64/projects/pgrouting/build/CMakeFiles
>>> /C/ming64/projects/pgrouting/build/CMakeFiles/progress.marks
>>> make -f CMakeFiles/Makefile2 all
>>> make[1]: Entering directory `/c/ming64/projects/pgrouting/build'
>>> make -f
>>> src/shooting_star/src/CMakeFiles/shooting_star.dir/build.make
>>> src/shooting_star/src/CMakeFiles/shooting_star.dir/depend
>>> make[2]: Entering directory `/c/ming64/projects/pgrouting/build'
>>> /C/ming64/msys/bin/cmake.exe -E cmake_depends "MSYS Makefiles"
>>> /C/ming64/projects/pgrouting/src/shooting_star/src
>>> /C/ming64/projects/pgrouting/build/src/shooting_star/src
>>> /C/ming64/projects/pgrouting/build/src/shooting_star/src/CMakeFiles/
>>> s
>>> h
>>> ooting_star.dir/DependInfo.cmake
>>> --color=
>>> make[2]: Leaving directory `/c/ming64/projects/pgrouting/build'
>>> make -f
>>> make[2]: Nothing to be done for
>>> `src/shooting_star/src/CMakeFiles/shooting_star.dir/build'.
>>> /C/ming64/msys/bin/cmake.exe -E cmake_progress_report
>>> /C/ming64/projects/pgrouting/build/CMakeFiles  11 12 [ 13%] Built
>>> target shooting_star make -f
>>> src/trsp/src/CMakeFiles/trsp.dir/build.make
>>> src/trsp/src/CMakeFiles/trsp.dir/depend
>>> /C/ming64/projects/pgrouting/src/trsp/src
>>> /C/ming64/projects/pgrouting/build/src/trsp/src
>>> /C/ming64/projects/pgrouting/build/src/trsp/src/CMakeFiles/trsp.dir/
>>> D
>>> e
>>> pendInfo.cmake
>>> --color=
>>> make -f src/trsp/src/CMakeFiles/trsp.dir/build.make
`src/trsp/src/CMakeFiles/trsp.dir/build'.
>>> /C/ming64/projects/pgrouting/build/CMakeFiles  13 14 15 [ 33%] Built
>>> target trsp make -f src/astar/src/CMakeFiles/astar.dir/build.make
>>> src/astar/src/CMakeFiles/astar.dir/depend
>>> /C/ming64/projects/pgrouting/src/astar/src
>>> /C/ming64/projects/pgrouting/build/src/astar/src
>>> /C/ming64/projects/pgrouting/build/src/astar/src/CMakeFiles/astar.di
>>> r
>>> DependInfo.cmake
>>> --color=
>> `src/astar/src/CMakeFiles/astar.dir/build'.
>>> /C/ming64/projects/pgrouting/build/CMakeFiles  1 2 [ 46%] Built
>>> target astar make -f
>>> src/dijkstra/src/CMakeFiles/dijkstra.dir/build.make
>>> src/dijkstra/src/CMakeFiles/dijkstra.dir/depend
>>> /C/ming64/projects/pgrouting/src/dijkstra/src
>>> /C/ming64/projects/pgrouting/build/src/dijkstra/src
>>> /C/ming64/projects/pgrouting/build/src/dijkstra/src/CMakeFiles/dijks
>>> t
>>> r
>>> a.dir/DependInfo.cmake
>>> --color=
>>> make -f src/dijkstra/src/CMakeFiles/dijkstra.dir/build.make
>>> `src/dijkstra/src/CMakeFiles/dijkstra.dir/build'.
>>> /C/ming64/projects/pgrouting/build/CMakeFiles  3 4 [ 60%] Built
>>> target dijkstra make -f CMakeFiles/routing.dir/build.make
>>> CMakeFiles/routing.dir/depend
>>> /C/ming64/projects/pgrouting /C/ming64/projects/pgrouting
>>> /C/ming64/projects/pgrouting/build/CMakeFiles/routing.dir/DependInfo.
>>> c
>>> make
>>> --color=
>>> make[2]: Nothing to be done for `CMakeFiles/routing.dir/build'.
