[pgrouting-dev] Gsoc 2013
Mukul priya
mukul2047 at gmail.com
Sat Apr 27 07:02:06 PDT 2013
Thanks Steve . i will go through the steps that you have mentioned once i
am free from all my academic commitments by the end of this month ( in 2-3
days at max).
-Mukul
On Sat, Apr 27, 2013 at 6:59 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi Mukul,
> I think your proposal looks good. Daniel may have some additional comment.
> At this point if you have time, you might want to start with getting a
> github account, forking the pgrouting project, making sure you can build
> the existing project and install it under pg 9.2.
> Regarding the Astar algorithm, you might want to look at implementing your
> own algorithm unless you want to try and work with the existing Boost code
> as this might be easier in the long run. Either way some research now,
> might help you with your planning later. This would allow you to work out
> all the basics of working in our environment and give you a head start. In
> the past the most successful and less stressed projects have been those
> that took an interest early on as these details can be frustrating and time
> consuming. This is totally at you option because the proposal has not been
> accepted yet.
> Thank you putting together an interesting proposal that would add value to
> the project.
> -Steve
> On 4/27/2013 6:29 AM, Mukul priya wrote:
>> Hi steve , i have edited my proposal based on our previous discussion (
>> added some lines about Astar) .meanwhile do suggest if there is scope of
>> some improvement .
>> Thanks
>> Mukul
>> On Thu, Apr 25, 2013 at 11:22 PM, Mukul priya <mukul2047 at gmail.com
>> <mailto:mukul2047 at gmail.com>> wrote:
>> Thanks Steve will add a few lines to my proposal explaining the
>> reason behind opting Astar.
>> Mukul
>> On Thu, Apr 25, 2013 at 8:55 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>> On 4/25/2013 11:06 AM, Mukul priya wrote:
>> How much of the network do you have to explore using each
>> algorithm?
>> This will be reduced significantly while using Astar as we
>> will have a
>> fair bit of idea about the direction towards which we should
>> proceed.
>> How does this impact the number of grids you have to load?
>> Once we have an idea about the direction towards which we
>> should proceed
>> , only those grids will be loaded. This will result in
>> loading of less
>> number of grids.
>> How does this impact your proposal?
>> The basic motivation behind the proposal is to make shortest
>> path
>> computation faster. Number of database querry will be
>> reduced as we will
>> be fetching lesser number of grids. This will have a
>> positive effect on
>> computation time.
>> Right, so in your proposal, you want to be clear that the
>> benefit will be achieved using astar or another algorithm with a
>> heuristic and not dijkstra. I understand that "shortest path" is
>> a generic reference to all of these algorithms, but the only
>> ones that will benefit from this approach will be ones with a
>> heuristic that allow us to explore only a subset the overall
>> bounding box of edges that we might otherwise use as input. So
>> it is best to be clear on these points.
>> -Steve
>> On Thu, Apr 25, 2013 at 7:07 PM, Stephen Woodbridge
>> <mailto:woodbri at swoodbridge.__**com
>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>> wrote:
>> On 4/25/2013 12:26 AM, Mukul priya wrote:
>> Thanks Steve ,I am familar with astar ,It uses a
>> heuristic to guide
>> itself to the destination, there was huge focus on
>> it in our
>> game theory
>> course.
>> Although do point out the advantages it has in real
>> life road
>> network
>> and its importance to my proposal.
>> each algorithm?
>> load?
>> -Steve
>> On Thu, Apr 25, 2013 at 7:43 AM, Stephen Woodbridge
>> <mailto:woodbri at swoodbridge.>_**___com
>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>
>> wrote:
>> Hi Mukul,
>> This is a good write up. It largely mirrors
>> out discussion. One
>> thing that needs to change in this is that
>> dijkstra should be
>> replaced with astar.
>> Are you familiar with how these are different?
>> http://theory.stanford.edu/~__**
>> ____amitp/GameProgramming/____**__AStarComparison.html<http://theory.stanford.edu/~______amitp/GameProgramming/______AStarComparison.html>
>> <http://theory.stanford.edu/%**7E____amitp/GameProgramming/__
>> **__AStarComparison.html<http://theory.stanford.edu/%7E____amitp/GameProgramming/____AStarComparison.html>
>> <http://theory.stanford.edu/%_**
>> _7E__amitp/GameProgramming/___**_AStarComparison.html
>> <http://theory.stanford.edu/%**7E__amitp/GameProgramming/__**
>> AStarComparison.html<http://theory.stanford.edu/%7E__amitp/GameProgramming/__AStarComparison.html>
>> ___7Eamitp/GameProgramming/___**_AStarComparison.html
>> <http://theory.stanford.edu/%_**_7Eamitp/GameProgramming/__**
>> <http://theory.stanford.edu/%**7Eamitp/GameProgramming/**
>> AStarComparison.html<http://theory.stanford.edu/%7Eamitp/GameProgramming/AStarComparison.html>
>> Do you see why? and specifically why it matter
>> for this
>> project?
