[pgrouting-dev] Gsoc 2013 Preliminary project proposal
Mukul priya mukul2047 at gmail.com
Sat Apr 13 20:12:36 PDT 2013
Thanks Steve for clearly mentioning the two proposals.
For Item 1 , upgrading all the algorithms will certainly require a lot of
work and since i will be having my summer vacation i don't have any issue
with it :).
For item 2 , i am looking into the idea that you have proposed , It is very
much doable , there are however some concerns of mine like
- how do we decide what should be the grid size . this can vary for
suburban area and urban area based on netwrok density.
- how do we classify the nodes lying on the junction of two or more grids .
should it be assigned to all the grids??
- how do we decide the grid that needs to be loaded in the memory ,
connectivity with the previous grid seems legit here but i guess we need to
discuss some corner cases too.
Thanks.
On Sat, Apr 13, 2013 at 6:20 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 4/11/2013 3:24 PM, Mukul priya wrote:
>> Hi Steve and Daniel,
>>          You suggested extending the present algorithms such that its
>> input  can take more points and not only the source and destination . i
>> think this can be implemented and i will soon come up with
>> implementation details( kind of more technical ) .
>>          Can you be a liitle bit more elaborate about partioning data
>> into spatial chunks or even suggest some readings . I can then come up
>> with some better ideas about implementing it.
> This is just me thinking out loud :)
> Lets say we construct a grid of one degree squares, you can visualize it
> by drawing a grid over your map.
> Then you can associate all the nodes with the grid they fall in. We might
> also need to associate edges to the grids also and an edge the crosses over
> a grid boundary might need to be associated with two grids. This could be
> done with some simple relational tables like:
> node_id|grid_id  or  edge_d|grid_id
> So my idea would be to do the routing like this:
> 1. get the start node or edge
> 2. build the graph based on loading the items in the related grid
> 3. mark the boundary nodes (we might want to do this when we grid them)
> 4. run the algorithm until we find the target node or hit a boundary node
> 5. on hitting a boundary:
>   a. we check if the connected grid is loaded and continue if it is
>   b. or we extent the graph with the new grid
> 6. continue with the routing
> We might want to be able to dynamically change the size of the grid cell
> based on the number of items in it. This would give us better performance
> when transitioning from rural areas into urban areas where there is a
> greater density of road segments. Think of a quadtree where we split it
> based on number of entities.
>           Daniel , i took a look at the oracle link that you provided but
>> there was no details about how it has been implemented , it was more
>> about how one can use it. May be a bit  more search   and luck might
>> take me to its implementation document :) .
> Right, it is useful if you look at the documentation and ask why did they
> do it that way and what does it imply about how it works behind the scenes.
>            The other thing that you mentioned was about contraction
>> Hierarchy . Still the nodes have to be ordered based on some criteria or
>> according to their importance . We can  use natural hierarchy present in
>> the network for doing that .
> This is not related to what you proposed. It is an algorithm that does a
> lot of precompuation, that is LOTS in capitals, but it can get results in
> milliseconds for cross country routes.
>             i will be really grateful if anyone can correct me in case if
>> my thought process in not on the right lane and sorry for the late reply
>> as my academic session  is in progress too .Meanwhile  i am trying to
>> get fluent with git ,cmake and other tools.
> So read over our wiki:
> https://github.com/pgRouting/**pgrouting/wiki<https://github.com/pgRouting/pgrouting/wiki>
> The way I see it at the moment there are two unrelated proposals on the
> table (I'm leaving out the contraction hierarchy):
> 1. multi point routing
> 2. partition JIT graph building while routing
> Item 1 is fairly trivial technically, I think, but if you were to upgrade
> all the algorithms to do this it would be a lot of work and a useful
> contribution to pgrouting.
> Item 2 is more of a design and code a new algorithm and you would probably
> want to focus on using astar or trsp algorithm to do this with. This one is
> more technically challenging and has more unknowns in it but I think it
> should be doable.
> If you are interested in reading about contraction hierarchies:
> https://www.google.com/#q=**contraction<https://www.google.com/#q=contraction>hierarchies
> Thanks,
>   -Steve
>  Thanks .
>> Mukul
>> On Thu, Apr 11, 2013 at 6:47 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>>     With pgRouting, we do most things dynamically, here is the basic flow:
>>     1. Given a collection of input, points, nodes, or edges
>>     map these to nodes or edges depending on algorithm.