>>> [ 60%] Built target routing
>>> make -f src/tsp/src/CMakeFiles/routing_tsp.dir/build.make
>>> src/tsp/src/CMakeFiles/routing_tsp.dir/depend
>>> /C/ming64/projects/pgrouting/src/tsp/src
>>> /C/ming64/projects/pgrouting/build/src/tsp/src/CMakeFiles/routing_tsp.
>>> --color=
>>> /C/ming64/projects/pgrouting/build/CMakeFiles 10 [ 66%] Building C
>>> object src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.obj
>>> cd /C/ming64/projects/pgrouting/build/src/tsp/src &&
>>> /c/ming64/mingw64/bin/gcc.exe  -Drouting_tsp_EXPORTS -O2 -g
>>> -frounding-math @CMakeFiles/routing_tsp.dir/includes_C.rsp   -o
>>> CMakeFiles/routing_tsp.dir/tsplib.c.obj   -c
>>> /C/ming64/projects/pgrouting/src/tsp/src/tsplib.c
>>> 'findEulerianPath':
>>> appears in
>>> Error 1
>>> make[1]: Leaving directory `/c/ming64/projects/pgrouting/build'
>>> So if I look at the commands that are getting executed you will
>>> notice above on the gcc.exe there is:
>>> This appears to be a way to include command line options from a file.
>>> So I just copied the options from the file to the commandline in the
>>> next
>>> command:
>>> $ cd /C/ming64/projects/pgrouting/build/src/tsp/src
>>> $ /c/ming64/mingw64/bin/gcc.exe  -Drouting_tsp_EXPORTS -O2 -g
>>> -frounding-math
>>> -Ic:/ming64/projects/pgx64/pg92/include/postgresql/server
>>> -IC:/ming64/projects/pgrouting/src/astar/src
>>> -IC:/ming64/projects/pgrouting/src/dijkstra/src
>>> -IC:/ming64/projects/pgrouting/src/shooting_star/src
>>> -IC:/ming64/projects/pgrouting/src/tsp/src
>>> -IC:/ming64/projects/pgrouting/src/driving_distance/src
>>> -IC:/ming64/projects/pgrouting/src/trsp/src
>>> -Ic:/ming64/msys/local/include/boost-1_46_1
>>> -Ic:/ming64/projects/pgx64/pg92/include/postgresql/server/port/win32 -o
>>> 'findEulerianPath':
>>> appears in
>>> And tried to convert the "C:" to "/c" in this command:
>>> -frounding-math
>>> -I/c/ming64/projects/pgx64/pg92/include/postgresql/server
>>> -I/c/ming64/projects/pgrouting/src/astar/src
>>> -I/c/ming64/projects/pgrouting/src/dijkstra/src
>>> -I/c/ming64/projects/pgrouting/src/shooting_star/src
>>> -I/c/ming64/projects/pgrouting/src/tsp/src
>>> -I/c/ming64/projects/pgrouting/src/driving_distance/src
>>> -I/c/ming64/projects/pgrouting/src/trsp/src
>>> -I/c/ming64/msys/local/include/boost-1_46_1
>>> -I/c/ming64/projects/pgx64/pg92/include/postgresql/server/port/win32 -o
>>> 'findEulerianPath':
>>> appears in
>>> Lets check that the file exists, and it does. This file gets
>>> included from postgres.h
>>> $ /bin/find.exe /c/ming64/projects/pgx64/pg92/ -name postgres.h
>>> -print
>>> /c/ming64/projects/pgx64/pg92/include/postgresql/server/postgres.h
>>> $ /bin/find.exe /c/ming64/projects/pgx64/pg92/ -name elog.h -print
>>> /c/ming64/projects/pgx64/pg92/include/postgresql/server/utils/elog.h
>>> So I'm left with:
>>> 1. it works on 32 bit
>>> 2. the -Idirectory is included in the gcc 3. the include files exist
>>> in the correct places 4. gcc does not appear to be loading them, but
>>> I do not know why
>>> Anyone run into this problem before?
>>> Anyone have any ideas?
>>> -Steve
>>> pgrouting-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