>> -Steve
>> On 4/24/2013 9:10 PM, Mukul priya wrote:
>> ***Name*:Mukul Priya
>> *Country:*India
>> *School and degree*: International
>> Institute Of Information
>> Technology-Hyderabad ,
>> B.Tech +
>> Masters in
>> computer
>> Science And
>> Engineering
>> *Email*:mukul2047 at gmail.com
>> <mailto:mukul2047 at gmail.com>> <mailto:mukul2047 at gmail.com
>> <mailto:mukul2047 at gmail.com>>>
>> <mailto:mukul2047 at gmail.com>>>**>
>> *Phone*:+91 9885991061
>> *OSGeo project(s*):pgRouting
>> *Title:* A partitioned approach to on
>> demand increment
>> graph
>> assembly
>> for pgRouting.
>> *Describe your idea*
>> *1. Introduction*
>> pgRouting has been working
>> towards providing
>> routing
>> functionality on a PostGis/PostgreSql Geo
>> spatial
>> database. It already has support for
>> shortest path
>> algorithm
>> like
>> astar ,dijkstra , tdsp and trsp .But for a
>> very
>> large network, routing becomes time
>> consuming. Network
>> partitioning
>> is one such way which can prove to
>> be helpful in improving the overall
>> time efficiency
>> of routing
>> querries. The main idea here is to first
>> partition
>> the whole network using a Quad tree
>> approach and
>> when the
>> shortest
>> path is computed these partitions are
>> loaded on demand. hence , there is an
>> on demand
>> incremental
>> graph
>> generation.
>> The project aims at designing and
>> implementing a
>> Shortest Path
>> algorithm on an on demand incremental
>> Graph using a network partitioning
>> approach.
>> *2. Background*
>> Considering the present status
>> where pgRouting has
>> support for
>> shortest path algorithm like astar etc.
>> Looking at their implementation details
>> we can
>> observe that
>> the graph
>> is configured dynamically for all
>> of them before computation.My proposal
>> will also be
>> on the
>> same track
>> and for very large networks
>> where the distance between source and
>> destination
>> can be
>> very large ,
>> the response time will be
>> significantly lesser and memory wise
>> too it will be
>> lot more
>> efficient. Presently they don't use any
>> partitioning
>> approach so it will prove to be a good
>> addition to their
>> support for
>> shortest past algorithms.
>> *3. The idea*
>> There are two major components of my
>> idea .
>> *Network Partitioning*
>> For this part we can use a quad
>> tree approach.
>> Say , we
>> start
>> with a square and a condition like maximum
>> number of nodes that can reside
>> in a square .
>> if the
>> number of
>> nodes in the square is greater than the max
>> condition we further quarter it
>> into four
>> squares and
>> allot the
>> nodes appropriately to each of them.All
>> these
>> squares can be called grids and
>> they all will
>> be addressed
>> uniquely using a grid cell number .Each node
>> will be assigned a grid cell
>> number based on
>> the grid
>> they are
>> lying inside.
>> We will have data
>> structures to address
>> edges as
>> they can
>> remain contained in either one grid cell
>> or span across a number of grid
>> cells.the
>> idea is to
>> first flag
>> such edges and store the grid cell numbers
>> of the grids that the edge
>> crosses/intersects.
>> *On demand graph generation and
>> Routing.*
>> The idea here is to first
>> identify the
>> grid cell
>> initially and then fetch the edges that
>> are associated with
>> that grid. These are the edges
>> that will get
>> appended
>> to the
>> present graph and the graph will keep
>> growing
>> dynamically this way. we will
>> have appropriate
>> database
>> tables
>> addressing the above issue such that
>> we are able to fetch the required
>> edges
>> quickly using a
>> database querry.