>>     2. Select the edges we need to build the graph
>>     3. build the graph and solve it
>>     4. return the results
>>     All our algorithms today only take start and end points. They could
>>     be extended to take points. Each "point" (I use "point" as a generic
>>     term because it might be a lat/lon, node id, edge id and offset,
>>     etc) would need to be mapped to the appropriate input need for any
>>     given algorithm.
>>     So for node based algorithms like Dijkstra,and astar it would get
>>     resolved to a node. For TRSP it would get mapped to the nearest edge
>>     and offset along that edge. Postgis has lots of handy tools for
>>     doing this.
>>     -Steve
>>     On 4/10/2013 10:50 PM, Mukul priya wrote:
>>         Thanks for the reply steve . i have already cloned the github
>>         repository
>>         and looking into various aspects of it .
>>         For IRNN querry implementation i think it is a good idea to sub
>>         divide
>>         the whole route and generate n+1 routes separately , say from S
>>         to F1 ,
>>         F1-F2 ,..... F(n-1)-Fn , Fn to D . i wanted to know if we have
>>         that kind
>>         of a data where each and every facility is mentioned on the map
>> as a
>>         point (node ) . even if it is not directly connected to the road
>>         network
>>         we can basically treat it a pseudo node and then call the router
>>         . The
>>         other thing about optimization yes we can do that using spatial
>>         range
>>         querries suppose there are several instances of the same
>>         facility that a
>>         user wants to access then we can use spatial range querries to
>>         locate
>>         that facility which is the nearest.
>>         On Thu, Apr 11, 2013 at 1:42 AM, Stephen Woodbridge
>>         <mailto:woodbri at swoodbridge.__**com
>>         <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>> wrote:
>>              On 4/10/2013 3:23 PM, Mukul priya wrote:
>>                  Hi ,
>>              Hi Mukul,
>>              Thank you for your interest in pgRouting.
>>                                 I am a  B.tech fourth year student at
>>         IIIT-Hyderabad
>>                  pursuing a degree in computer science and engineering
>>         and i will
>>                  be soon
>>                  pursuing a Masters Degree in the field of Spatial
>>         Informatics
>>                  and the
>>                  research topic that i have been working on is *"In
>>         route nearest
>>                  neighbour querries".*
>>                                 Last year i worked on a project that was
>>         funded by
>>                  Honeywell technology solutions and it gave me a lot of
>>         insight about
>>                  open source programming and industrial work culture.
>>                  I was introduced to pgrouting by *Prof. Venkatesh
>>         Raghavan* who
>>                  visited
>>                  our college last summer. i have also used pgrouting for
>>                  implementing one
>>                  of my Honors project.
>>                  i have gone through the updated ideas page and i am
>>         listing out
>>                  a topic
>>                  that i feel i can contribute to.
>>                  *Idea *
>>                  Network Partitioning
>>                  A very simple method using which it can be done is :
>>                     * *Existence of a natural Hierarchy*
>>                             Generally road networks are organized such
>>         that there
>>                  is some
>>                  natural hierarchy for example if we look at the road
>>         network of
>>                  USA we
>>                  observe that there are national highways which connect
>>         multiple
>>                  large
>>                  regions , inter state roads connect places within these
>>         regions
>>                  , multi
>>                  lane roads connect city areas and then there are small
>>         roads to
>>                  connect
>>                  individual houses.
>>                               so what we can do is first rank these
>>         classes that
>>                  constitute the road network and then use the highest
>>         level roads to
>>                  divide the road network into large regions enclosed by
>>         these
>>                  roads. each
>>                  of the divided regions can further be divided again
>>         using next lower
>>                  level road.
>>                               so suppose we have a road network which n
>>         classes of
>>                  different roads then we can create a tree of depth n-1
>>         where the
>>                  root of
>>                  the tree will represent the entire road network and
>>         children of
>>                  the the
>>                  root node will represent the area formed by
>>         partitioning the
>>                  root using
>>                  the level 1 ( highest ) edges and so on . the nodes
>>         will basically
>>                  represent a smaller part of the road network.
>>                                The idea seems to be very naive right now
>>         but if
>>                  anyone can
>>                  give some feedback whether it is achievable or not or
>>         may be suggest
>>                  some modifications.
>>              Yes this is the basics of how this could work. Because we
>>         build our
>>              graphs dynamically for each route request, we can do
>>         something like
>>              this today. Typically you have to feed the route request
>>         and SQL
>>              query that provides the edges needed to build the graph and
>>         this can
>>              be simply the bounding box of the start and end point of
>>         the route
>>              expanded slightly to allow the route move outside that
>>         bounds by a
>>              little if needed. A case in point are start and end points
>>         that form
>>              a vertical of horizontal line.
>>              So for the natural hierarchy, you can for a SQL query like:
>>              select * from edges where st_dwithin(the_geom, start_pnt,
>>         radius)
>>              union
>>              select * from edges where st_dwithin(the_geom, end_pnt,
>> radius)
>>              union
>>              select * from edges
>>                 where st_expand(st_makeline(start___**__pnt, end_pnt),
>> pct)
>>                   and road_class < 4;
>>              So this gets all edges regardless of class at the start and
>>         end and
>>              then gets all the major roads and highways between the
>>         start and end
>>              points. We can dynamically select the edges that we want
>>         when we
>>              build the graph.
>>              Regardless of how you implement the routing, the problem is
>> all
>>              about the data. If you have a road segment the is
>>         misqualified, you
>>              might end up with a network that is broken between start
>>         and end.
>>              This can alsoo happen if ramps are not coded correctly.
>>              One of the challenges we have today is that we have to be
>>         able to
>>              construct the whole graph in memory before we can start
>>         routing.
>>              This is ok for small areas but it is a problem if you want to
>>              generate a route between say Miami, Florida and Seattle,
>>         Washington.
>>              An interesting problem would be the ability to partition
>>         the data in
>>              spatial chucks and only load them as the solver needed them.
>>              If you think about your edges sorted into say 1 degree grid
>>         partitions,
>>              then you load the partition for the start point and start
>>         routing
>>              using A* search, when you frontier get to an edge of the
>>         grid you
>>              are in, then you load the adjacent grid and continue, if
>>         you bump
>>              into another grid boundary that is not loaded yet, you
>>         load, if it
>>              is already loaded you continue. Anyway food for thought! :)
>>                                 In route nearest neighbour querries(
>>         IRNN) which
>>                  handle
>>                  querries like computation of shortest path , provided
>>         that the user
>>                  wants to visit facilities F1 , F2 ,.....FN while he/she
>>         drives
>>                  or walks
>>                  from source to destination. Network partitioning can
>>         optimize these
>>                  computations  too as the search space reduces
>>         significantly once
>>                  we have
>>                  the partitions. Handling such querries have not been
>>         implemented
>>                  yet. It
>>                  will be very helpful if we can have some discussion
>>         about whether
>>                  implementing it is feasible or not.
>>              What is we just added via support to routing? Then we could
>> do
>>              something like say generate a route: Start, F1, F2, ... Fn,
>> End
>>              This would allow us to build a graph one time and then
>> generate
>>              multiple sub-routes with in the graph. Today if you want to
>>         do that
>>              you have to generate n+1 routes and build the graph n+1
>>         times. We
>>              could also do some preliminary optimization of the via
>>         points based
>>              on Euclidean distance using something like TSP before
>>         calling the
>>              router.
>>                                 It would be great if someone could give
>>         a general
>>                  idea
>>                  how  to go about learning more about the areas
>>         mentioned  with
>>                  respect
>>                  to the organization's projects.Specially suggest those
>>         ideas
>>                  which the
>>                  developers think are achievable for now . I will also
>>         be grateful if
>>                  somebody can guide me regarding the development
>>         framework of
>>                  pgrouting
>>                  so that i get familiar with the whole framework in the
>>         coming days.
>>              I would clone the github repository and look at branch
>>         sew-devel-2_0
>>              this is our new tree structure and it has code, doc, and
>>         test all
>>              organized in a nice way that makes it easy to multiple
>>         contributors
>>              work with the tree.
>>              Ask questions, There is a tutorial floating around and lots
>> of
>>              people that are will to help.
>>              -Steve
>>                  Thank you .
>>                  Mukul Priya
>>                  Lab for spatial Informatics
>>                  IIIT-Hyderabad
>>                  ______________________________**_____________________
>>                  pgrouting-dev mailing list
>>         pgrouting-dev at lists.osgeo.org
>>         <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>         <mailto:pgrouting-dev at lists.__**osgeo.org <http://osgeo.org>
>>         http://lists.osgeo.org/____**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>
>>         <http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>>         <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>> **>__>
>> **>__>
>>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130414/2e633e39/attachment-0001.html>
More information about the pgrouting-dev mailing list