>> The implementation details for
>> the above are :
>> we will first partition the whole
>> graph using
>> the quad tree
>> approach and each node/vertex will be
>> assigned
>> a grid cell number so we can have
>> database
>> table for the
>> assigned nodes and edges like :
>> CREATE TABLE vertex{
>> id Node_id
>> unique
>> for each
>> node.
>> cell grid_cell_number;
>> \\ the
>> grid in
>> which the
>> node lies.
>> geometry;
>> CREATE TABLE edge {
>> int id ;
>> Int node_a;
>> int node_b; \\ the
>> connecting nodes
>> // we can have other parameters
>> like
>> traversal cost
>> and return
>> cost.
>> using the tables we can then
>> fetch the
>> edges form
>> edge table
>> using simple database querry once
>> we are provided with the grid cell
>> number very easily.
>> In short the summary of the whole idea
>> is :
>> Step1: Fetch the start node , get the
>> related Grid cell
>> number.
>> Step 2: Increment the graph by fetching
>> all the items
>> related to
>> that grid.
>> Step3 : Check for boundary nodes ( this
>> is done while
>> we are
>> partitioning) or target node .
>> Step 4: On hitting a boundary node
>> check if the connected
>> grid is
>> loaded and
>> continue if
>> it is
>> or we extend the graph
>> with the new
>> grid and
>> continue
>> with the routing;
>> or On hitting the target Node
>> stop;
>> *4. Project plan*
>> I will have about 12 weeks to
>> implement the
>> project. The
>> tentative
>> schedule is as follows:
>> Before 17th June : Get familiar
>> with the development
>> environment
>> of pgRouting and test some demos.
>> week 1-2: Discuss and Define the
>> various data
>> structures
>> and data
>> table that will be required.Prepare the
>> Overall
>> implementation
>> architecture.
>> week 3-4- Discuss and Implement
>> network
>> partitioning
>> using quad
>> tree.
>> week 5-8 -Start coding for on
>> demand graph
>> generation and
>> routing
>> using Dijkstra. In between Prepare mid-term
>> report.
>> week 9 - Integration with pgrouting .
>> week 10-12- Testing and Bug fixing.
>> Draft Final
>> report and
>> documentation.
>> 5. Future ideas / How can your idea be
>> expanded? *
>> It can be integrated with other
>> shortest path
>> algorithms
>> like
>> astar etc. which pgrouitng provides.For
>> time dependent
>> shortest path computation, it will
>> greatly reduce the
>> updating cost
>> as we will be updating the cost of only
>> those edges
>> that are contained in the grid cells
>> that are loaded.
>> In route nearest neigbour querries
>> can also be
>> implemented using
>> the partitioning approach.Overall we can
>> expand this approach to various
>> other algorithms.
>> *Explain how your SoC task would benefit
>> the OSGeo member
>> project and
>> more generally the OSGeo Foundation as a
>> whole:*
>> The proposed idea will significantly
>> improve the
>> performance of
>> shortest path finding algorithms.This will
>> have a
>> positive effect on the user base of
>> pgRouting. For
>> various
>> software
>> paltforms or applications that are using
>> this library ,
>> the response time will significantly
>> improve.
>> Please provide details of general
>> computing experience:
>> I generally use ubuntu ( 12.04) for all my
>> academic
>> purposes and
>> windows
>> 7 for entertainment only. I am familiar
>> with Fedora also.
>> C++ is the language that i use most (
>> programming
>> purposes). For
>> implementing various course projects i
>> have used C++
>> ,python
>> ,Java and
>> matlab.
>> I have no experience with hardware. The
>> only experience
>> that i
>> had with
>> networking was during my computer network
>> course.
>> Please provide details of previous GIS
>> experience:*
>> I am a part of "Lab for Spatial
>> Informatics" which is
>> the only
>> lab in
>> India devoted to GIS applications and
>> learning. I am
>> familiar
>> with and
>> have used almost all the open source GIS
>> platforms like
>> Quantum ,
>> OpenJump, ILwis,Grass. We have our own
>> rendering
>> platform that was
>> developed by our lab.(LSI viewer)
>> *Please provide details of any previous
>> involvement
>> with GIS
>> programming
>> and other software programming:*
>> I am very much familiar with Gdal/OGR as
>> i used it
>> extensively
>> while
>> implementing an outsourced project of
>> Honeywell
>> Technology . I have played a lot with ESRI
>> shape files.
>> *Please tell us why you are interested in
>> GIS and open
>> source
>> software:*
>> I was very impressed with google earth
>> when it was
>> launched way
>> back in
>> 2004.GIS platforms like quantum and
>> Openjump were
>> introduced to
>> me when
>> i was in my second year and then i joined
>> Lab for spatial
>> informatics
>> that is in our college based on my
>> interest in this area.
>> open source platforms provide an
>> opportunity to learn .
>> The best
>> part is
>> you can always create or develop something
>> that you are
>> interested in
>> and there are people who will always be
>> there to help
>> you if you
>> are stuck.
>> working for
>> OSGeo and the
>> software project you have selected:*
>> It will be huge learning experience since
>> i have been
>> using
>> platforms
>> like Qgis , Gdal ,PostGis etc which come
>> under Osgeo
>> I chose pgrouting because the algorithms
>> that they have
>> implemented are
>> related to my masters topic and it will be
>> great if i
>> get an insight
>> about how these were implemented on a much
>> larger scale.
>> your specific
>> coding
>> project:*
>> Implementing routing algorithms for real
>> world networks is
>> actually very
>> challenging.its a challenge to come up
>> with good
>> approaches so
>> that the
>> computation cost and response time is both
>> reduced.
>> *Would your application contribute to your
>> ongoing
>> studies/degree? If
>> so, how?*
>> I am pursuing my Masters and my topic is
>> closely
>> related to my
>> proposal
>> . If the results are impressive , i might
>> get a
>> publication in
>> this area.
>> *Please explain how you intend to continue
>> being an
>> active member of
>> your project and/or OSGeo AFTER the summer
>> is over:*
>> I was always interested in open source
>> programming but
>> never
>> knew where
>> to start . GSOC provides an opportunity
>> for beginners
>> like me
>> to take a
>> dive in the area open source programming.
>> i have other
>> ideas like
>> implementing IRNN ( In route nearest
>> neighbour
>> querries) which
>> can be
>> implemented within pgRouting.I have other
>> intentions like
>> working for
>> bigger projects like Quantum Gis or
>> Grass.I will be
>> contributing
>> to the
>> community forum and will always try to
>> improve things.
>> *Do you understand this is a serious
>> commitment,
>> equivalent to a
>> full-time paid summer internship or summer
>> job?*
>> Yes, I understand that this is a serious
>> commitment and
>> will try
>> to give
>> my best and work in a professional manner.
>> *Do you have any known time conflicts
>> during the
>> official coding
>> period?
>> (June 17 to Sept. 27)*
>> No .
>> On Thu, Apr 25, 2013 at 12:47 AM, Stephen
>> Woodbridge
>> <mailto:woodbri at swoodbridge>.
>> <mailto:woodbri at swoodbridge>.>**______com
>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>>
>> wrote:
>> On 4/24/2013 2:34 PM, Mukul priya
>> wrote:
>> Hi Steve and Daniel ,
>> I have posted my proposal on
>> Melange Gsoc
>> system. Do
>> have a look
>> at it.
>> Waiting for feedback and
>> suggestions.
>> Can you post a link to your proposal?
>> or the text
>> of it
>> here also. I
>> can never find anything in Melange or
>> I may not have
>> visibility to
>> it yet as I just applied as a mentor.
>> Thanks,
>> -Steve
>> ______________________________**_________________________
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>> <mailto:pgrouting-dev at lists.__**osgeo.org <http://osgeo.org>
>> <mailto:pgrouting-dev at lists.>_**___osgeo.org <
>> http://osgeo.org>
>> <mailto:pgrouting-dev at lists.__**osgeo.org<http://osgeo.org>
>> <mailto:pgrouting-dev at lists>.
>> <mailto:pgrouting-dev at lists>.>**______osgeo.org
>> <http://osgeo.org> <http://osgeo.org>
>> http://osgeo.org>
>> http://lists.osgeo.org/_______**_mailman/listinfo/pgrouting-*
>> *dev <http://lists.osgeo.org/________mailman/listinfo/pgrouting-dev> <
>> http://lists.osgeo.org/______**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev>
>> <http://lists.osgeo.org/______**
>> <http://lists.osgeo.org/____**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>
>> **>__>
>> <http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>> **>__>__>
>> **>__>
>> <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>> **>__>__>__>
>> http://osgeo.org>
>> **>__>
>> **>__>__>
>> http://osgeo.org>
>> **>__>
>> **>__>__>
>> **>__>
>> **>__>
>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130427/44f78be8/attachment-0001.html>
More information about the pgrouting-dev
